Unanswered: Fuel Pump installation
Ready to start my GT for first time after engine swap... this is all I need solved... I hope. THanks,
Mark 70 GT, Rebuilt 1.9L; ported, performance Cam , Weber 32/36, Pertronix, ported and torquered intake manifold, Sprint Exhaust manifold |
Spacer!
There should be an 1/4" (..well 6mm ...) thick insulating spacer where the pump mounts with a gasket each side - got one?
Also turn the motor over till the fuel pump activating cam on the bottom of the distributor shaft is 'IN' not 'OUT'.
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 05-07-2006 at 01:28 PM. |
Thanks, Jim. I do not have the gaskets, so I guess an order from OGTS is in need. I DO have the Spacer though!!
I stripped one of the mounting holes, so I am now needing to heli-coil that hole... Getting closer and then farther...
Detritus Maximus
That's the wrong attitude! The Heli-coil is stronger than the original threads in the aluminum. Put that in the 'high performance modification' column!
The next thing on the 'high performance modification' to-do list is to safety wire all the little nuts and bolts in the headlight rotators....
it just needs to be marked with a pen and cutout with a craft knife on some woodi've even made them from cornflake boxes at a pinch and used them for years
long time Opeler
You can also make gaskets from Brown paper shopping bags. From your local grocery store.
Or from a shoe box if it has to be thicker!!
