Old 01-12-2009   #1 (permalink)
R8Gordini
Real Name: Paul
r8gordini is on a distinguished road
Unanswered: Engine swap for 1.1L Kadett B with 1.2 Corsa A
I own 68 Kadett "B" LS 1.1L in europe and was wondering if
a later Opel Corsa "A" 1.2L engine would bolt up to the 1.1L Kadett transmission ??
I would probably have to change the distributor system to a crankfire type but thats ok.
r8gordini is offline
Old 01-13-2009   #2 (permalink)
Hiro's Avatar
Hiro
I don't think this will work:
the CorsaA 1.2 has the "OHC" engine with alu head & overhead camshaft,
whereas your KadettB 1.1 has the old "OHV" engine with cast iron head & lateral camshaft (like your R8 Gord IIRC...).
I think only the CorsaA 1.0 was fitted with the old "OHV" engine,
better to find a OHV 1.2 from a KadettC (easy swap in Europe).
HTH,
Hiro
Hiro is offline
Old 01-13-2009   #3 (permalink)
heimue's Avatar
Basically Hiro is right. I just wanted to add that you could pair a OHC engine from a Corsa with a Getrag 240 from a Manta B or Rekord E with a 1.8 Liter engine. This is not the "regular" Getrag 5-speed, it has a different bellhousing, fitting the OHC/DOHC line of engines. The gear box has gotten pretty rare, but comes up every once in a while on German ebay and will set you back 500-800 Euro + shipping.
Dieter
heimue is offline
Old 01-13-2009   #4 (permalink)
R8Gordini
Real Name: Paul
Thanks for the responses.
Corsa A engine is a newer engine with 5 main bearings and OHC and thats what is atractive about it.
A couple of years ago I drove a Corsa GT I think it was a 1.3s engine and it went pretty good.
I think it would be the perfect power, with a decent fuel comsuption for the Kadett. Dont forget that in Europe gas is over $2.00 per liter (7.00 to 8.00 US gallon)
I think that if the engine would bolt up to the Kadett transmission I could make it fit, using a crank fire ignition system and electric fan for the radiator.
I am happy enough with the 1.1L Kadett engine but the 3 main bearings scare me a little bit, specially when I have to rev it quite high to maintain the 120 km/h speed limit on the higways, so I usually keep it around 100 to 110 km/h
I also have a question about the rear end, but I will post it in the apropriate
forum.
Paul
Old 01-13-2009   #5 (permalink)
Don't Worry!
The 1.1L OHV motor has been rev'd to over 8,000 rpm in competition and will happily go to 6,500 rpm on the street for years and years.
Though it only has three main bearings the stroke is very short (61mm - 2.40") keeping stresses quite low.
Enjoy what you have while finding one of the the Kadett C 1.2L OHV motors for a bit more power!
Old 01-15-2009   #6 (permalink)
TheBIG is on a distinguished road
corsa a 1.2 is a ohv engine , it is the same engine like in kadett c 1.2 , only corsa b has 1.2 ohc engine
TheBIG is offline
Old 01-15-2009   #7 (permalink)
mamakevf's Avatar
mamakevf is on a distinguished road
Some corsa a's did come with 1.2 ohv engines, some with ohc. The ohv engines in the fwd cars do not have the same engine mounts as in the rwd kad c's . The mounting holes on the rwd block are missing from the fwd block but can be drilled as the space were they originally were are still there in the casting. The ohc engines will not mate to the kadett g/box.
mamakevf is offline
Old 01-15-2009   #8 (permalink)
ggl
ggl's Avatar
ggl is on a distinguished road
You might be able to find a 1.3 "S" engine with transmission from an Ascona/Manta B, these cars are known as "1.3 J" and have the newer OHC engine mounted north/south with a 4 speed transmission. That would make for a realtively easy transplant aside from the already mentioned distributor issue
"The nice thing about standards is that you have so many to choose from"
--Andy Tanenbaum--
ggl is offline
Old 01-19-2009   #9 (permalink)
R8Gordini
Real Name: Paul
would this be the same engine as on the Opel corsa GT 1.3 ??
So what you are saying is that the 1.3 engine would mate to the ascona transmission...
would the ascona trany be a straight fit into the Kadett B 1.1L
Paul
Old 01-19-2009   #10 (permalink)
ggl
ggl's Avatar
I do not know too much about that engine/tranny combo other than I had a brief encounter with it since a friend of my brother had an Ascona B with it, that was either an 80 or 81 as it had the plastic bumpers and I believe those were the only model years with that particular engine, up that point they used the 1.2 pushrod engine
I know it had the 1.3 OHC engine as I helped him change the head gasket but I can't remember if it had the distributor at the rear, I'm pretty sure it had the same semi-long gear lever as all the other Ascona B's so my guess is that it used the same gearbox but with a special bellhousing as that would make the most sence from a financial POV for Opel
My guess is that if you find that special bellhousing somewhere you would be able to hook up any "small block" OHC engine from the Corsa/Kadett range with an Ascona transmission but obviously it would be easiest if you found a complete unit from an Ascona B with the correct engine mounts and all, easier to modify something than start from scratch
I don't think it's the exact same engine as the Corsa GT but I could be wrong, power output was rated at 75 hp, the Ascona B model you're looking for is known as the "1.3 J" and as you can guess it's not a particularly popular engine choice for such a large car so you can probably get it fairly cheap
I don't know if the standard Ascona gear box will fit the tunnel of a Kadett B but we've been able to fit it in a Kadett C with the small tunnel, the exhaust was a tight fit though and we had to use a big hammer to modify the tunnel a wee bit
Just rememeber it's been about 15 years since I worked on that car so don't run out and buy different engines and such based on my say so, that's why I'm suggesting that you buy a complete engine/tranny combo from one of these cars rather than mixing and matching
--Andy Tanenbaum--
ggl is offline
Old 01-21-2009   #11 (permalink)
OPEL PARTS GREECE
alpharm's Avatar
alpharm is on a distinguished road
S83 CORSA-A 1983-1992
10S 12N,12NC,E12GV PETROL ENGINES ok for the mod
The other are OHC engines
12S,12ST,12NV PETROL ENGINES
C12NZ PETROL ENGINE
13S,13SB,13NB,C13N PETROL ENGINES
14NV,C14SE,C14NZ PETROL ENGINES
E16SE,C16SE,C16NZ PETROL ENGINES
15D,15TD DIESEL ENGINES
You may have a engine mounting problem but with a drill everything will be ok
The trans can be used also from Kadett/C Ascona Manta/B 1.2 with the shift gears either in front or rear
E-mail: alpharm@otenet.gr
Online: (MSN users-Windows Live Messenger): Opelparts@hotmail.com
Skype: Opelparts
alpharm is offline
