Unanswered: new gas tank filler gasket: 5 min job
You dont need to disconnect the filler tube to put in a new gasket at the body exit point. step1: plug gas tank hole with a rag,cut out old gasket with razor knife step2: boil a cup of water,add gasket,add dish soap to cup. I used gloves to avoid a burn with the hot water. step3: slip it on over the top. the heat and soapy water makes the gasket so pliable, you you just work it around and in 1 min,you got it. real easy, my type of project, that ungrades that old cracked gasket. Thanks Gene
new gasket
Some folks take the easy way out.
Of course I had the tank out and all the shelving. But I did have a new gasket from OGTS and used some "Petrolatum, Technical", commercial "Vaseline", and it just slid in the hole, and the filler neck did too.
