Real Name: Allan Wheeler
Unanswered: 5spd vs Auto
73 Gt (RIP), 4 speed, 2.0L, 290H cam, weber, S-10 clutch w/ matched flywheel, sprint to a 2" pipe, Aluminum finned oil pan. SOLD! 70 Kadett Wagon 14k, 1.9L, Auto, weber |
For off the line performance you can not beat the standerd transmission (5speed). The auto will alwas have some lag between the time you put your foot to the floor and the time the car jumps. If I wanted performance I would go with the 5 speed. If I was driving the car everyday in traffic I would go with the auto.
But that is me. You have to make your owen mind up!!
Are WE having FUN YET!! Rick in Atlanta |
Everyday comuter not not I'd prefer a manual over an auto. Some of the newer cars do have very nice autos in em, but still I always have & always will enjoy the shifting.
'71 Datsun 521 '71 Opel GT |
Alan, personal opinion, I manually shift my monza with a beefed up TH 350. I had the option of a high speed stall convertor, but opted for the standard convertor. I want it locked up as soon as possible, so there is no slippage at low speeds/rpm. It's not a dragster that I need to run up the rpm before I slip my foot off the brake. Then again, it all depends on if you drink coffee or soda while driving, if so, then it's kinda hard to shift and hole the soda or coffee when you shift gears. I prefer having the 5-speed in Willit? and may go that route in the monza too. IDK.
Real drivers don't automatics, nuff said
3.18's
Your biggest performance killer is gonna be the diff gears. With a 'hot' cam and those the auto is going to struggle and the 5-speed will be at over-drive gearing .. before you shift into 5th.
You need at least 3.9:1 gears with a 4-speed OD auto or the Getrag and that cam you have. "Hot" cams and the wrong diff gearing are a PIA - the 3-speed auto will just make it worse. IMHO
A 3000 rpm converter with 3.67 rear axles and that cam will go quite nicely. It will launch pretty darn hard, and will be far easier on the driveline than a 5 speed. I have run numerous Opels with big cams and high stall converters with automatics. For in-town driving it's a tough combo to beat. However, for the highway, it pretty much sucks. A 3000 rpm high-stall converter doesn't 'slip' constantly at 3000 rpms as many people think, but under load it will flash up and it will still make for higher rpm cruising speeds, and therefore lower gas mileage. If you do any amount of highway driving, go with the Getrag. If you do all in-town commuting, the automatic in an Opel with a decent converter is tough to beat.
Bob |
hmmmmm most of the driving I do is in town, but would like to use it for road trips too. Stock tire and 3.18 with cruise 70mph at 3300 rpms...not bad. With 3.67 gears it will be turning close to 3800rpms
. Getrag would be 2650rpms. Getrag with 3.67 would be 3055rpms. Would the use of 14" tires bring the rpms down some? BTW anyone have a set of 3.67 gears?
#9 (permalink) | |
#10 (permalink) | |
#11 (permalink) | |
as jordan said if you go to a radical cam the EFI gets upset as it is set up for 1 cam and 1 cam only
to use EFI with a radical cam it needs a new chip mapping to match the injection to the cam or a programable ECU so it can be set up to match on a rolling road session
#13 (permalink) | |
sorry about these questions!!
sorry if I'm hijacking here
#14 (permalink) | |
Depending on the automatic of your choise of course, but from my own experience i can tell that getrag is much better, more reliable and takes much more HP than automatic... Plus, if something brakes, its much cheaper to get the manual in the condition again.
Autos Rule!
Keep watching this space - there are a couple of 'KILLER' auto gearbox Opels in the planning stages.
1) Tri-Matic - The TH180 GT auto box has been used in the 3.0L 12v six-cylinder Opels and even Rover V8's Plus it is extensively used in 4,6 & 8 cylinder Holdens, so it can hack the pace. 2) Quadra-Matic - The Aisin-Warner 4-speed overdrive auto is another magic auto that has been used behind 6-cylinder Opels (same bellhousing as the 4-cylinders ....) Try a Turbo Isuzu Impulse with this 4-speed,overdrive, lock-up convertor auto and it will make you a Believer too!
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 05-03-2006 at 11:34 AM. |
#17 (permalink) | |
Are you saying that a Impulse auto will bolt right up to our 1.9's???
#18 (permalink) | |
Some of the non-Turbo ones do not have lock-up in top gear. Also Opel used this trans on some Monza and Senator models in the mid to late 1980's though I don't REALLY want to take the one out of my Monza. It works very well - the chop down from 4th lock-up to 2nd gear when the pedal is put to the metal just about lifts the front wheels..! However, the DOHC Isuzu Piazzas that were domestic market only got imported to New Zealand in small numbers 2nd hand ... have the stater on the opposite side (the same side as the Opel). Consequently, I have a couple of DOHC Piazza ones that look good prospects for fitting with an adaptor plate. The Piazza my Best Lady drives is auto as well and is very impressive with just 90 hp and about 500lbs more weight than a GT..........
