Future Opeler
Real Name: Casey Boudoin
Unanswered: V6 Swap into Kadett
#2 (permalink) | |
Engine size/brand? Just trying to narrow it down a bit. Quite a few have put 60° GM V6's into Opel GT's, but not many other swaps are documented. I haven't seen a Model 50 (Manta/Ascona) swap shown here, nor have I seen any Kadett swaps other than a pseudo-drag race 4.3 swap.
Future Opeler
69 kadettL 1900 2 door wagon. wondering what i can fit in the engine bay with out chopping it up. i was also looking into mazda miata motors. small and still is rearwheel drive and the rearend is small.
![]() Provided Answers: 10
I have installed both 60 degree and 90 degree V-6 engines on GT's and the cutting is not as bad as people think. I got the conversion down to one weekend on the 60 degree V-6, two weekends on the 90 degree. The best bang for the bucks would be either a quad-4 or a Zetec engine coupled to a T-5 tranny. You can buy most of the parts required and can be done in little time, making your conversion driveable after just a few days. I have not done a Kadette but if you post a picture with a few dimensions, I might be able to help you on it.
Without cutting up the body of the car the Kadett is very limited for installation of v-shaped motors because of the starter. Any starter that runs along the oil pan and hangs below the centerline of the crankshaft is limited to <7" in length before it would hit the front suspension crossmember. Cutting the firewall and setting the engine back some would remove this concern, but then you're stuck with something you can't undo.
Best bet, then, is a motor where the sterter is mounted up high, like the one on the Opel engine is. Most 4-cylinder imports fit this bill, and a few v-6s like the one in the Catera. If your Kadett has the 4-speed transmission there isn't much of anything that's going to fit in the transmission tunnel. The Miata trans in particular is way too long. An auto trans tunnel is more forgiving, but still pretty short.
You requested some info on installing a V-6 in an Opel. Here's the link to a 6 part Article on the 3.4L V-6 engine I installed in my GT. It may give you some insite on what it takes to do the deed. HTH.
Performance Articles - The Classic Opel Forums
