Looking thru the threads I can't find an answer to my question:What is the best place for an electric fuel pump so that it's easy serviceable and doesn't get to dirty? What about the filter what's the best place for that??
best place for electric fuel pump
The ideal spot is up to you, but it should be under the car and close to the fuel tank. The pump will push more fuel than it will pull and therefore you can use a smaller pump than mounting it in the engine compartment and the fuel will stay cooler, which is a good thing. Filter placement is also a matter of putting it where you can get to it for service and you need two, one between the tank and the pump and one between the pump and carb. if you are going to put the second filter under the hood, also place it where it can be serviced and away from heat.
Detritus Maximus
I made a mounting plate and used the rear swaybar mounting holes in the body to bolt to.
Here's a good place to start. HTH, Jarrell
http://www.opelgt.com/forums/showpos...3&postcount=14
opopelnut10:
The ideal spot is up to you, but it should be under the car and close to the fuel tank. The pump will push more fuel than it will pull and therefore you can use a smaller pump than mounting it in the engine compartment and the fuel will stay cooler, which is a good thing. Filter placement is also a matter of putting it where you can get to it for service and you need two, one between the tank and the pump and one between the pump and carb. if you are going to put the second filter under the hood, also place it where it can be serviced and away from heat. opelbits: I made a mounting plate and used the rear swaybar mounting holes in the body to bolt to. Do you have some kind of shield to protect the pump and the electric contacts form street dirt or what?
Detritus Maximus
You know, I don't remember. Regardless, it's a good idea. Depending on the pump type you have, square Facet or rotary vane, there are quite a few cars that can supply a nifty shield. Look for 70's-80's era european FI cars with a rear underbody mounted fuel pump. Alfa, VW (Type 3), Volvo, Opel that have a cylindrical pump may suppy a shield for the rotary vane type pump. Of course, those cars may also supply a nice rubber-isolated mounting bracket to modify, too. Or you could make your own out of sheetmetal.
A sheetmetal shop (HVAC ductwork) could bend up a nice little shield for the Facet type pump. I find those shops like doing interesting odd-ball jobs, plus they are cheap compared to a real panel-beater or autobody shop. Just make sure you have a nice cardboard template for them to follow. Allow for drain holes, no water/crud traps, and make sure the shield covers the pump in such a way that anything you run over won't go between the shield and pump. Sounds harder than it actually is. The wiring should be covered. I ran both wires through the floor (found a convenient hole) with a rubber grommet. My 12v+ wire is inside the car with a covered (insulated) terminal. The ground lead also has a covered terminal. This does two things, one it allows quick disconnection, and two, if either wire comes loose, it doesn't short to the body. Running the wires inside keeps the terminals from the elements and I can maintain a more consistent ground inside. Something probably should have added in the first post, I could use the swaybar holes because I do not have a swaybar on the back of the GT. If you have a swaybar, engineer this carefully.
"No, it's not fiberglass." "No, the motor is not in the back." "No, your friend in high school did not 'peg' his speedometer." Last edited by opelbits; 02-05-2006 at 02:45 PM. |
#8 (permalink) | |
Bob |
Thank you all for your input now I can draw up a plan for my FI E-pump fitting
I forgot that you have an Ascona. On the 75 Mantas, I believe it was mounted to the passenger side of the car up next to the tank. RallyBobs idea seems to be the best though, and Opelbits idea about a shield, and the disconnects are definately a good idea. Jarrell
Erick, just to be sure we're on the same page, a fuel pump for a carbed engine will have a much lower pressure than one for fuel injected engines. Hopefully you have or will purchase one of correct pressure and don't forget about the return line from the injector rail back to the fuel tank. HTH.
#12 (permalink) | |
