Unanswered: Thoughts on FI and Overlap
how would one offset this problem. is there anything that can be done besides going to an aftermarket computer that could be programmed for a specific application Last edited by kwilford; 02-02-2008 at 08:00 PM. Reason: sp |
#2 (permalink) | |
The ticket is to use a programmable ECU, and if you really want a hot cam, forgo the O2 sensor (you don't want a stoich mixture anyway on a hot engine, it needs to run richer than 14.7:1!), and map via TPS values, and rpm. Bob |
#3 (permalink) | |
admitedly not OK for a street usage but this works. Hiro |
You can have a long duration (>300) cam that opens the valve late and possibly get away with it. ...maybe...
Tinkering is my name..fun is the game Last edited by wrench459; 01-30-2008 at 09:33 PM. |
Certified Opelholic
Real Name: joe blow
I know I tried using another AFM one from a 260z but I took the stock 1.9 AFM circuit card from the Opel and put it in the 260Z AFM Then I tried to manipulate the spring tension This was all done at the drag strip The attempt failed When I adjusted the motor to have a smooth idle it was a dog I then adj the spring so loose that black smoke cam out the tail pipe And the car sounded like it had a big cam (the AFM was bouncing back and forth like Rally Bob said) The car would not rev past 5k on the 1/4 mile So to answer your question it can be done but you need to make the system adj Adding an AFR meter would be a must The stock 1.9 AFM is tiny so that would need to be changed out And ADJ FPR would need to be added Then you would need to have a way to adj when the fuel gets injected (or pulse of fuel gets injected into the motor) On the low end you could maybe hook an ignition timing device in with the ecu to allow you the control that is needed Maybe adapt a SAFC or SAFC II (the older version is better) A'PEXi U.S.A. - Products: Electronics Another option is an AIC or additional injector controller So all kinds of things can be done Going with a stand alone ECU might be the easiest I have a MR2 that failed emissions so I wanted to see if I could get it to pass emissions with out a CAT Well I spent more money then it would of cost had I just went and bought a new CAT But I did learn something and it did pass on the third attempt Davegt27 |
