Unanswered: F.I. problem?
"Yes, I do have a rifle rack in my Sportwagon" Last edited by tekenaar; 09-10-2008 at 04:55 PM. |
Well injectors is a place to check. You likely have another set, so you could have them cleaned and install them. Another thing I would consider is rotor and cap and spark plug wires. After that? I dunno.
TMK |
UFO pel abductee.
Gene, from personal experience, it could be the flow meter rheostat needing cleaning. If you haven't looked at the inside of one, there is a wiper arm traveling across a potentiometer variable resistor on a printed circuit board.
If the circuit board becomes dirty, prying the cover off the flow meter, and cleaning the copper pot surface with contact cleaner or brake cleaner should solve the problem. The cover can then be resealed with clear silicon sealant. Do not be tempted to adjust the arm tension or play with the spring tension of the air flow paddle to make the engine run leaner or richer. You won't really help anything doing that and could cause the pot surface to wear faster.
-Mark '75 Manta Direct link to my album of Opel related parts catalogs and magazine articles for reference: http://www.opelgt.com/photopost/show...ser/23031/sl/a Last edited by Aardvaark; 09-10-2008 at 09:50 AM. |
Efi
Hi Gene
Try a leakage test. Make sure you do not have a burned valve. Pete
* * * * * * * * * * * * * * Pete Anastopoulos www.anastosmotors.com info@anastosmotors.com * * * * * * * * * * * * * * Last edited by tekenaar; 09-10-2008 at 04:56 PM. Reason: burn valve |
I'd check the egr vacuum hose and the fuel pressure regulator and associated vacuum hose.....
Also, I'd get out the Mity-Vac and check the EGR diaphram for leaks.... You may have to remove the egr and clean out the gunk that is inside the metal tube
Paul |
Gene, this sounds like an electrical problem and the absolute first thing I would check is your common L-Jet system grounds - brown wires, one at the lower throttle bracket mounting bolt at the rear of the manifold - not as likely the cause - and a group of ground wires at the FI ECM behind the pass-side kick panel - the most likely place of corrosion build-up, oddly enough, and hardly ever checked!
![]() Proper power is important, proper ground contact even more so!
If you don't have spare injectors and stuff, I have several EFI set-ups here we can rob parts off of if need be.
Opel Addict Since 73
75 Factory Supplement
Gene - I had the same problem with one of my 75 Mantas. There's an inline fuse holder near the fuse box that supplies power to the F/I. I discovered the contacts inside the fuse holder were severely corroded. I cleaned the contacts and the problem went away. I would also concur with Otto regarding good grounding lug connections. They're critical. If all else fails...go to the back of the purple 75 FSM supplement. If you've never used it before...there's a respectable troubleshooting guide there for the F/I.
Scott D. |
#12 (permalink) | |
Portable oh yeah almost will fit in your back pocket. Don't we have a meet coming up? Or Lisa and myself could make a fun run to the other half of Ga. one weekend. Good excuse to put some miles on the GT. |
#13 (permalink) | |
As a follow up to my problem....it has been solved. John Lewis (guyopel) did some quick checking and found the ground strap from the frame to the motor/trans had come loose and that was causing the hard starting after warm up, and the "skip" turned out to be the strap, blowing in the breeze and making contact with the body.
Dan;
Yes we did, but, we fired it right up, this would occur only if the car sat for about 5-10 minutes and it wouldn't start. If I let it sit for 20-30 minutes, it would start right up.
