Distributor w/ Electronic advance for FI conversion
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 46
Thread: Distributor w/ Electronic advance for FI conversion
    Opeler Red0ktober is on a distinguished road
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    I have lots of GM/Isuzu TBI parts on hand, so I'm thinking I'll convert my Kadett to TBI (the carb was rusting in the water-filled trunk when I got the car).
    I understand there are some newer electronic distributors that will drop into the 1.9L CIH. What US market cars would have a compatible ignition system?
    Thanks!
    1970 Opel Kadett Rallye / 1971 Opel GT - Future LeMons Racer
    1990 Isuzu Trooper LS - 3.4L V6 Swap and more
    1999 BMW 328i - 215k miles and going strong
    Project 1450 supporter... Site Supporter My location RallyBob has a spectacular aura about RallyBob has a spectacular aura about RallyBob has a spectacular aura about RallyBob's Avatar
    Pleasant Valley, CT
    9,029
    Bob Legere
    Quote Originally Posted by Red0ktober View Post
    I
    Thanks!
    None, they are all from overseas. 2.0 or 2.2 litre CIH engines from later model Opels. You might try contacting Opel GT Source or Opels Unlimited. They import the entire engines, and usually remove the accessories prior to selling the engines.
    4,000 Post Club My location wrench459 will become famous soon enough wrench459's Avatar
    Jul 2005
    Milner, GA.
    4,093
    Dan
    4
    I have lots of GM/Isuzu TBI parts on hand, so I'm thinking I'll convert my Kadett to TBI ...
    Give us a idea of all the parts that you've got laying around.
    Someone might be able to mix and match parts to make a system.
    I like crank triggers myself.
    Old enough to know better but too young to resist.
    This and that
  5. #4
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    I've worked on several Isuzu Troopers with the GM 2.8L in them, done some engine swaps and I have a parts car. I think I have all the components of a GM TBI system on hand, except a dizzy that will drop into the CIH engine. It's a simple speed-density system, not a lot of sensors.
  6. #5
    Jul 2005
    Milner, GA.
    4,093
    Dan
    4
    Paul
    You've got me curious.
    Are you planning on using the GM pcm?
    This and that
  7. #6
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    Yes, the GM PCM. The Trooper's use a 1228062 which I have worked with most, but I also have a 1227747 which is slightly older but very similar and more widely used, and a 16197427 which is one of the last and most refined TBI ECUs, but uses a different connector so I haven't messed with it.
    For this engine, the Iron Duke code is probably what I'd start with. Those came TBI equipped, not sure what ECU they used, but should be readily available.
    This will require a return line to the fuel tank as with any other injection setup. TBI operates at 12-15PSI. For the race car, I may mount an Isuzu Trooper fuel tank in the trunk, it's already set up with the proper pump/pickup and return, and it has a 21.9 gallon capacity.
  8. #7
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    Google "GM TBI conversion" or "Holley TBI" (same setup) for some more info. It's such a simple and reliable system that it's been retrofitted onto many engines, like the Toyota 2F, Jeeps, and of course older GM V6 and V8s.
  9. #8
    Jul 2005
    Milner, GA.
    4,093
    Dan
    4
    That's what I thought.
    First off the 1227747 pcm is about the most backward engineered thats out there.
    Plenty of info ...and to this day GM has keep the same strategies.
    I went a different route with the injection.
    Used a 1994 T-bird 3.8L pcm (L4J1 code) to run the injectors.
    This and that
  10. #9
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    What did you do with yours?
  11. #10
    Jul 2005
    Milner, GA.
    4,093
    Dan
    4
    Oh my let me see.
    Changed the firing order to 1-3-4-2-1-3-4-2
    Set the ignition type to high data rate DIS
    Had to adjust the MAF backflow maps.
    And several other things....trans type,adaptive fuel and so on
    This is of course with port injection.
    And yes I was RallyBob'd
    Closer look
    This and that
  12. #11
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    I don't know what the normal firing order is, or who rallybob is, but I'll assume that improves it somehow.
    I'm new to these Opel things.
  13. #12
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    Oh, that's RallyBob.
  14. #13
    Jul 2005
    Milner, GA.
    4,093
    Dan
    4
    Ok back to the orginal problem.
    Have you thought about remote mounting the ignition module
    then use two flying magnets to trigger?
    Heres a picture of the pick-up
    This and that
  15. #14
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    Haven't thought about that, no.
    I did convert my Trooper to DIS, but the newer long-block I used was already set up with a crank trigger so no fabrication was needed, just a little wiring.
  16. #15
    Member ghcoe will become famous soon enough ghcoe's Avatar
    Feb 2009
    SW Idaho
    482
    George
    Have you looked into the Megasquirt system? A great system for a F/I conversion because it can be upgraded as you improve the system. You can start with just a simple speed density setup with a MAP sensor. The Megasquirt can be configured to work with just a points ignition.
    MegaSquirt-I EFI System - SMD PCB3.57 w/ Black Case DIYAutoTune.com
    They have a great support forum too.
    www.MSefi.com • Index page
    George
    "Gott schuf Adam, und Adam den Opel"
    -1975 Ascona [mine] http://www.opelgt.com/forums/showthr...ghlight=ascona
    -1974 Manta [sons] http://www.opelgt.com/forums/manta/21191-another-opel-1974-manta.html
    -1967 (early) Kadett Caravan L [wifes] http://www.opelgt.com/forums/showthr...ht=1967+kadett
  17. #16
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    I've looked at Megasquirt a bit, but not had need to use it myself. I've been doing GM injection on GM engines, so I've stayed with the their ECUs.
    I may do a fuel-only configuration, but I figured that if a bolt-on distributor was available, I'd use that.
  18. #17
    Jul 2005
    Milner, GA.
    4,093
    Dan
    4
    I may do a fuel-only configuration...
    Thats what I did ..two separate stand alone systems.
    One for spark timing control (EDIS-Mega-Jolt)
    Then piggy backed the PIP signal to the ECC-IV pcm for fuel control.
    This and that
  19. #18
    Feb 2009
    SW Idaho
    482
    George
    Megasquirt can control ignition too.
    George
    -1974 Manta [sons] http://www.opelgt.com/forums/showthread.php?t=21191
  20. #19
    Jul 2005
    Milner, GA.
    4,093
    Dan
    4
    IMO Bigstuff does it better.
    BigStuff3.com
    This and that
  21. #20
    Dec 2011
    Hood River, OR
    53
    Paul Gerstenberger
    Oh I know MS can do it, but I have this GM stuff just laying around already.
+ Reply to Thread
