Unanswered: Opel Manta Not Starting Fuel Injection Problems
Manta GTE = Manta B with a 2.0 EFI engine.
If, like you are saying, the injectors inject fine, it can only be a problem with the ignition. Did you check for sparks? Take one out, have somebody else start the engine, and watch whether your spark plug gets nice sparks (don't forget to put the head of the spark plug on ground). If that looks good, I suspect a problem with your potentiometer on the air flow meter. Dieter
Manta Maniac
Crap in the tank blocking the fuel pick-up filter...same as the infamous GT "sock" problem...
Politicians and diapers have one thing in common. They should both be changed regularly and for the same reason. |
Hi
Thank you all for your replies. My Manta is a 1987 gte I have already checked the spark plugs there okay I did think of the air flow meter but how do I test it is it possible? Also the fuel is pumping And pressuring with no obstructions |
Manta Maniac
It must be bad when it's keeping you awake at night Eddie!!
If you are sure the probem is under the bonnet: Try to find another Manta owner who is willing to let you swap parts with the 2 cars side by side. Swap 1 item at a time, and when you transfer the problem, bingo! (beem known to trouble shoot aircraft this way, but don't tell the pilots...)
Two Ideas -
1. Does your car have a mass air flow meter? It sounds like it could be symptomatic of a faulty one. If so, my experience with my personal vehicles is the engine will crank, fire, and rev for a brief moment, then die. Some models will eventually figure out the sensors are out of spec, and will default into "limp-home" mode. 1987 sounds too early for this last feature. How to test one? I don't know. Try to obtain a used one from a salvage yard to check if the engine will run. If so, order a new one for more money, unless you have faith in the one from the salvage yard (and the car is not used for wife & children). My particular method consisted of cutting the damn thing open with a Dremel Tool and poking around in it; which was met with marginal success, at best. 2. From your statement the car sat idle for years, and your problem became progressively worse, I'm lead to believe you may have bad fuel. Although, this would not be consistent with the engine firing up, then dieing. Drain the fuel and run it through a small engine such as a lawn mower (or my favorite - a 2 stroke margarita blender). If the lawn mower runs, then go back to your mass air flow meter, or whatever form of sensing air temperature, air flow, and throttle position your car employs. Chances are, connections in a sensor circuit just aren’t connecting. This happens when they sit for extended time. Although, this too, is inconsistent with the problem worsening the more the car ran. |
It's a throttle position potentiometer, like the good ol' style.
Mass flow meters weren't introduced at Opel before they had the OHC/DOHC engines in the very late 80's/early 90's. Dieter
#13 (permalink) | |
Hi
Thanks again to everyone for your advice, also to answer one suggestion I have already Completely washed out the fuel tank and replaced the fuel, I think the air flow meter may be The problem, dos anyone know were I could get one I live in Ireland but anywhere in the UK Should not be a problem as it could be posted. one suggestion was to cut it open could you Elaborate on the radical suggestion |
Yes, go here in the UK
ATP Electronic Developments Ltd - Remanufactures Fuel Injection Parts e.g air flow meters, ecu/ecm`s etc
TMK |
Maybe I have a better idea. What is your Bosch part number?
I may have one for you that I will trade if you can find one to fit my 84-87 2.2 liter FI engine. I need an AFM with part number 0 280 202 068. I have a 0 280 202 006 for trade.
TMK |
#18 (permalink) | |
Bill |
Thanks to everyone for your help, if anyone is interested I found the problem there is a earth wire
Attached to the air intake housing of the fuel injection unit and this was broken even though the Outer insulation of this earth wire was holding it together making it appear intact |
#20 (permalink) | |
Manta Maniac
Well done finding a well hidden fault!
