Unanswered: EFI wiring
One wire I need to hook up is called out to be connected to an ignition key 'on' +12 source. My question is what would be a good source location for this? Thanks,Bob |
not to be silly but "the ignition switch"
![]() best to fit an otto start to cut the load down on cranking and then take a feed from ign position 2 this is the wire that feeds all the ign live wires and relays and will shut off when you remove the key but not have a fed if you are running the radio with the engine off ( ign pos 1 )
Thanks Baz,
Not a silly answer, sometimes the most obvious answer is easiest to miss. I was thinking along a different line,perhaps splicing into another location under the hood. Guess Ill do it the correct way, as you suggest.
12 volts
I use the wire for the choke. It supplies 12 volts with ignition on.
Pete
* * * * * * * * * * * * * * Pete Anastopoulos www.anastosmotors.com info@anastosmotors.com * * * * * * * * * * * * * * |
Have you looked here?
ah now we know its a late one with electricary inside
now if I'd known it was an ex electric choke i would have said
