Old 08-22-2007   #1 (permalink)
justhelping is on a distinguished road
Unanswered: LE Jetronics: need help what to do next????
I think this is the right section if not sorry mods. Any ways I have a 73 gt and am in the process of installing the le jetronics. I ran into a wall I cannot get the car to start.
1. checked fuel pressure ok
2. checked spark ok
3. made sure hot and ground are hooked up to le harness
After that i am lost it almost seems like the injectors aint firing. I bought the complete system and followed the instructions the best i could. If there is anyone out there that could help i would be grateful.
thanks jason
justhelping is offline
Old 08-22-2007   #2 (permalink)
Detritus Maximus
Where is the power for your ecu coming from? Does it have a decent ground?
Do you have 12 volts (confirmed, not assumed) going to it?
Can you post a pic of the engine bay and the FI installed?
Do you have a good ground from the motor to the frame/battery?
"No, it's not fiberglass."
opelbits is offline
Old 08-23-2007   #3 (permalink)
The 12 volt supply is coming direct from the battery it is just temp while I am trouble shooting. It is attached to what appears to be a 10 gauge red wire with a pig tail located about half way on the harness. I do have confirmed power to the harness. I do have on plug that is 3 white 1 black 1 black/red this is crewed but it looks like this _-_ The instructions I have said ignore this plug but the pics dont look the same. I have been looking for better instructions on the net but havent found any yet
I will double check the power just to eliminate that also do you know if the relay should click or anything. It does nothing at all I have power to it but makes no noise or movement( I took the cover off to see)
Thanks jason
pics coming soon
Old 08-23-2007   #4 (permalink)
Kalifornia Kid
DennisGardiner's Avatar
The 2.0L LE EFI system is easy to wire up. As simple as the 75 EFI.
Black/Red wire - Key Start on Starter (power only while cranking)
Green wire - Tach signal wire ( coil (-) wire & tachometer wire)
{this is what tells the computer 'when' to fire the injectors}
Black wire - Ignition ON (+12 volts when the key is turned ON)
White or Blue wire - +12 volts to the EFI fuel pump (computer/relay controlled)
Red wire - +12 volts to Battery (power all the time)
Brown wire - Ground (bolts to the bacl of the EFI intake manifold.
DennisGardiner is offline
Old 08-23-2007   #5 (permalink)
thanks to the dennis and opelbits I got the car to run just need to clean everthing up I have wires running everywhere
Thanks again
jason
Old 05-31-2008   #6 (permalink)
BlitzGT's Avatar
BlitzGT is on a distinguished road
If I might ask, where did you get the kit from?
BlitzGT is offline
