Unanswered: New Fuel Injectors
In my build up to a megasquirt controlled fuel injection I came across these fuel injectors and thought that others may be able use them as well. The plan for my project was to use the original phenolic bases with a new style injector and a custom fuel rail. I sent one of the original injectors to Marren's Fuel Injection of CT along with the specs on my 1.9 ltr. They recommended a 24lb/hr injector with a hybrid seal kit that matches the original injector. The pictures show the old barb style injector and the new style. I had them flow matched and the end price was 55.00 each. That seemed good to me after pricing some of the other options out there. Russ at Marren's was a great deal of help and clearly very knowledgeable in this area. Check them out if you need injectors. They also had the fuel rail stock material. On left is the old injector and on the right the new. Thanks for the tip RallyBob!
Part # 0524Y (1) Power Pac Kit matched set of 4, 24lb/hr injector, Hybrid seal kit # 5410731 Marren Fuel Injection - We Service All Your Fuel Injection Needs
I call her Laticia, Costs more than she's worth, but what a set of headlights!
Reason: Think he ment left then right for pictures
