Old 07-27-2007   #1 (permalink)
azopelnut's Avatar
azopelnut
Unanswered: Manta/Ascona Getrag mount
Does anyone who has installed a getrag in a Manta or Ascona A have a picture or a diagram of what the rear transmission mount need to be like? I have seen the pic and drawing of the rear getrag mount in the GT but I believe the Manta/Ascona would not be the same as the tunnel is quite different...your help is greatly appreciated
Paul "azopelnut" Heebink
1970 GT 12A-Rotary 5-speed
1972 GT 2.0, 5-speed
1974 Manta, 1.9 Auto A/C
1975 Fiat X19
azopelnut is offline
Old 07-27-2007   #2 (permalink)
Paul;
Here's one way of doing it, if the Manta/Ascona was originally a manual trans car. This was Dieter Heininger's (hiemue on this site) solution. He used two flat pieces of bar stock to bolt right in where the stock mount would have, and used the stock cross memeber for the tail of the 5-spd, and just drilled all new holes, the attached pics are self explanitory.
BQS4 is online now
Old 07-27-2007   #3 (permalink)
Bill Hoffmann's Avatar
Bill Hoffmann
I did something similar. However, if you notice on his mount, the plates that relocate the position of the mount are made of thick plate steel. On mine, I used steel angle, but then added aluminum shims to get the height correct. I'm not saying that's better, just a slightly different way. The rubber mount was from the Getrag, and for the crossmember I used is the stock Manta piece, drilled in two places for the studs. I think I turned the rubber 180 degrees around also.
Bill
Bill Hoffmann is offline
Old 07-27-2007   #4 (permalink)
azopelnut's Avatar
azopelnut
I love this site...thanks guys
ask and it is freely given!
1975 Fiat X19
