Unanswered: L-Jetronic Help
Can anyone provide a PDF or file on the Jetronic Fuel Injection? I just purchased it with the computer brain and manifold. I am pretty lost as to all the connections, especially to the manifold itself. I saw the PDF on this site for the conversion, thanks that will help, but I was wondering if anyone had the workshop manual or more in-depth literature. Many thanks in advance! Dave M. |
Manual.
What do you need in the way of information. I have several manuals on the L-Jetronic. When you say "manifold" are you referring to the intake or exhaust manifold, you must have the fuel injection exhaust manifold to use the system.
Dave |
Here is a pretty comprehensive explanation and install instructions by Otto Bartsch
1970 Opel GT 1.9 1980 Moto Guzzi V50 2000 Saab 9-3 2.0 turbo 2000 KTM 200 exc STOLEN Last edited by tekenaar; 12-20-2007 at 11:45 AM. |
Connections.
The injectors are connected to the FI control unit and the sensors are color coded on the harness connections. There is not much else to connect except the starter (black w/red stripe), fuel pump (blue), 12V+ battery (red) and 12V switched-ignition (black) connections.
Keep in mind the original 1975 Opel L-Jetronic and the later European LE-Jetronic are quite different in many aspects.
#10 (permalink) | |
Thank you Dave - This is helpful! |
I can't tell from that picture unfortunately, at least not on my screen.
LE Jetronic
Are the tops of the injectors an orange color?
If they are,then its probably an LE.I believe the injector tops on an L system are colored gray or blue? The LE Jetronic was on the 2.0 engines,not made for import to the US |
Certified Opelholic
Real Name: joe blow
looks like the TS (throttle switch is one for a 2.0)
like David said you need a FI exhaust manifold or a header a later starter solenoid is useful (one that has two prongs) is your ECU black is the dual relay one connector or two some useful links http://www.texas912.org/912E%20Tech%...l%20Manual.pdf http://www.fiveomotorsport.com/Injector_CONNECT.asp http://www.atpelectronics.co.uk/Catalogue/vauxhall.htm good luck Davegt27 |
#16 (permalink) | |
Fortunately I have the exhaust header so I'm covered in that direction. The ECU (and I'm assuming that's the control box) is a stainless steel color (if I am speaking of the correct part) Thank you for the links and help. I am learning quite a bit from the great folks here! Dave Last edited by tekenaar; 12-22-2007 at 02:45 PM. Reason: forunately |
#18 (permalink) | |
![]() Connect A to D . . . Connect B to C, not E . . . Connect E with original one-way valve to F! Can't tell you (from pic) where they mounted the dual/control relay for the FI power control . . .
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by kwilford; 12-23-2007 at 05:08 PM. Reason: Added photo just in case the link get broken |
Many Thanks
Do I need the 75" distributor? I have asked Todd M (where I bought the system) - I can't seem to get a quick response.
I have a small metal box (looks like a resistive load - perhaps relay?) Thanks for pointing out the connections - your markup will help immensely, Dave M Last edited by tekenaar; 12-28-2007 at 01:04 PM. |
#20 (permalink) | |
![]() . . . this means it's an L-jetronic like the '75 model, not the LE previously thought. '75 distributor is not an absolute requirement, though nice to have.
