Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 6 - Engine > 6C - Fuel System > Fuel Pumps
Old 05-14-2006   #1 (permalink)
poffenroth's Avatar
poffenroth
Unanswered: Fuel Pump Bolt Length?
I am putting the fuel pump back into my GT and replacing the spacer that the PO had removed (or left out or whatever...).
However, it appears that the PO has cut the bolts down (!!!) to make them seat properly. Does anyone have the length of these bolts handy?
Thanks!
Trev
The gene pool could use a little chlorine...
poffenroth is offline
Old 05-14-2006   #2 (permalink)
Trevor,
Thread a longish bolt into that the mounting holes in the chain case to see how deep the threads are. Then measure the thickness of the spacer and pump base. Add the two, subtract about 1/4", and use that length. IIRC, it's about 3/4 to 7/8".
Old 05-14-2006   #3 (permalink)
poffenroth's Avatar
poffenroth
Thanks Keith - good idea!
I am second guessing myself now...
Are anyone elses fuel pump bolts hardened? Mine are an 8.8 and NOW I am wondering if they are even the original bolts...
Old 05-14-2006   #4 (permalink)
Umm, we could probably do this by phone or even in person and not bother the members...
"Standard" metric bolts are Gr. 8.8, about equivalent to an SAE Grade 5. Hardened Metric are Grade 10.9, approximately an SAE Grade 8. And some are Gr. 12.9 (Bearing cap bolts etc), and I don't know what the SAE equivalent is.
For fun and educations, Google it or go to
http://www.boltdepot.com/fastener-in...ade-Chart.aspx
or
http://www.zerofast.com/markings.htm
Old 05-14-2006   #5 (permalink)
poffenroth's Avatar
poffenroth
Learn something new every day. I was thinking the 8.8 was hardened, not regular. Bolts bought and fuel pump installed. That top bolt is a bit of a crank to get started with the alternator still in!
Tank is next... hopefully this week.
Old 05-15-2006   #6 (permalink)
8.8 = Grade 5
8.8 and Grade 5 bolts are 'medium tensile' heat treated carbon steel. Ungraded SAE bolts 'ordinary'?? are made from mild steel and Metric does not have a direct equivalent.
BTW: Found the listing for the fuel pump bolts
68-74 ALL 2018114 2off Screw, fuel pump on timing hsg. (M8 X 25)
Old 05-15-2006   #7 (permalink)
poffenroth's Avatar
poffenroth
Thanks Jim!
Trev
Old 05-16-2006   #8 (permalink)
duvel's Avatar
duvel is on a distinguished road
It gives me again something to think about ; I have no spacer installed .
I'm going to order one immediate
duvel is offline
