Volvo 240 Rear End Swap - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 104
Like Tree44Likes
Thread: Volvo 240 Rear End Swap
  1. #21
    Swansea, MA
    8,988
    Gary
    4
    Probably. Soft rubber, low exposed mount. The ones in mine practically fell out when I took the arms off. The link arm rubbers were also pretty soft.
    Sent from my SGH-T999 using Tapatalk
    www.alt-opel.us
    @opelgary
  3. #22
    Opeler samdog's Avatar
    Oct 2003
    boston
    345
    Nice job Gary. I always thought that I was supposed to collect parts, I didn't know that they could be put together to make a car. Interesting concept.
    Gary, GoinManta and itb gt like this.
  4. #23
    Swansea, MA
    8,988
    Gary
    4
    Spent most of today chasing down a replacement pump for my lift jack. The pump (did I say it was made in China?) was full of oil and still would only go up half way. I ended up with a HF (Chinese) air over oil pump that is much easier to use.
    I did manage to tack the spring hats on and cut the nose off the trailing arms. Both arms are back in place and tomorrow, I'll re-align everything and weld the rod ends on. (Barring any more surprises!)
    The parts for the links will be here Thursday.
    www.alt-opel.us
    @opelgary
  6. #24
    Swansea, MA
    8,988
    Gary
    4
    Some pics. The last one was a hidden surprise on the stock arms.
    Travis, samdog and Trevil like this.
    www.alt-opel.us
    @opelgary
  7. #25
    Aug 2006
    Goderich, Ontario Canada
    2,684
    P.J.
    Gary, browsing through the Speedway catalogue, I found these arms: 15 Inch Swing Arm - Speedway Motors, America's Oldest Speed Shop
    Looks like they will be suitable for the rear axle conversion as they already have brackets for the braces to create that "triangle" support. They are available in various lengths. It might be easier than converting Volvo's trailing arms.
  8. #26
    Swansea, MA
    8,988
    Gary
    4
    That swing arm would require coilovers or a different spring setup. Plus it is discontinued.
    The Volvo trailing arms are actually working out nicely in the Ascona.
    The spring hat sits on the top surface and is under the stock upper hat. After cutting off the Volvo body mount, the rod ends fit into the Opel body mounts with spacers taking up the slack. The Volvo link mounts on the rear end are angled slightly toward the trailing arms so the front joint of the adjustable links will line up and attach to a reinforced section of the trailing arm. All welding will be done on the arms so it will make it much easier for someone to take the arms to a weld shop and have the rod ends, spring hats and link bungs welded. The rear end will be adjustable in all planes.
    www.alt-opel.us
    @opelgary
  9. #27
    Swansea, MA
    8,988
    Gary
    4
    Rear end is roughed in place.
    Stopping power; Volvo rear disc brakes installed. Middle pic shows the ride height with the wagon rear springs. Needs to be ~2" lower. Gonna try a cut down Volvo progressive spring next.
    Some more pics.
    www.alt-opel.us
    @opelgary
  10. #28
    Swansea, MA
    8,988
    Gary
    4
    Cut 1 3/4 coil off the Volvo springs. The wagon is sitting ~2 inches higher in the back. Going to leave it that way for now and see if it settles down after driving it.
    Bolt on the links, fab a panhard bar and shock mounts, fine tune the alignment and then it's on to sheet metal work!
    ggl likes this.
    www.alt-opel.us
    @opelgary
  11. #29
    Aug 2002
    SW Missouri
    2,252
    Looking good Gary.
    TMK
  12. #30
    Sick with Opelitus My location broszzy's Avatar
    Aug 2007
    Janesville wisconsin
    1,292
    Some more pics.
    Have you thought about modifying your trailing arms, from the picture it looks like you could maybe recess the rear springs 2 - 3 inches. Those T/A's are a lot bigger then the ones you removed.
    Pat
  13. #31
    6,748
    Charles Goin
    5
    Gary not to be "Picky" but any chance you have a picture with drawings and such to replicate the work for a machine shop..?
    Only ask, as I may go this route.. will know more once I get Atlas in hand.
    Pictures maybe worth a thousand words..
    But dimensional drawings can be worth Millions..
    CURRENT
    '74 Opel Manta - "Barbara"
    '05 Pontiac GTO
    In the past owned:
    '06 Pontiac GTO
    2 Bitters (#491/#439)
    '73 Commodore GS
    '73 Blue Max Manta Luxus
    & at least 20 other Opels
  14. #32
    Swansea, MA
    8,988
    Gary
    4
    Quote Originally Posted by broszzy View Post
    Pat
    I originally thought about doing it that way. There was only a 1 inch difference from the top of the arms to the stock Opel spring bucket location. Recessing the springs would have involved a lot more work on the arms. I am trying to keep this swap as simple as possible in case others want to try it.
    Looking at this swap now, modifying the shock towers and using coilovers would be a fairly easy alternative as the shocks are right over the Volvo spring location behind the axle.
    www.alt-opel.us
    @opelgary
  15. #33
    Swansea, MA
    8,988
    Gary
    4
    I plan on doing a full write up with grocery list.
    Locating the rear end was a real pain in the rear end. Having the length of the trailing arms and panhard bar will save a lot of work for any future attempts.
    I still need to find the centerline of the wagon and set the track of the rear end to the body. My front suspension is all new and not in alignment. Plumb bob time!
    I will be using the Volvo driveshaft from the center joint back. Volvo C/J parts are easy to get and fairly inexpensive.
    Again, the beauty of this is all welding is done on the trailing arms, making it easier for those who do not have access to a welder. Brand new trailing arms are $69 ea.
    GoinManta likes this.
    www.alt-opel.us
    @opelgary
  16. #34
    Aug 2006
    2,684
    P.J.
    I told you so.
    Honestly, I do not like those massive Volvo trailing arms. Take another look here:
    19 Inch Swing Arm - Speedway Motors, America's Oldest Speed Shop
    You might find easy and elegant off-shelf solution. As I am building my 2.5 motor and I will likely have to undertake the same project in the near future.
  17. #35
    Opeler My location Bill Hoffmann's Avatar
    Jul 2002
    Wilmot, WI
    704
    I think you did it the right way, especially on a wagon. The stock spring location supports the car by the frame. I would feel better about that than even a modified shock tower.
    Bill
  18. #36
    Swansea, MA
    8,988
    Gary
    4
    I told you so.
    True, but another goal of this swap was to keep costs to a minimum. For under $700, I'll have a locker rear end with disc brakes that will handle the 24v's HP and it uses parts that are readily available.
    GoinManta and G.v.Mainberg like this.
    www.alt-opel.us
    @opelgary
  19. #37
    Swansea, MA
    8,988
    Gary
    4
    Quote Originally Posted by Bill Hoffmann View Post
    Bill
    I will be doing something to strengthen the shock towers (maybe even a roll bar/cage). RallyBob noted that there is a tendency for cracks to develop around the shock towers in wagons. They do not have the structural support that prevents flexing that the Mantas and sedans have.
    RallyBob likes this.
    www.alt-opel.us
    @opelgary
  20. #38
    Your Noble Friend ;-) My location G.v.Mainberg's Avatar
    Nov 2004
    Atlanta, GA - USA
    3,297
    Not only in wagons. I remember back in the 1980's when I got the Röhrl Rallye, the sheet metal around the shock mounting holes was completely broken out. Not deformed a bit, and no rust on it, just cracked clean apart from stress. "Spirited driving" from the first owner of the car, and red Konis do that easily...
    Dieter
  21. #39
    Swansea, MA
    8,988
    Gary
    4
    Progress
    I looked closely at the Volvo springs. The bottom coils were just about touching and the upper coils were doing all the work. I ended up cutting 1 1/2 coils off a set of Manta/Ascona front springs. They sit fine.
    The shock brackets are in place for welding and I am waiting for parts for the adjustable panhard bar. The Volvo bar has a bend in it to clear the pumpkin so I will add adjustment bar and link to the body side mount.
    Final adjustments will be made once the bar is in place.
    www.alt-opel.us
    @opelgary
  22. #40
    Swansea, MA
    8,988
    Gary
    4
    Finished!
    The wheels are centered. The panhard bar and sway bar are in place.
    Pluses for the Volvo 240 rear end:
    • Dana 30 diff. Same as a jeep. many ratios available
    • Parts readily available
    • G-80 locker on '92 204's fits right into older ones
    • Disc brakes
    • All welding is done on the Volvo trailing arms (new ones are ~$70.00)
    • Trailing arms and brackets for links are on the same axis
    • Fully adjustable in all planes
    • Same width as Manta/Ascona diff
    • Front of trailing arms are very close to Opel body mounts
    • Uses stock Volvo sway bar
    • Volvo 240 diffs are common in salvage yards
    Minuses:
    • Axles need to be drilled for 4x100 bolt pattern if using Opel rims (5x108 is stock)
    • Springs need to be cutdown (recessing the springs into the trailing arms will eliminate this)
    www.alt-opel.us
    @opelgary
    1. 1.5L Rear end?
      By soybean in forum 4A - Differential
      Last Post: 03-30-2016, 07:22 PM
    2. Rear End Swap Pics?
      By opelwasp in forum Clutch, Transmission and Drive-train Upgrades
      Last Post: 12-10-2006, 11:09 PM
    3. about toyota rear end, or rear ends in general
      By simplemind7 in forum Clutch, Transmission and Drive-train Upgrades
      Last Post: 02-22-2006, 01:59 PM
    4. Need Advice about Rear-End swap
      By rockytopmark in forum 4C - Axles
      Last Post: 01-14-2006, 07:26 PM
    5. possible volvo engine swap?
      By 73gt1984 in forum Engine Swap Forum
      Last Post: 07-22-2005, 02:13 PM
