Old 08-11-2008   #1 (permalink)
Jaakkob's Avatar
Jaakkob is on a distinguished road
Unanswered: Opel Rekord engine replacement?
hi. I own a opel rekord hardtop 71 automatic.
Im tired of my old, oil spitting 1900 and thinking about replacing it with a 2.2 or 2.4 l. Or maybe a commodore 81, 2.5l 6 piston, if that could fit?
how does that engine fit with the automatic trans? any problems with the flywheel or is it just bolt on?
Have changed a couple of 1900s before, but never on an automatic.
Very thankful for any tips or knowledge on this before i start ripping it apart!
Jakob
Jaakkob is offline
Old 08-11-2008   #2 (permalink)
tomking's Avatar
I am sure some other more knowledgeable than I will speak up. But I think since you have an automatic 1900, that an automatic 2.0 or 2.2 liter will bolt right up.
TMK
tomking is offline
Old 08-11-2008   #3 (permalink)
Supercharged 2.4
Gumby's Avatar
Technically speaking just about anything could be made to fit…
The 2.4 is what I am in the process of swapping into my GT. It is a pretty straightforward change as almost everything is bolt in minus the EFI equipment. The automatic tranny should be plenty strong enough for the 2.4. Just try to get the Omega 2.4i engine instead of the later frontera 2.4 otherwise you'll have to swap the flywheel out.
Gumby is offline
Old 08-11-2008   #4 (permalink)
2 Fast 4 U's Avatar
Welkom here Jakob
The 6 in line wil fit after you place the radiator more to the front, see if you can find any photo's of a Commodore.
The 4 in line engines are bolt-in.
And we like photo's lots of photo's
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is online now
Old 08-11-2008   #5 (permalink)
heimue's Avatar
Jakob,
4 cylinder CIHs that will fit: All (1.9, 2.0, 2.2, 2.4, or any other CIH bored out up to 2.7 by any of the known engine tuners). These are bolt-on.
6 cylinder CIHs and DOHCs that will fit: All (2.2, 2.5, 2.8, 3.0, 3.0-24V). For these you need either the Getrag 240 or Getrag 265, or whatever else they came with where you are taking them out (Opel 5-speed gearboxes or automatic transmissions out of Monza, Senator, Omega A). These are close-to-bolt-on. Everything you need is available to buy (use Commodore parts, and parts from the engine donor car).
4 cylinder DOHCs that will fit: 2.0-16V or 2.0-16V turbocharged, with Getrag 240 gearbox out of a Manta B 1.8 or Rekord E 1.8, with some other modifications.
You decide how much you want to spend for having fun, and then decide for yourself.
Enjoy!
Dieter
heimue is offline
Old 08-12-2008   #6 (permalink)
Jaakkob's Avatar
thanks for all the info!
Think i go for a 2.2 or 2.4 CIH. Will see what I can get my hands on.
How about the 2.4 l, is it better to go with the Fuel injection or to fit a 2.2 cylinder head with carburetor? got a 2,2 and a 2.4 L cylinderhead lying in the garage. wanna beat out as much cheap horses as possible
Will post some pictures when i can find my camera
Thanks in advance
Jaakkob is offline
Old 08-12-2008   #7 (permalink)
Thanks in advance
Intake manifold mounting is identical for the 2.2 and 2.4 heads, so your choice! 2.4 has slightly larger valves, I believe, but Bob says 2.2 flows slightly better "stock" . . . as in, direct from factory.
Old 08-12-2008   #8 (permalink)
2.2 and 2.4 heads use identical-sized valves. The 2.2 outflows the 2.4 on the intake side....122 cfm vs. 110 cfm. But the 2.4 outflows the 2.2 on the exhaust side...93 cfm vs. 77 cfm.
I would tend to use the 2.2 head, as they make better torque thanks to the smaller exhaust ports, even on bigger engines. With a split-profile cam favoring exhaust flow (the only Opel CIH head that needs it!), the 2.2 will run very well.
