Old 07-02-2009   #1 (permalink)
fourdukes's Avatar
fourdukes is on a distinguished road
Unanswered: Getrag: Squeaks When Clutch Released
...since this IS a thread about the Getrag conversion. As I said above, I just finished the 4-speed to 5-speed conversion. The transmission is GREAT - feels unlike any manual I've ever had in an Opel (4 Manta's since 1979). It is amazingly tight and solid, not sloppy like all the 4-sppeds I've had in the last 30 years. Anyway, the issue is that anytime the clutch is not engaged (pedal is up) there's a squeaking sound that is not terribly loud at idle, but when driving, it is loud enough to be worrysome. I am running synthetic blend gear oil in the Getrag, right now, just to get things going, to be replaced by the recommended synth once everything is working good. So my plan for tomorrow is to start with the clutch and adjust to see if that will fix it. Has anyone had a squeak issue after the Getrag conversion (or any other time) that might point me in the right direction?
Thanks,
Carson
fourdukes is offline
Old 07-02-2009   #2 (permalink)
Originally Posted by fourdukes View Post
...since this IS a thread about the Getrag conversion. As I said above, I just finished the 4-speed to 5-speed conversion. Anyway, the issue is that anytime the clutch is not engaged (pedal is up) there's a squeaking sound that is not terribly loud at idle, but when driving, it is loud enough to be worrysome. I am running synthetic blend gear oil in the Getrag, right now, just to get things going, to be replaced by the recommended synth once everything is working good. So my plan for tomorrow is to start with the clutch and adjust to see if that will fix it. Has anyone had a squeak issue after the Getrag conversion (or any other time) that might point me in the right direction?
Thanks,
Carson
Perhaps the release bearing? It shouldn't really be "engaged" when the pedal is released, and even when it is engaged, it should be pretty quiet. Does the squeak change when you depress the clutch pedal? Try adjusting the clutch and let us know if that made a difference. If it does, you might be planning to replace the release bearing in the not-to-distant future.
kwilford is online now
Old 07-02-2009   #3 (permalink)
fourdukes's Avatar
I actually did replace the clutch disk, pressure plate and release bearing when reassembling the drivetrain (hadn't planned on it until we were under the car, ready to put the tranny up, and decided that we didn't want to disassemble and reassemble the Getrag too often). Maybe the new release bearing is no good. It's silent when the clutch pedal is pressed.
-cd
Old 07-02-2009   #4 (permalink)
Sounds like the clutch cable is adjusted too 'tight....in other words no free play.
Old 07-03-2009   #5 (permalink)
fourdukes's Avatar
The girlfriend part reminds me...
About 30 years ago, I was working at a restaurant. A bunch of us were hanging out in the parking lot, and I had to go back in to work. I asked one of the girls there (a girl I'd had my eye on for a while) if she would move my car for me ('73 Manta). I then looked at her and asked "Can you drive a 4 speed?". She looked at me, and said "I can drive anything."
We celebrated our 25th anniversary last fall.
-cd
Old 07-03-2009   #6 (permalink)
Originally Posted by DacMan View Post
I don't want my girfriend driving my car,... Thanks, DacMan
You could be like a buddy of mine that finally sold his unfinished 'vette. I asked about it once and his father said he'd never put it back together because he didn't want his wife to drive it. Harold (not me) just hung his head and grinned.
Old 07-03-2009   #7 (permalink)
opelwasp's Avatar
-cd
Very coy. I'll bet she has made you very happy.
Like my wife, while we were dating she would grease my wheel bearings for me, by hand. She has never been afraid of getting dirty. Just how I like her. We are going on 13 years.
opelwasp is offline
Old 07-04-2009   #8 (permalink)
fourdukes's Avatar
Adjusted clutch yesterday. Didn't seem to have any effect. No less or more squeaky. Actually loosened to the point where it wasn't possible to get it in gear. So I'm thinking about the release bearing again. If the release bearing was bad, would it be noisy with the clutch pedal down, as well as up?
-cd
Old 07-04-2009   #9 (permalink)
-cd
The release bearing should not be engaged until the pedal is depressed.
How did you adjust the clutch? Proper adjustment includes releasing the cable tension (remove the clip @ the firewall), then adjusting the pivot stud on the bellhousing until the distance from the centerline of the clutch cable ball-end to the face of the bellhousing is 4.25".
Then you adjust the cable itself. To do this, turn the key to the 'on' position, and pull on the cable until the light on the dashboard lights up (clutch wear light/brake light). You'll need two people to accomplish this of course! Now release the cable until the warning light *just* goes out, and at this point place the E-clip on the cable 2 or 3 slots away from the firewall. That will give you the appropriate free-play to ensure the release bearing is not engaged.
HTH,
Old 07-04-2009   #10 (permalink)
I have a question for you. Was the trans rebuilt before you installed it? You say it is tight, so maybe the input shaft was installed with the wrong clearance and the bearing is a little too tight. The input shaft will turn anytime the clutch is engaged. The way you describe it, it sounds like you have eliminated the throw out brg as the problem IMO.
I guess maybe I should back up a bit.
I don't know how a getrac is constructed. I don't have a book. I am assuming it is an aluminum case with shims to set the clearances. I am only going from a past experience I had with a ZF transmission. on that trans it had similar symptoms and it ended up being a thrust problem.
trlmr is offline
Old 07-04-2009   #11 (permalink)
HTH,
and again for clarity, the procedure that Bob describes is for a Manta/Ascona, NOT for a GT, which doesn't have the clutch-out-of-adjustment light. On the GT, simple adjustments for friction disk wear are done only with the release fork pivot stud to maintain pedal free-play. When you have to adjust both the cable and the release fork (after replacing one or more major components), you first adjust the stud to get the 4 1/4" spacing, THEN you adjust the e-clip to give the required pedal free-play (3/4" to 1 1/4", described as two grooves of clearance in the clutch cable end by the FSM)
Old 07-05-2009   #12 (permalink)
fourdukes's Avatar
Thanks to all for the inputs.
Going back to when we reassembled everything. I adjusted the clutch fork to 4.25", not knowing if that was the same for the Getrag as for the stock 4-speed, but having no other direction, that's where I decided to start. After the reassembly, we got the squeaking as described above. Did some adjusting on the clutch Friday - sort of seat-of-the-pants adjustments to loosen things up a little. No effect. Yesterday, going by the book, and Bob's reminder of how it's supposed to be done, did everything as prescribed. Again, no audible effect. I am puzzled.
I don't know whether the trans was rebuilt before I got it. Bought from OGTS, received last December/January.
Had a thought last night - what if the ball stud wasn't greased when the clutch fork/release bearing was put back together in the bellhousing? Kinda makes some sense that it would squeak when it's not under pressure, and when the clutch pedal is depressed, there would be enough pressure on it that it wouldn't squeak. Kinda makes you want to
-cd
Old 07-05-2009   #13 (permalink)
This topic is taking on a life of its own and deserves its own thread, so I split it off
...Anyway, the issue is that anytime the clutch is not engaged (pedal is up) there's a squeaking sound that is not terribly loud at idle, but when driving, it is loud enough to be worrysome.
Hmm...Noises are darn tough to diagnose even in person, and almost impossible over the Internet. A couple of questions:
Is it a stock clutch?
Is the squeak engine-speed dependent?
What happens when you depress the clutch pedal at speed?
Is the squeak different when in different gears?
I don't think that the release fork ball stud has anything to do with the squeak, but if you were to drop the transmission, it certainly couldn't hurt to lubricate it.
Old 07-05-2009   #14 (permalink)
There was another member that had a 5-spd noise, turned out to be that the cover plate (half-moon shaped cover) for the bottom part of the bellhousing was bent just enough to allow it to touch the flywheel directly behind it. Just a thought....
Old 07-05-2009   #15 (permalink)
Mike's Opel Shop
opellane's Avatar
If I remember when I did my 5-speed Conversion, I used the S-10 Clutch
I had to grind some Aluminum off the inside of the Bell Housing as the clutch rubbed a little bit. Try to pinpoint sound by turning engine over by hand until you hear the noise. HTH
MIKE
1969 Opel GT in Paint Shop
1973 MGB, Red, Weber 38DGES
I have pride in my rides
opellane is offline
Old 07-05-2009   #16 (permalink)
Bill Hoffmann's Avatar
Bill Hoffmann
Yes. My Manta with Getrag also does just that, but only when I've been sitting in traffic for a while. That cover plate is so close it doesn't take much for it to rub. I get a cyclical scraping sound when it happens, which could be described as squeaking.
Bill
Bill Hoffmann is offline
Old 07-05-2009   #17 (permalink)
West Coast GT's Avatar
West Coast GT
Your squeak might be vibration.
Check to see if your "clutch return spring" is missing, broken, or slack. if there is no tension to hold the fork snug out of the way, it will vibrate.
This return spring is exterior to the transmission, and attaches at the throwout arm and to a crossmember (probably the transmission cross member).
West Coast GT is offline
Old 07-05-2009   #18 (permalink)
Mike Preble's Avatar
ttranny noise
I am in the middle of pulling my Getrag to change the bearing on the front of the input shaft. My noise occurs mostly when my tranny is in 1st, 3rd and 5th. I was told this is common when a Getrag is stored on its nose at the junk yard. Water will drain down threw the tranny and down the input shaft and rusts the bearing. My whirring noise is so loud that I must wear ear plugs to drive on the freeway. This has probably contributed to my insanity, but that is another subject.
But I will know better once I get the tranny out of the car. A fun project while laying on your back in 100+ weather. I love sweating.
Just a thought, though and I will keep you informed of what I find.
Mike
Mike Preble is offline
Old 07-05-2009   #19 (permalink)
Bill Hoffmann
I thought of the pilot bearing but this condition would seem top rule that out, since the crankshaft and input shaft are at the same speed.
Old 07-05-2009   #20 (permalink)
Bill Hoffmann
Mike,
Rereading your post, I realize you mean the input shaft bearing, not the pilot bearing.
Sorry,
Bill
