+ Reply to Thread
Results 1 to 9 of 9
Thread: 70 opel kadett fastback
    Opeler opel fastback is on a distinguished road opel fastback's Avatar
    Nov 2008
    shrewsbury ma
    i have a 70 opel kadette ls fastback. i just pulled the 1.1 as it was melted beyond belief. im looking to put in a 2.8 v6 out of a s-10 with the 5 speed. is this feasible? im new to this but i would like to put an engine that is reliable and cheap parts wise. is this engine swap a good idea? or am i barking up the wrong tree? thanks chris
  2. #2
    Opel Intern Redskinsjbs is on a distinguished road Redskinsjbs's Avatar
    Aug 2008
    Washington DC
    600
    Blog Entries
    I'd say try to find a smaller engine. The kadett is not a very large car, so if you are going to be putting in a larger engine, it will require extensive modification to the body/frame. If I were you, I'd try to find a 1.9l opel engine. This would fit nicely, be reliable with a Weber and Pertronix, and would require no modifications (minor ones, if that) to the body of the car. Plus, it would be an opel engine in an Opel car, which is always nice.
    If you are looking for more power, the 1.9 will give you more, but many have used larger blocks or bored out the 1.9 block (It can bored out a HUGE amount and still be safe) and given them longer strokes. This, combined with a 5 speed transmission should be just about everything you could ask for in such a small car without converting it into a race car.
    J Swift Sincerely
    Flickr photos
    Videos
  3. #3
    "The Jägermeister" heimue is on a distinguished road heimue's Avatar
    Nov 2004
    Newnan, GA - greater ATL area
    1,469
    Quote Originally Posted by Redskinsjbs View Post
    If I were you, I'd try to find a 1.9l opel engine. This would fit nicely, be reliable with a Weber and Pertronix, and would require no modifictions (minor ones if that) to the body of the car.
    I wouldn't say this out loud. You need to modify:
    - the front mask needs to accomodate the radiator, which is about 8" further forward as in the 1.1. You need a donor front mask to do it, and extensive welding is needed. Or gutting out your existing front mask, with even more cutting & welding...
    - switch out the complete front axle from a 1.9, including the larger brakes
    - while doing this, don't forget to put in the master brake cylinder with booster from the 1.9
    - use the gear box and drive shaft from a 1.9
    - use the rear axle from a 1.9
    In short, forget about it. It's not worth the trouble . It's way cheaper to buy a finished 1.9, which has more HP, but is heavier too.
    As for the original question of Chris, you can drop in whatever you want, but be prepared to
    - spend half of your life doing it
    - spend half of your life's earnings doing it.
    I would really like to see a Kadett with V6, since I LOVE Kadetts; but if you start, prepare for a long road ahead of you!
    My recommendation: stay with a tuned 1.1, put a nice Weber on it, and enjoy your Kadett as it is. It's a lot of fun w/out modifications. And dirt cheap & absolutely reliable!
    BTW, you own an Opel "Kadett", not a "kadette".
    Enjoy,
    Dieter
    Last edited by tekenaar; 11-24-2008 at 10:28 PM. Reason: half your live; some nice Webers
  4. #4
    6,000 Post Club namba209 (R.I.P.) is on a distinguished road namba209 (R.I.P.)'s Avatar
    Aug 2002
    6,037
    Chris, Dieter has it right. To put in a larger engine, Opel or otherwise, you're gonna have to do some mods, as he stated. To give you and idea of what it will take to dorp in a 60 degree GM V-6 in an Opel check out the link at the bottom of this post. This little project took me 7 years in conjuction with a complete restoration, and I'm still paying off the credit card I started the project with.
    Performance Articles - Opel Forums
  5. #5
    Saint Michael, MN
    1,724
    Blog Entries
    The s-10 2.8 is going to be a hard fit in any Kadett mostly because of the starter and front crossmember. With the transverse leaf spring you can't modify the crossmember, and the starter is so long front to back there's no where for it to go unless you cut and patch the firewall so you can move the engine and trans back about 6".
    If you have a FWD 2.8, though (or one of the dual-drilled 3.4 replacement motors) where the starter is on the driver's side, you might be able to use a late model Malibu gear reduction starter and make it all fit. I'll try and test fit one for you next week and get you some pictures, as I have a Kadett with no engine in it already on it's way this weekend.
  6. #6
    Nov 2008
    shrewsbury ma
    i appreciate everyones input on this. i have a parts car with a good 1.1 and the dual carbs but i wasn't sure if it was going to be durable enough as it seems i can hardly find parts for it. i have access to a 1.9 but id rather not rip it out of the car because it has an actual 274 miles on it. it had an accident brand new and was left in the garage. the old guy is still hesitant to part with it. its an automatic to. does a modern 2.4 dohc from a front driver gm bolt onto the opel transmission? thanks chris
  7. #7
    Cunning Linguist tekenaar will become famous soon enough tekenaar's Avatar
    Plano, TX 75074
    4,467
    tekenaar has made a donation to the forum!
    Quote Originally Posted by opel fastback View Post
    i apreciate everyones input on this. i have a parts car with a good 1.1 and the dual carbs but i wasn't sure if it was going to be durable enough as it seems i can hardly find parts for it. i have access to a 1.9 but id rather not rip it out of the car because it has an actual 274 miles on it. it had an accident brand new and was left in the garage. the old guy is still hesitant to part with it. its an automatic to. thanks chris
    Yes, absolutely!! . . .
    nope!
  8. #8
    Jun 2003
    New Zealand
    5,690
    A little beauty!
    ... i wasn't sure if it was going to be durable enough as it seems i can hardly find parts for it. .. thanks chris
    Chris - have a look here:
    Opel OHV engine - Wikipedia, the free encyclopedia
    The tiny OHV motor is a really good motor and many parts are still available for it as it was used right through to 1993.
    It is light, gives good power and is economical.
    The 'rules' changed with the financial crisis - you may regret giving up the cost effectivness of the smaller motor!
  9. #9
    Opeler pw8penguins is on a distinguished road pw8penguins's Avatar
    Jan 2005
    Ashland, Mass
    16
    Opel Kadett Fastback
    Just like people to know. I just traded Chris for the Opel in the Forum..
+ Reply to Thread
