Old 07-03-2006   #1 (permalink)
hustlerzlife's Avatar
hustlerzlife is on a distinguished road
Unanswered: Seal Material Around Sensor
What should I use to seal off my fuel sensor on the top of the tank? It was originally covered with some black rubbery stuff. Silicon perhaps?
-Conrad (1971 GT)
hustlerzlife is offline
Old 07-03-2006   #2 (permalink)
jtb
jtb's Avatar
I thought it was cork with rubber. You can buy this by the sheet from an autoparts store if you can't find the gasket.
jtb
jtb is offline
Old 07-03-2006   #3 (permalink)
kent's Avatar
opelgtsource sells these gaskets. They are made of cork.
kent is offline
Old 07-03-2006   #4 (permalink)
Not the gasket, I was planning on using some cork/rubber material for that. I was talking about the goop of rubber that sealed the top of the sensor unit. Is it just not nessicary?
-Conrad (1971 GT)
Old 07-03-2006   #5 (permalink)
jtb
jtb's Avatar
I don't recall any rubbery goop on top of my sensor when I took it out. Perhaps it was some seam sealer or undercoating or something that got on there inadvertently?
If you have the cork gasket in good condition, there shouldn't be anything else required to make a good seal.
jtb
jtb is offline
Old 07-03-2006   #6 (permalink)
soybean's Avatar
It could have also been covered with "Liquid Rubber" to keep it from corroding.
Just a thought. Jarrell
soybean is offline
