Old 01-16-2006   #1 (permalink)
Opel-GT-72's Avatar
Opel-GT-72 is on a distinguished road
Unanswered: Good place for the 2,2E ECU
Good place for the 2,2E ECU under the Rear board
Opel-GT-72 is offline
Old 01-16-2006   #2 (permalink)
2.2 EFI mounting in GT
What about these:
Ignition ECU and Main Relay:
FI ECU and IAC:
2.2 EFI Hoodlatch mods:
Old 01-16-2006   #3 (permalink)
Certified Opelholic
davegt27's Avatar
Real Name: joe blow
very nice guys
Otto what is that black thing that goes over the valve cover
sorry if the question has been asked before
Davegt27
davegt27 is offline
Old 01-17-2006   #4 (permalink)
Thumbs up Cool injectors
Originally Posted by davegt27
very nice guys
Davegt27
Airway for fan to cool injectors . . . from EFI 280Z.
Old 01-18-2006   #5 (permalink)
Opel-GT-72's Avatar
@tekenaar - how do you cover the co-driver footspace ?
Waht kind of container/tank have you used (front left) for catching the cooling liquid ?
Old 01-18-2006   #6 (permalink)
What kind of container/tank have you used (front left) for catching the cooling liquid ?
Haven't addressed the cover in the footwell yet. Will probably modify junkyard plastic cover from another car to fit.
Have used various containers from different Jap cars over the years . . . whatever I could find at the time and would fit where I wanted to locate it.
Old 01-24-2006   #7 (permalink)
Opel-GT-72's Avatar
That´s how it looks finished ....
http://www.sh.opelGT.org
Old 02-04-2006   #8 (permalink)
Certified Opelholic
davegt27's Avatar
Real Name: joe blow
Nice clean Job looks good
question
i see the ECU and the dual relay whats the other black box?
also does the 2.2 use a O2 sensor?
thanks
Davegt27
davegt27 is offline
Old 02-04-2006   #9 (permalink)
question
thanks
Davegt27
1. Idle Air Control (IAC) unit, regulates idle speed electronicly based on engine sensors.
2. No, this was last iteration Bosch LE EFI prior to 'dynamic/O2 feedback (Lambda)' mixture optimization in EFI, LH and Motronic, which also use a MAF air flow sensor (Luftheizung) instead of the 'vane' type (Luftmengen) in the L/LE EFIs.
Old 02-04-2006   #10 (permalink)
Certified Opelholic
davegt27's Avatar
Real Name: joe blow
thanks
davegt27
davegt27 is offline
Old 02-04-2006   #11 (permalink)
opelnut10's Avatar
2.2e Ecu
Just a tip, Otto before you cover the stuff up with a kick panel make sure the radio antenna is sealed good at the fender. Otherwise water will get under and run down the antenna lead. Where the lead makes it's bend is right over your ECU and it will drip water onto it (bad news) ECU does not like taking a bath.
opelnut10 is offline
Old 02-05-2006   #12 (permalink)
spdkilz02's Avatar
spdkilz02
thats a real good tip, even if otto has already thought of that...it will help someone else who is thinking of locating the ecu in the same place...
Adam
spdkilz02 is offline
Old 02-05-2006   #13 (permalink)
Well, now it appears that I am missing the IAC Unit for the 2.2 setup that I got off of my engine. So...does anyone out there have one? I also do not have the dual relay, but figured I could take care of that.
Old 02-06-2006   #14 (permalink)
Are you sure it's not merely a 2.0 LE FI? The 2.2 FI main relay is much more than just the dual relay as used in the 1.9/2.0 L/LE FIs, it also has an input from the distributor ignition trigger used in idle speed control. See #4, the 'relay', and #7, the ignition trigger source, in the wiring diagram below. This is representative of the 2.2 EFI system.
Old 02-06-2006   #15 (permalink)
tomking's Avatar
I wonder what happened to Arnold Smith who retired from the Army and moved to Germany? He was going to hunt for IACs for us. Bmetsoldier where are you??
TMK
tomking is offline
Old 02-06-2006   #16 (permalink)
Both Tom King and I have 2.2 engines, I got mine from Tom. They both came without several of the EFI parts. We are both in need of the IAC and the Dual Relay.
Old 02-06-2006   #17 (permalink)
Otto,
Can you tell us what the Bosch part number is on the IAC box?
Old 02-10-2006   #18 (permalink)
Certified Opelholic
davegt27's Avatar
Real Name: joe blow
The dual relay is the same one from a Renault alliance FI 1.7,2.0 around 1987 time frame
Sorry it’s been a long time so I am not sure
they where kind of expensive so when I got my 2.0 FI setup from Gil and saw a weird electrical relay
Right away I went looking for a replacement in case mine went bad
Its not to big of a deal the special relay just primes the fuel pump for a few seconds when you turn the key on
So you could wire in your system with a regular relay if you wanted to
HTHs
Davegt27
davegt27 is offline
Old 02-10-2006   #19 (permalink)
'NO,......O P E L..G T!'
Motor Mouth's Avatar
Motor Mouth is on a distinguished road
Nice looking job.
Just an idea worth considering......I mounted my ECU under the glovebox, no worries about water that way and it's also hidden when you look in the footwell.
BTW....don't ask for a picture, the beastie currently has 101 boxes on top of her as she's been blocked in the garage all winter due to Fredopelgt's GT being parked in front of her.
Mark
I used to have an Opel....now i have a collection
69 GT 2.5 FI, Getrag, Irmscher Big Brakes, LSD, Lowered, 8" & 8.5" BBS RM's, Leather.....ex Dealer Opel Team
70 GT 1.9 Weber, 4 Speed
70 GT 1.9 Twin Weber, 4 Speed, Alloys
71 GT 2.0 Weber, Getrag, Lenk Styling, Alloys
71 GT 3.5 V8 Holley, RHD, TARGA, Leather Recaros
75 Commodore GS Coupe, 2.5 Twin Carb, Auto
76 Commodore GS/E Coupe, 2.8 FI, Auto, Alloys, LSD, Sunroof
Motor Mouth is offline
Old 02-10-2006   #20 (permalink)
fredopelgt's Avatar
fredopelgt is on a distinguished road
Thumbs up
"BTW....don't ask for a picture, the beastie currently has 101 boxes on top of her as she's been blocked in the garage all winter due to Derfgt's (aka fredopelgt) GT being parked in front of her."
However, back in the Fatherland now and tucked up in the garage. After a great drive over with miles of smiles. Will have to ask Motormouth what his Race Engineer did to the the 2nd barrel, kicks you in the back and goes like a rocket.
It's only money that keeps your GT flying.
fredopelgt is offline
