+ Reply to Thread
Page 7 of 11
FirstFirst ... 3 4 5 6 7 8 9 10 11 LastLast
Results 121 to 140 of 207
Thread: Megasquirt Kits- Group buy/build??
  1. #121
    Saint Michael, MN
    1,720
    Blog Entries
    fuel rail
    I haven't done all the pricing yet, but SDS does offer a weld-on injector boss for the newer style o-ring injectors that has pipe thread connections on the top so you can just use high pressure flexible tubing. They are a bit pricy, at $37 each, but if you take out the machining costs and the fuel rail material and add in the cheaper injector costs it seems like it would be pretty close.
    http://www.sdsefi.com/ (about 2/3rd down the page)
    I think with a stock plenum all you would have to do is cut a piece of flat steel or aluminum plate, buy the appropriate boss, and do some basic drilling and welding to be able to install "regular" injectors.
  2. #122
    opel free after 26 years baz is on a distinguished road baz's Avatar
    Jun 2002
    sunderland england
    5,072
    bob the jag xjs has the same injector as the 1.9 efi
    as they rust like its going out of style there should be 12 at a time in a junk yard near you with low milage
    B.O.O.B. founding member
  3. #123
    Pleasant Valley, CT
    7,554
    Forgive me, if I am wrong, but I don't think a 1.9 injected motor was ever built. All discussion that I know of on this site is to fit a 2.2 injection manifold etc. onto a 1.9 motor.
    Just to reiterate what Ron and Todd have already said, all the 1975 Opels imported into the USA (Manta, Ascona, and Sportwagon) came with the Bosch L-Jetronic fuel injection as standard equipment. This was also the only year for the 'Sprint' exhaust manifold in the US, as well as the larger front brakes (245 mm instead of 238 mm rotors, and appropriate calipers with larger pads).
  4. #124
    Rice Cooker neuropel is on a distinguished road neuropel's Avatar
    May 2002
    Spring Church, PA
    1,765
    neuropel has made a donation to the forum!
    I have a set of stock 2.4 o-ring injectors, 2.4 injector plates, and 2.4 fuel rail going onto a 1975 Opel EFI 1.9 intake manifold for my 1972 wagon EFI upgrade. Everything bolts right up! But those were the only 2.4 parts I had, so I needed another viable option for injector plates, hence the conversion of the 1.9 injector plates currently under way.
    This is extremely good news since I have a complete 2.4 EFI setup sitting at home and have been wondering what I could do with it! Sounds like I'm all set!!
    PS, did you get the Nissan throttle body yet Todd?
    Yes I did Bob! I thought I had PM'd you but I guess I didn't...been busier than a one-armed wallpaper hanger lately. Thanks again for the throttle body since that is the last critical piece I needed!
    Todd
    -Abraham Lincoln
    ________________
    1972 GT 2.4L
    1974 Manta GT/E 2.2L
    1973 Manta Rallye 2.5L
  5. #125
    Pleasant Valley, CT
    7,554
    Quote Originally Posted by neuropel View Post
    Yup, the stock 2.4 injectors (gray ones) are rated at 192 cc's. Figure on about 153 hp (flywheel) maximum on a naturally aspirated engine before they run out of fuel. Forced induction engines run richer and need more fuel so, the hp limit would be a bit lower with a turbo or supercharger. But, easily upgradeable with aftermarket injectors...
  6. #126
    Senior Contributor markandson is on a distinguished road markandson's Avatar
    Oct 2002
    Kent Lakes, NY
    1,995
    Thanks for the input on the 1.9 EFI engines, I guess I have just never seen one, or if I have I didn't realize what it was.
  7. #127
    Moderator jordan is on a distinguished road jordan's Avatar
    Mar 2003
    corning ny 14830
    2,174
    Would anyone happen to know the real difference between the MS1 pcb2.2 and the pcb3.0? I know what MSII has the ability to control spark as well without the ignition add on, but I can't figure out the difference between the 2 MS1's.
    1970 Opel GT 1.9
    1980 Moto Guzzi V50
    2000 Saab 9-3 2.0 turbo
    2000 KTM 200 exc STOLEN
  8. #128
    Member Hiro Hiro's Avatar
    Mar 2004
    Paris, France, EEC.
    940
    Quote Originally Posted by jordan View Post
    I think MSI/pcb3.0 has the same pcb than MSII,
    but uses the small 68HC908GP32 processor.
    so MSI/pcb3.0 can be easily upgraded to MSII by adding the daughter card processor,
    I think this upgrade was not built-in the pcb2.2 version.
    HTH,
    Hiro
  9. #129
    Mar 2003
    corning ny 14830
    2,174
    I've looked into the options of all 3 versions and of course the MSII seems the nicest and most promising, especially for further expansion. Though if I do tune the ignition curve and I didn't go with a distributorless system (VR, hall, optical) Would I then need to rivit the distributor plates stationary? Would anyone ever want to control ignition through a stand alone ecu and mechanical and or vacuum advance? Should I even use the EFI distributor I bought or just use the early model with vacuum advance and then lock that one up when I actualy tune the ignition curve?
    1970 Opel GT 1.9
    1980 Moto Guzzi V50
  10. #130
    Pleasant Valley, CT
    7,554
    I would just take the distributor out of the equation, and go with a crank trigger and EDIS Ford-based system. Much simpler.
    I have a cut-down distributor just for this purpose, it essentially consists of just the shaft to drive the oil pump and the distributor housing 'flange' to locate it on the timing cover hole. A small cap is welded over the center shaft to prevent oil leaks.
    If, however, you decide to use the distributor as the trigger, then the advance curve must be locked out completely. Weld 'er up!
  11. #131
    Member 1000 Post Club Paul is on a distinguished road
    Ft Smith, Arkansas
    1,489
    What would be your method of choice to mount the crank trigger?
    Paul
  12. #132
    Pleasant Valley, CT
    7,554
    Quote Originally Posted by Paul View Post
    I am having a custom steel crank pulley machined which will have a step in it to center the 36-1 trigger wheel. Then a few simple tack welds and it's done. It will cost about $160 for me to do it this way.
    I could also just weld a trigger wheel to a stock crank pulley, but for racing I want the 'comfort' of a billet pulley for high rpm reliability.
  13. #133
    Member garrymc garrymc's Avatar
    Feb 2003
    Phoenix
    235
    Escort 36-1 ring and Opel pulley
    The Escort ring is about the right size for the Opel pulley. The outside of the pulley has a cleanup cut and the ring has a step machined in it to just barely grap the pulley. Everything was indicated in so it should run good when assembled.
    It will need to be tack welded or bolted to hold it firm. The machine work was only to "jig" it together so it won't runout of round.
    I have not mounted the VR pickup from the Escort yet. I think a bracket between the block and altenator bracket might work.
    Garry
  14. #134
    Mar 2003
    corning ny 14830
    2,174
    Could all of the edis compontents be taken out of a junkyard escort and used? Will the coil pack work?
    1970 Opel GT 1.9
    1980 Moto Guzzi V50
  15. #135
    Pleasant Valley, CT
    7,554
    Yes, you can re-use an Escort's EDIS crank trigger, EDIS module, and coilpack. Just a few mods to make the crank trigger fit the Opel pulley and make a pickup adapter for the timing cover.
  16. #136
    Jun 2002
    sunderland england
    5,072
    if the Ford cogged crank pulley is the same alloy one as we got on the CVH engined sierra(sold in states as the ford merkur) it is no good above 6800 RPM they tend to spread out around the engine bay at high RPM's
  17. #137
    Mar 2003
    corning ny 14830
    2,174
    There are many companys that sell trigger wheels so the ford escort one would not have to be used, I was just thinking of using the escort set up becuase it is a small 4 cylinder, they are easy to find in junk yards, and they are cheap.
    1970 Opel GT 1.9
    1980 Moto Guzzi V50
  18. #138
    Ft Smith, Arkansas
    1,489
    Oh my, that looks interesting.
    Bob/Jordan/Gary, what year model rang Escorts have the stuff we would need?
    Paul
  19. #139
    Pleasant Valley, CT
    7,554
    Paul, this should answer your questions:
    EDIS Ignition Control
    It lists not only the 'how', but also part numbers for aftermarket parts sources, and the years that they were offered as OEM by Ford.
    This company from the UK, Trigger wheels for engine management systems , has many aftermarket trigger wheels in various diameters and configurations. I will likely order a few of the wheels from them for my various projects. With the small diameter racing pulleys I often run, the availability of a smaller diameter trigger wheel is often a necessity. Tough to put a 5.25" 'ring' type trigger wheel on a 3.5" pulley!
  20. #140
    Mar 2003
    corning ny 14830
    2,174
    Bob, do you happen to have any pictures of the VR sensor attached to a timing cover?
    1970 Opel GT 1.9
    1980 Moto Guzzi V50
+ Reply to Thread
Page 7 of 11
