Certified Opelholic
Real Name: joe blow
Unanswered: More FI parts in solidworks
I am trying to get the instructor to add inventor but auto desk so i can try it solid works is a very painful program anyway 2.2 intake flange (took 3 days to make ha ha)
Dave,
What material thickness are planning to make this from? Do you have a dimensioned sketch? Even one that has been hand drawn? I can draw it in 2-D in Auto-Cad... or better Yet cut you one on the Water Jet at work... Lemme Know
Paul |
Don't forget that the flange can't have those through-holes for mounting or they will overlap with the exhaust manifold. They need to be half-moon.
Manta Owner
Real Name: Dean Hartje
Useless Graphics
They have just started using it here at my job. It has been a real pain. AND unfortunetly it is just about the only system we can run...
Dean
"Taste Death, Live Life" - "HotDog" - The Movie |
#8 (permalink) | ||
Certified Opelholic
Real Name: joe blow
i finally figured out how to do a drawing (you have to open up a blank drawing and import your part)
the Solidworks works off relations to one another so you cant just go in and change one line I started version "D" this time everything is coming from the dowel pin thanks David |
Certified Opelholic
Real Name: joe blow
Thanks for the info I found solid edge’s web sight but I can't tell too much from it
Well I finally got the drawing right at the end of class on Thursday They have these things called radius gages to find the radius of different items. 1/2" was the biggest they had so I took to using different size sockets One of the young kids in the shop helped me when he measured the size of the socket with some calipers, I was like Doh! The outside diameter of the socket not the size of the socket you dummy (talking to my self) ha ha I am going to use 1/2 inch plate. I only had a few min of class time to upload this image so it’s not so hot ![]() Davegt27 |
Dave, I have a suggestion, but don't know if it is something that you can do with the equipment available to you.
Have you considered making the port openings on your flange angled 'upward' to coincide with the roof of the 2.2/2.4 intake ports? This way instead of having a port that angles upward, then goes horizontal for 1/2", then angles upward again....you have a smooth transition from port to intake runner. I'm also curious if you are going to keep the port shape symmetrical or if you're going to change the upper radii to match the stock head castings (which are asymmetrical from top to bottom). If the radii on the flange are smaller than the OEM port opening shape, then there will be quite a bit of turbulence due to the interference. Bob
#12 (permalink) | ||
Certified Opelholic
Real Name: joe blow
the instructor said to just do a 2D drawing and we can get it cut out pretty easy one of the you kids in the class (the same one that made me see the light on measuring the outside diameter of the socket) jumped up on feature cam and had a 2d drawing done in a 1/2 hour that was pretty close he also did a tool path simulation which was pretty cool
Other then that my drawing matches the gasket almost exactly Let me try to upload a scan Davegt27 |
#13 (permalink) | |
Certified Opelholic
Real Name: joe blow
OK I see
I have a copy of my final drawing and I just laid the 2.2 gasket on top of it The top of the intake port, I made it match the bottom which means I opened up the tops radius a little (it starts out as two radii) The radius I have for the bottom is .406 Ht of the port I have 1.582 I can’t get Photobucket to work so I can’t show you a scan David |
1970-GT
David, looks like your learning alot.
The CNC machining trade can be fun/challenging. What CNC machine are you using? How are you going to generate the G-code program? Have you got a machining plan yet? How are you planning to hold the 1/2" plate? What are you going to machine first? What size end mill? I have a few ideas, but want to see how they/you want to do it. It's a perfect first CNC project to learn on, have fun! Oh, remember to lock out the "Z" axis when testing the program the first time! Lyle |
#16 (permalink) | |||||
Certified Opelholic
Real Name: joe blow
http://www.haascnc.com/VMC_MODEL_HIG...p#VMCTreeModel
I guess I need to drill and tap some holes in the fixture next.
Solidworks is pretty cool but hard and frustrating. I can now see why it cost so much to get things done. I have started work on the throttle body flange and its even harder then the head side David |
But I need 5 of them David, you didn't make enough....
Very cool parts Dave!
#21 (permalink) |
Certified Opelholic
Real Name: joe blow
DCOE flange made in Solidworks
this one was pretty easy compared to the one I been working on for months but I am starting to learn this stuff ![]() now that I am learning I should be able to go back and modify the 2.2 flange to the asymmetrical that Rally Bob mentioned the reason I only made two sets of flanges is that all the aluminum I had next comes matting the 2.2 and other flanges to make some type of manifold the DCOE one is for a friend that wants a DCOE to RB26 TB adapter ha ha but once done I hope to do all kinds of stuff Davegt27 |
