Old 03-11-2006   #1 (permalink)
OpelGirl
kndlindsey's Avatar
Real Name: Kim
kndlindsey is on a distinguished road
Unanswered: OEM fuel injection on a GT
Can you use the fuel injection parts from a 1975 opel 1900 engine on a gt? And do you need a specific exhaust manifold or will the standard one work?
http://cgi.ebay.com/ebaymotors/1975-...QQcmdZViewItem
kndlindsey is offline
Old 03-11-2006   #2 (permalink)
Provided Answers: 11
you can use just the manifold itself, the rest of the piping is no good for a GT. if you had a Manta or an Ascona, you're good to go
Old 03-11-2006   #3 (permalink)
If you install the Bosch L Jetronic EFI from a '75 Opel in a GT (or earlier Ascona/Manta/Kadett), you either need the "Sprint" manifold that comes with the Opel EFI (as per the eBay listing) or a header. The standard pre-'75 carb'd style exhaust manifold has an open flange that bolts up to the base of the carb inlet manifold to apply heat to its base. Since you don't have a carb'd inlet manifold, you need an exhaust manifold without the opening.
There are several threads that discuss the issues of installing the OEM EFI in a GT on this Forum. It is NOT a simple bolt up, as you need the entire harness and computer, all the relays, the high pressure fuel pump, and a return line to the tank. A '73 GT tank is also recommended, as it has a return port already (for the vapour return line from the '73 fuel filter). There is also some minor modifications required to the bodywork.
Old 03-12-2006   #4 (permalink)
nhopel's Avatar
Real Name: Dennis
nhopel is on a distinguished road
injected GT
I put the euro inj on the mistress as the wife calls it, about 12 hours of fitting , refitting running line changing fuel tank putting in elec fuel pump mounting the ecu and some slight body changes. I got the unit from OTGS it comes with some instruction and alit of photo for the changes.I would not go back to a carb
nhopel is offline
Old 03-12-2006   #5 (permalink)
OpelGirl
kndlindsey's Avatar
Real Name: Kim
thanks for all the input guys, dave was interested in it. i will make sure to have him read all the info from you guys.
Old 03-12-2006   #6 (permalink)
1.9l / 2.0l
Probably better to get a complete 2.0L set-up from OGTS - later model (1979 onwards). There are all sorts of little bits and pieces needed and getting a known, complete system from OGTS is probably cheaper n the long run.
Old 03-13-2006   #7 (permalink)
Arrow '75 FI in a GT
Posted numerous times before . . . '75 FI in a GT.
Old 03-13-2006   #8 (permalink)
OpelGirl
kndlindsey's Avatar
Real Name: Kim
sorry, i usually search exhaustively on things i'm interested in but when it's for Dave i tend to just do a quick ask. Will try to be a better wife and boardmember in the future
