Opel Forums
Go Back   Opel Forums > Technical Forums > Tech Links and Data > Tech Reference Library > Engine FAQ's
Engine FAQ's Engine specs and modifications
LinkBack Thread Tools Search this Thread Display Modes
Old 01-23-2003   #26 (permalink)
And for what to do with the hoses that were formerly hooked to the Solex Air cleaner, and now don't have a home, go to:
http://www.opelgt.com/forums/showthr...&highlight=PCV
kwilford is offline   Reply With Quote Top home
Old 03-10-2003   #27 (permalink)
opelgal33
Mechanics 101 requested.
I am trying to read this thread and understand half of the stuff you guys are saying, but ain't gettin it
See I am looking around trying to find what comes out of the valve cover as far as lines running. I have none at the time and oil leaks galore. My engine has so many hoses floating around and I dont know where they go. I think some (ones on the drivers side of engine) went to the A/C something or nother that when there. Anyhow can you explain this in laymans terms
By the way I do have the piece of sh** solex still in mine, and yes the Weber is top priority. After I feed my kids, or do they really need to eat, awfully tempting
Jennifer
opelgal33 is offline   Reply With Quote Top home
Old 03-10-2003   #28 (permalink)
opelgal33
I am going to have to borrow a digital camera and take a picture of my carb.
I found the picture jpiper downloaded and mine does not look like this. Unfortunately I can't read some of the discriptions of the hoses.
I don't have the line from air filter
PCV something or other
on the"y" I have one going to distributor the other plugged
Brake Booster???
What is the hose above the "y" connection? I have nothing there either. just the nipple
no cannister vent line either.
Yikes, hows this thing run?
Jennifer, I will try to get a picture in the next day or two
Old 03-10-2003   #29 (permalink)
OK, first, kids need WAY less food than most parents seem to think. So Webers are more attainable than they appear!
Now, a layman's guide to PCV (Positive Crankcase Ventilation) and Opel valve cover hoses. I seem to have made a career on Opel PCV systems, and GT headlights. But I digress....
Internal combustion engines generate internal gases. Well, it happens from things like leaky piston rings and valve seals. If an engine was all sealed up, it would be like a big ballon. And after a while, it would go "pop". The gases would pressure up the crankcase and blow all the oil seals. BAD gases!
In the olden days, cars just had breather caps (or crankcase vents, in the case of post-war British cars) that allowed these gases to vent to the atmosphere. These gases have pollutants in them, such as unburned hydrocarbons. And oil, which dripped all over the sides of old British cars, even when their seals didn't leak. BAD olden days!
Then, some clever Engineer (hmm...) figured out that if you routed those gases to the intake manifold, they would burn up, and we would have a happier planet. So he (or she) invented the PCV system. Most cars, in the past thirty five years or so, use a PCV valve that connects to the intake manifold, where the inherent vacuum "sucks" the gases out of the crankcase and into the combustion process. It also requires a breather, to keep the crankcase from being sucked too hard (into a vacuum condition). The breather filter (usualy inside the air filter cannister) pulls clean air from inside the air filter, and the air goes into the valve cover (and hence the crankcase). On "Vee" engines, one side is the breather, and the other is the PCV valve. In-line engines usually have one fitting at each end.
At higher rpm (or as the engine gets old), the engine generates more gases than the PCV system can remove (Blow-by) and the breather reverses flow, and gases flow OUT the breather, and into the throat of the carb or fuel injection throttle body. Either way, the gases were burned. GOOD PCV system!
The PCV valve is usually stuck in the side of the valve cover, and is a combination check valve and metering valve. The check valve only allows gases to flow out of the valve cover, not in. And the metering function keeps too much air from being pulled OUT of the crankcase.
Now, our Opels have a slightly different system. Instead of a PCV valve, they use a metering orifice where the small hose connects the small hole in the valve cover to the PCV orifice at the intake manifold. This is the small metal tube just below brake booster fitting, as shown in jpiper's picture at:
http://www.opelgt.com/photos/showpho...t=1&thecat=500
So, the small hose is the equivalent of the PCV hose in most (especially North American) cars. But Opels of this era do NOT use PCV valves! The big hose, which is where folks seem determined to install PCV valves from their local NAPA dealer, is the equivalent of the breather. It is connected at one end to the air filter (to draw filtered air IN to the valve cover at idle, and out at higher rpm) and the other end to the big hole in the valve cover. DON'T install a PCV Valve here, as it will block the intended flow of air and crankcase gases, and cause the oil seals to leak even worse than they might already.
So, after this diatribe on the theory and operation of PCV systems, here's the scoop. Big hole in the valve cover connects to the similar size tube on the stock air filter neck (just before the dreaded Solex). If you have a Weber with the typical flat air filter, you need a fitting installed on the bottom to connect the big hose to. The little valve cover hole connects to the PCV orifice tube.
If you also want to know where the gas tank and charcoal cannister vent lines connect, the pages I mentioned previously have more on that topic.
Old 03-10-2003   #30 (permalink)
opelgal33
Keith, Keith, Keith let me show you how it's done in "Laymans terms"
So what you are saying is that the little nipple by the brake hose and the distributer hose goes to the little hole in valve cover and the neck of the air cleaner has a big nipple that goes to the big hole. See thats how its done.
Just being funny. Ya'll have been doing this so long and or have some mechanical background that you can't bring yourselves to think there are idiots out there (like me) that will attempt to work on a car with no previous knowledge. Of course then again the way these cars tend to get butchered by the PO, there are more of us out here than you think.
I really appreciate all your help. I see where the hoses go that are missing. I know this is part of my oil leak problem. Maybe even the whole problem.
Ya'll will train me yet. Jennifer
Old 03-10-2003   #31 (permalink)
opelgal33
almost there
Just when I thought I had it.
Lets see how many more times we (you, Keith) can go over this.
Let me tell you what I have, because it is not what you have.
I understand the "t" shaped piece that has a small opening going to the distributor ( which mine is plugged) The end of the "t" goes to brake booster, and the larger nipple goes to larger nipple on distributor. Also I see where large whole on valve cover goes to air filter.
Now comes the confusion. Under the "t" is another nipple very hard to see. I assume this should go to the small valve opening. Yet mine is attached to a metal tubing that goes back towards the firewall and down under the car?? And what about the vaccum advance, where does that go from the carberator?
my vent line from gas venting system that goes down the back end of the car all the way up front, is just hanging around in the nose of the car??
Sorry if you seem to be repeating yourself over and over.
Thanks Jennifer
Old 03-10-2003   #32 (permalink)
Site Admin
Gary's Avatar
Just make sure the nipple the hose from "the little hole in the valve cover" goes to has a real small hole in it not a full size hole. The small hole helps to control (meter) the amount of vacuum to the valve cover.
Gary is offline   Reply With Quote Top home
Old 03-10-2003   #33 (permalink)
GT Owner
opelgt722002's Avatar
Classified Rating: 100% (1)
opelgt722002
Gary, you wrote:
The small one connects to a metered orifice located on the intake either at the engine side below the carb base or is part of the brake booster vacuum fitting.
I just looked at the intake manifold on a 70 GT and it has a 90* fitting on the engine side instead of below the brake booster vacuum fitting. My 72 GT is on the outboard side.
Which year intake manifolds have the fitting on the inboard side and which on the outboard side?
opelgt722002 is offline   Reply With Quote Top home
Old 03-10-2003   #34 (permalink)
Site Admin
Gary's Avatar
I *believe* the early ('69 - '70) engines had the 90° fitting. The later ones had the metered nipple on the brake booster fitting.
Old 03-10-2003   #35 (permalink)
webster
"Now comes the confusion. Under the "t" is another nipple very hard to see. I assume this should go to the small valve opening. Yet mine is attached to a metal tubing that goes back towards the firewall and down under the car?? And what about the vaccum advance, where does that go from the carberator?"
opelgal do you have an auto trans? because on my '72 auto that metal tube goes to the vac modulator on back pass side of trans.
and the fitting on the intake (brake booster connection has two little nipples not one ). the nipple below this on intake goes to the valve cover
webster is offline   Reply With Quote Top home
Old 03-10-2003   #36 (permalink)
webster
I have a great write up from OGTS on this subject but it's to large to download/or i dont know what i'm doing cause its not working. if anyone wants it e-mail me at
ptregan@hotmail.com
Old 03-10-2003   #37 (permalink)
opelgal33
Yes your right there are two nipples on the "t" . One goes to the distributor and the other?? Are you saying that the little one with the tiny hole is the one that goes to the valve cover? I thought this one went to the small nipple on the distrib?
yes auto trans on 72
Old 03-10-2003   #38 (permalink)
webster
The other goes to the vac modulator on the trans (tail end pass side) metal pipe that goes to fire wall e-mail me i'll send the write up it has all the pics you'll need to get it done
Old 03-10-2003   #39 (permalink)
GT Owner
opelgt722002
Keith, you said:I tapped the valve cover with a 1/2 inch NPT tapered tap and bought a 1/2 by 3/8 brass barb fitting to connect the hose to . How much material would you estimate you had to remove inside the valve cover to enable you to tap the 1/2"npt?
Old 03-10-2003   #40 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
none
I always just ran the taps right in, 1/2"npt for the big hole and 1/8" for the small hole.
You can also get a pair of double nipples, shorten one side of each, and solder them in place. This gives a bit shorter profile (doesn't stick out as far) and will let you but the hose almost all the way up to the valve cover.
oldopelguy is offline   Reply With Quote Top home
Old 03-10-2003   #41 (permalink)
opelgal33
Tell me if I'm on the money:
Large valve cover hose goes to fixture on neck of air filter
Small valve cover hose to first smallest nipple on "T". (pin hole)
Advance goes to larger nipple on distributor
Second nipple (bigger) on the "T" goes to smaller nipple on distrib
End of "T" is brake booster fitting
All these are outboard nothing hooked up on inboard
PO has only two hoses hooked up to carb. Second nipple on "T" goes to large distributer nipple and brake booster Is hooked up. Thats it.
Not only that, but I think my brake booster fitting isn't screwed on all the way because the nipples face towards nose, and pictures i have seen face towards fire wall.
Thanks everybody,
Jennifer
Old 03-10-2003   #42 (permalink)
Layman?
First, I can't help it if I wanted to be a writer, and not a mechanic. So to me, I DID put it in "layman's terms". Hey, I'm an Engineer! At least I didn't go off and try to "solve it from first principles"! Or use a bunch of integrals and differential equations. And I did finally say: "put the big hose in the big hole, and the small hose in the small hole". I just wanted you all to know that PCV in an Opel is different that in most cars. And to not try to install a PCV valve. 'Cause I just took one off Kat's GT, and after replacing all her engine seals, I wanted at least one person to avoid all that pain. OK, I'm feeling better now....
In point form:
"Large valve cover hose goes to fixture on neck of air filter"
Yes.
"Small valve cover hose to first smallest nipple on "T". (pin hole)"
No. At least I don't think so. The "Tee" that I am referring to should have a big end (for the brake booster hose) and only have one small tube (for the distributor vacuum retard. This connects to the small nipple on the distributor. This can be deleted to give a better idle, by capping the tube to prevent a vacuum leak. But the PCV orifice tube should be just below the brake booster hose tee, on the intake manifold. I believe that I read somewhere that '73 and '74 Opels (pre-fuel injection) had the PCV tube on the inboard side of the intake manifold. But if the nipple has a very small internal hole (1/16 inch) it should work as a PCV orifice. Just make sure that there aren't any other open fittings on the intake manifold that would cause a vacuum leak (such as where the PCV orifice should be, directly below the booster fitting) .
"Advance goes to larger nipple on distributor"
Yes. And the other end should hook up to a nipple on the carb base, just above the level of the throttle plate. So it sees no vacuum at an idle, and maximum vacuum when the throttle is wide open.
"Second nipple (bigger) on the "T" goes to smaller nipple on distrib"
I don't know what "tee" this is. Perhaps this is from an Auto tranny model for the modulator valve?
"Not only that, but I think my brake booster fitting isn't screwed on all the way because the nipples face towards nose, and pictures i have seen face towards fire wall."
Maybe it is just screwed in tight to prevent a vacuum leak? You should be able to unscrew the big tee, and wrap the threads with teflon plumbing tape. Then, screw it back in until it is snug. And the nipples face whatever direction you want.
Old 03-11-2003   #43 (permalink)
opelgal33
I finally get it.
One more tiny question. May not even pertain to this, but I noticed on my driveway after letting the car sit while running, that there were oil spurts. They must of come from the exhaust??? Why?
Just a few more tweeks here and there and I hopefully will have her ready for her first trip. We are headed to Charlotte NC for a car show.
Thanks guys and gals
Jennifer
Old 03-11-2003   #44 (permalink)
webster
1) Large valve cover hose goes to fixture on neck of air filter!
YES
2) Small valve cover hose to first smallest nipple on "T". (pin hole)!
NO
Goes NOT ON T-connection, but below t- connection on intake (hard to see with carb on but you can feel with hand, it's also larger than the smallest nipple on the "T")
sm. nipple on T connects to metal pipe going to fire wall for auto trans vacume modulator (not dist.vac)
3) Advance goes to larger nipple on distributor!
NO.
goes on middle of carb body, pass. side (solex carb)
4) Second nipple (bigger) on the "T" goes to smaller nipple on distrib!
YES
(it is for vac retard on inboard of vac advance of distrib. closest to cap.)
5) End of "T" is brake booster fitting!
YES
(6) All these are outboard nothing hooked up on inboard
YES
ON '72 AUTO TRANS GT
(7) Second nipple on "T" goes to large distributer nipple and brake booster Is hooked up. Thats it.
"T" has 3 nipples for cars with auto trans (2 nipples for standerd trans cars) EACH A DIFFERENT SIZE -
(1) LARGEST goes to BRAKE BOOSTER
(2) SMALLER goes to DISTRIBUTOR VACUME RETARD (closest to cap)
(3) SMALLEST goes to METAL LINE towards fire wall under car to Transmission VACUME MODULATOR.
[UNDER (NOT ON) THE "T" THERE IS A NIPPLE, IT IS TO BE CONNECTED TO THE SMALLER HOSE COMMING OFF THE VALVE COVER (hard to find with carb on but it is there)]
(8) Not only that, but I think my brake booster fitting isn't screwed on all the way because the nipples face towards nose, and pictures i have seen face towards fire wall.
USE A small WRENCH AND TRY TO TIGHTEN (DO NOT FORCE)
IF NO MOVEMENT REMOVE, CLEAN THREADS, AND REINSTALL.
TEFLON TAPE WILL WORK TO SEAL IT UP NO MATTER WHICH
WAY IT FACES.
Once again if you give your E-MAIL address I'll attach all the info you need
WEBSTER
Old 03-11-2003   #45 (permalink)
Site Admin
Gary's Avatar
WEBSTER
Webster, Send it to me and I'll post in in the Tech section. I'll PM my email.
Old 03-14-2003   #46 (permalink)
webster
http://www.opelgt.com/photos/showphoto.php?photo=1134
here are the correct placements for the vac hoses & hot water choke hoses under hood.
Mod edit: Corrected the url link.
Old 03-14-2003   #47 (permalink)
opelgal33
Sorry we couldn't connect via email. I tried twice. I did call OGTS and they faxed me a copy of the hose sheet.
I notice now you have it on the members photo site under your name. I suggest that if anyone has this question in the future they go to the site webster posted above. Big Big help
Jennifer
