Old 05-09-2009   #1 (permalink)
Mark K is on a distinguished road
Unanswered: 5 speed Getrag shifter knob removal
I want to remove the shifter knob that came with my 5 speed. It doesn't un-screw, so I'm guessing it's kind of a press fit. Do you just muscle it off?
Mark K is offline
Old 05-09-2009   #2 (permalink)
david the opel king's Avatar
david the opel king is on a distinguished road
I just left mine on I think it look good and I did not want to mees with it
david the opel king is offline
Old 05-09-2009   #3 (permalink)
If you have the muscles, yes, easier way would be to take a box knife and make two slits.
Old 05-09-2009   #4 (permalink)
That's what I was afraid of. OK, thanks for the info!
Mark K is offline
Old 05-09-2009   #5 (permalink)
If you find a knob you like, but, it doesn't have the proper shift pattern, let me know, I have some sheets of aluminum with the correct shift pattern engraved on them.
Old 05-09-2009   #6 (permalink)
opelnut10's Avatar
Shifter knob removal
If you are going to try to muscle it off, dunking it in a pan of boiling water for a minute or so will make it easier (be sure to wear a glove, or it will raise a blister)
opelnut10 is offline
Old 05-09-2009   #7 (permalink)
heimue's Avatar
Where did you get them??? Are you sure it's the correct pattern???
Dieter
heimue is offline
Old 05-09-2009   #8 (permalink)
This is how I got rid of the original knob and shortened the shifter, if you are interested in putting an aftermarket knob with a thread inside.
Old 05-09-2009   #9 (permalink)
Dieter
I hope so, going to be hard trying to find the guy I got them from to fix the problem...
Old 05-10-2009   #10 (permalink)
1971 GT
CDN OpelNut's Avatar
CDN OpelNut
The shift knob that came with my Getrag simply had a set screw. I just slid down the plastic sleeve that was hiding it, loosened it off and the knob came right off. I'd check before you go forcing anything.
CDN OpelNut is offline
