opel-istickly crazy
Unanswered: fuel injecting an opel
That girl with the opel
As Otto said Previously, here's all you need to know about putting fuel injection in a GT:
FI Conversion
#3 (permalink) | |
![]() Post #18 is linked to namba209's linked HTML (mine from 2002), as well!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 06-11-2008 at 04:25 PM. |
Trouble Maker
Real Name: Tony Holcomb
FI is doable, from what I understand it's fairly easy. The parts can get expensive unless you get them all at once either in a lot or from a donor car. Unless you just want to have a FI car, I really can't see swapping to the FI. You could have a lot more headaches there too. I don't know what problems that you're having with your carb but Webers are pretty reliable.
Needs a 2dr Ascona, everyone else has one. Last edited by tekenaar; 06-11-2008 at 04:58 PM. Reason: your - possessive; Webbers? |
Supercharged 2.4
If you are considering EFI I'd say go for it! Just keep in mind that it takes a few more modifications than just bolting it up. You can go with the euro injection or a stand alone EFI system. How much do you have to spend and what are your intended uses of the system/engine? That will largely determine what system you'll want to go with. I am in the process of fitting a 2.4l engine into my GT along with the Motronic fuel injection system using a cut down 3.0l intake since the 2.4l manifold is way too tall. The basic mods to make this work are to add a return line to the fuel tank, install high pressure fuel pump, run new fuel lines, cut hole in passenger side footwell and run the efi through the hole, change the hood latch to fit the efi manifold, and modify the throttle to work with the throttle body. If you have more specific questions we can help you more.
