Surge Tank for EFI - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Like Tree7Likes
Thread: Surge Tank for EFI
  1. #21
    Jul 2005
    Milner, GA.
    11,220
    Dan
    12
    Quote Originally Posted by Swiftus View Post
    Maybe I'll just compensate for fuel pressure like we do in the race cars. There we are running a returnless system, but it is a very dumb returnless system. All of the fuel pressure regulation happens within the fuel tank itself and then the entire feed line from the tank to the injector is regulated and one way.
    I've played around with variable speed/pressure returnless before.
    Let's just say that they have there own unique problems to work around.
  3. #22
    Opel Intern Swiftus's Avatar
    Aug 2008
    Corvallis, Oregon
    1,189
    Jay Swift
    This system is super simple mechanically and relies on the ECU to do all of the compensations.
    There is a spring-loaded valve which opens at ~350kPa of pressure, creating an outlet and line pressure of ~350kPa. Then at the fuel rail we have a pulsation damper along with a very fast pressure sensor and temperature sensor. Then in the MoTeC ECU we simply compensate for pressure and temperature in the opening time of the fuel injector. Compensation tables FTW.
    wrench459 likes this.
  4. #23
    Senior Member nickincrete's Avatar
    Jan 2009
    greece
    638
    Nick Barry
    Swirl pots compress out the air and force it to exit through the 'up' position in a swirl pot. But I don't know if I am a fan of the return line from the regulator also going to the swirl pot or surge tank. It almost guarantees 3-5psi of backpressure on that line. The backpressure must screw with the fuel pressure regulator on some level, causing irregular fuel pressures. Below is an drawing of the way I am currently thinking of routing a surge tank.
    Here is my tank, it costs about 50 bucks
    As you can see it is vented back to the tank from the top outlet.
    I think that this should prevent the backpressure from building up too much.
    However I see your point and its quite simple to have the fuel manifold return go straight to the tank. I still think, in addition it would be better to have a tank return from the surge tank as well, as in your diagram. The ebay seller I bought this from will put whatever size unions you require and would also omit a union for your set up free of charge
  6. #24
    May 2013
    Sunnyvale, CA
    75
    Patrick
    More EFI questions
    Installing my own EFI system (Megasquirt) and know I need to upgrade the fuel system. I like the idea of a swirl pot for both the simplicity (not messing w/ the tank too much) and the added safety for cornering. While I am not building a race car I do plan to go to a few track days.
    Love this thread but wanted to surface a few of my remaining questions. (1970 Opel GT (manual trans) w/ 2.2L EFI Engine running megasquirt)
    1.Where and how are people mounting everything? I want this to be tucked up for safety and looks. While I am interested in everything I am particularly interested in the location of the surge tank.
    2.What size fuel lines are people running?
    3.What type of fuel lines are people running (ex. solid , braided PTFE, a mix?) ?
  7. #25
    Jan 2016
    Albuquerque, NM
    460
    Joseph Bauer
    Quote Originally Posted by pbboy12 View Post
    I can't comment on the other questions, but for safety I'd do two things. I'd have the surge tank coated with a truck bed liner, anyone who has seen a truck bed liner take an explosion knows the stuff is strong. For mounting safety, I'd consider mounting it near the driver's side footwell / fender. The nose has room, but that is the first area to take a hit in a frontal impact. Mounting it near the driver's side footwell has the most available room. Maybe underneath the support beam that covers the brake pedal push rod?
    ~Joe
    "Autoholism is an incurable addiction medicated daily with car porn." ~Me
    "the sickest of the sick — a car guy who is collecting parts for the restoration of a car he doesn’t even own yet." ~Anonymous
  8. #26
    Jul 2005
    Milner, GA.
    11,220
    Dan
    12
    3/8ths OD supply and return.
  9. #27
    6,697
    Charles Goin
    5
    This is how I did it.
    CURRENT
    '74 Opel Manta - "Barbara"
    '05 Pontiac GTO
    In the past owned:
    '06 Pontiac GTO
    2 Bitters (#491/#439)
    '73 Commodore GS
    '73 Blue Max Manta Luxus
    & at least 20 other Opels
  10. #28
    Jan 2009
    greece
    638
    Nick Barry
    im putting mine on the back of the tyre shelf above the fuel tank.
    1. A Surge of Vibration
      By Conaero in forum Group 4 - Propeller Shaft & Rear Axle
      Last Post: 04-21-2013, 09:31 PM
    2. Cooling system upgrade - custom surge tank
      By RallyBob in forum Performance
      Last Post: 08-01-2010, 09:54 PM
    3. EFI Mods to 73 Fuel Tank
      By markandson in forum Fuel Tank, Lines, Filters and Venting
      Last Post: 09-27-2008, 01:52 PM
    4. Surge Tank for EFI
      By neuropel in forum Fuel Injection Mods
      Last Post: 05-25-2008, 11:37 PM
    5. tank conversion for EFI
      By rlcleeds in forum Fuel Tank, Lines, Filters and Venting
      Last Post: 06-02-2005, 11:06 AM
