'77 Manta B - yellow
Unanswered: electric fuel pump+carburettor issue
I registered in OC Forums for some time, I already contacted in private Rally Bob for some advices (and I am very pleased of his answers), but this is my first post. I have a 1977 Manta B, 1.9l engine which was on injection. The former owner, not being able to start it on injection one day and not being able to find someone skilled to help him here, in Romania (Europe), switched the injection to carburetor, keeping the electric fuel pump. I own this Manta since january 1995. It was not in a very good state. I made some investments in bodywork, removing the rust and painting, rebuilding the engine. All this being finished 2 weeks ago (my finances weren't so great, so my progress was quite slow) I started to run the engine and enjoy it... Well, there is something which ruins my good time. With the Solex 32/35 carburetor and electric pump, with an uncalibrated 'T' pipe for fuel, I experience too much fuel on idle and not enough on high torque. Please help me solve this, any advice is great. I try to switch back on the injection system, but parts and skilled people are hard to find; since then, I wish to find a decent solution to run on carburettor. Thank you in advance. Last edited by tekenaar; 11-14-2006 at 02:06 PM. |
#2 (permalink) | |
Fuel pump problem
#3 (permalink) | |
And my question is... is there any decent solution to make things work in this combination? A mechanical fuel pump deliveres the same quantity of fuel multiplied with the engine rpm; is there any decent solution to make things behave the same with this electrical fuel pump? I still have the fuel pressure regulator from the injection system (driven by vacuum), but it is not an ajustable one, it's encapsulated. Keep in mind that I can't install a mechanical fuel pump, there is no hole provided in the engine cap where it shall be mounted. Last edited by emircea; 09-18-2006 at 09:45 AM. |
There are many low pressure electric fuel pumps available for 12 volt operation, at least here in the USA. These pumps produce pressures of about 5-6 psi, and have ample fuel flow volume for a stock 1.9L Opel engine. Some of the manufacturers here are Holley and Facet. I assume that you can get equivalent parts in Europe.
Also, you can buy an in-line low pressure regulator that allows you to adjust the pressure at the carburetor in the range of 2-5 psi. We have run these types of fuel pumps on various race cars with carburetors from the stock 32 mm Solex to large 2 barrel 500 cfm Holley carbs to twin weber carbs, all with good results. Regards, Mark B. |
emircea ,any low pressure electric fuel pump from a car with a carb will work
i dont know what will be avalable in a junk yard near you but if it has a carb it will work do you get many west european/japanese cars there from mid 80's on ? there might be something i could say to look at if i knew
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 10-03-2006 at 04:41 PM. Reason: no regulator emphasis |
#8 (permalink) | |
Regards, Mark B. Last edited by tekenaar; 11-14-2006 at 02:09 PM. |
#9 (permalink) | |
Try this link: http://www2.cip1.com/ProductDetails....e=ACC-C10-5622 You can see both pumps and regulators. OTTO gives avery good solution; maybe he knows where to get this pump an at what price. EDIT: Summit Racing for about $58. Regards, Mark B. Last edited by Manta Rallier; 09-18-2006 at 07:23 PM. |
I have actually used the stock EFI pump on a carb'd engine. I just used a Mallory pressure regulator (return-style), and set the pressure at 5 psi for use with a Holley carb. It has worked fine for 4+ years so far. Of course, that particular regulator is $85, not $20.
Bob |
Thank you, guys!
One more thing, please... tekenaar posted a picture with an electric safety switch. How does this work? When there is no oil pressure, stops the pump or what? Thank you once again. When it's ready, I'll let you know what solution I succeded to apply (depending on the parts available). |
#12 (permalink) | |
The third terminal on the safety switch would normally be used for a low oil pressure warning light, but is probably not used in this application, since the Opel already has a warning light. |
Thank you, SpringGT.
<<The third terminal on the safety switch would normally be used for a low oil pressure warning light, but is probably not used in this application, since the Opel already has a warning light.>> - a good idea, with a relay, when the low pressure warning light is on, the normally closed contact on the relay is disconnected and the pump is off. Such a relay costs 2$ in my city. I still have to find an electric pump or a pressure regulator - I'll keep you guys in touch with the solution. Thank you all! |
#14 (permalink) | |
EFP safety switch wiring
#15 (permalink) | |
EFP safety switch wiring details
#16 (permalink) | |
ustaGT
And speaking of safety when mounting fuel pumps, if you have a Manta A or Ascona A, I would be mounting an external electric pump either in the axle tunnel in front of the tank and on the driver's side (away from the exhaust). Or on the left (driver's side) subframe rail in the engine compartment, behind the suspension. This would be to keep it somewhat protected in a crash.
Make sure the rear axle or associated parts like the anti-sway bar or panhard rod cannot get close to the pump if in the rear. One possible issue with the front subframe rail location is getting a good prime to the pump with it being higher than the fuel tank AND after 10 feet of tubing. (As a point of reference, we have never had an electric pump priming problem with various pumps mounted above the tank in the trunk in rally cars. But I never put one in front so can't tell if this is an issue.) Regards, Mark B. Last edited by tekenaar; 09-20-2006 at 02:01 PM. Reason: havae - Jidish have? ;-) |
can this be useful?
Hello,
I started searching the e-bay and I found the attached item. Can this be helpful? I think it's the pressure regulator for the injection fuel circuit... Anyway, I keep searching... |
This is definitely an FI!!! regulator, which CANNOT be adjusted to regulate at a low enough pressure for a carb, ~3.5PSI max!
#21 (permalink) |
D-Jetronic FI regulator
Wanted to add, pic looks like one from a D-Jetronic FI (mostly early VWs), not an L- or LE-Jetronic like used on Opels.
#22 (permalink) |
pressure regulator
Hello;
I finally ordered and received today the #4309 Mallory pressure regulator. I think I expected much more from Mallory about finishings, but I found some metallic debris in it which I cleaned... What I'm interested in is how can I tune this regulator without a pressure gauge - is it possible? Thank you in advance. |
#23 (permalink) |
pressure regulator
Last night (between 10 PM and 01 AM) I fitted the regulator, trying to make some tune-up to the engine.
I found a position on the regulator where clearly the carburetor is not flooded and the engine was constantly fed with fuel upon demands. Unfortunately, the pressure regulator was sent without fittings and with the ones I found locally (4$ for the whole set) I had to use teflon tape for sealing. I will post some pictures later... Is this teflon tape ok for use with gasoline or do you recommend a different product? Thank you in advance. |
#24 (permalink) |
Teflon tape will work just fine on your fuel fittings. I used it on the high pressure fuel fittings on Willit?'s SFI system and have no leaks at all. HTH.
#25 (permalink) |
finally
Finally!
In the picture you can see it fitted. Teflon tape did the sealing. Inside the .zip, you can see a little mouvie with my beauty running... Enjoy! Too bad I can't share the little mouvies I've made... |
