Old 03-21-2007   #1 (permalink)
Real Name: Matt
matl59
Unanswered: removing a locked gas cap without a key
So I realized a simple trick to removing a locked gas cap from the filler neck without a key this morning. Thought I'd post it because I've heard people ask before but I've never come across this in any post...I couldn't actually find any of those posts when I did a quick search though. (mods feel free to move this post to one of them if you can find one and feel compelled)
A little background, I've had some trouble with water getting in my gas cap and freezing. Up until today it seamed to always happen to the lock mechanism itself not allowing the key to go all the way in and up until now this phenomenon only happened after I unlocked it.
Well, this morning when I went to remove it the lock mechanism was already frozen and I wasn't able to put the key all the way in. I quickly realized that the whole cap was frozen this time. I just turned it right off the filler neck like it was unlocked. Put it right back on when I was done with no problem. Checked it again a little later that day to make sure I wasn't crazy and had actually left it unlocked. Sure enough, it spun freely.
So, long story short if you find yourself with a gas cap stuck on a filler neck without a key, drench the cap, freeze it, and spin it off like its unlocked
Guess my locked cap isn't as secure as I thought.
matl59 is offline
Old 03-21-2007   #2 (permalink)
West Coast GT's Avatar
West Coast GT
That's a good tip. Thank you.
West Coast GT is offline
Old 03-22-2007   #3 (permalink)
OpelJim's Avatar
OpelJim
Hard to fit a Gt in my frezer
For us San Diegians that would be a neat trick
OpelJim is offline
Old 03-22-2007   #4 (permalink)
What I did to stop my cap from freezing and being unable to get the key in all the way was to remove it and spray carb/brake cleaner into the cylinder while holding it upside down. You hopely flush all moisture and any grit that might be in it out. I let it drain and dry for some time and then added a lube designed for key cylinders. I didn't have that problem again until my significant other forgot to close the cover a few days later and it got rained on and I had to go through the process again. Gotta love 'em.
hrcollinsjr is online now
Old 03-22-2007   #5 (permalink)
jlthunder's Avatar
Liquid Nitrogen or Dry Ice may work for you guys
1973 GT, Parted out, R.I.P.
jlthunder is offline
Old 03-22-2007   #6 (permalink)
Real Name: Matt
matl59
I haven't had a chance to let it dry thoroughly. I've sprayed some WD-40 into it a couple times but still freezes up went its really cold... its only a minor annoyance. The door locks are even more fun on really cold days.
What I really need is a garage to park in at night...
matl59 is offline
Old 03-23-2007   #7 (permalink)
David12345 is on a distinguished road
Explain..
Could someone explain why freezing the cap would allow it to be removed without a key .. I don't see the picture.
David12345 is offline
Old 03-23-2007   #8 (permalink)
if the whole unit, especially the inside were frozen, it would become one solid unit, and able to turn. Like if your door handle freezes and you can't get the key in or if you do, it won't turn, or you can't press the button to open the door
Old 03-23-2007   #9 (permalink)
Love Opel ...
The gas cap on a GT is actually 'unlocked' when it spins freely - and the two parts 'locked' together so it can be taken off.
Thus - when the two bits are frozen together ... the cap can be taken off!
BTW - some water dribbled down the key-hole and a blast (or two!) from a CO2 fire extinguisher should do the job.
Oh! .. and use a thick glove when removing the frozen cap - or you will stick to it.
Old 03-26-2007   #10 (permalink)
jlthunder's Avatar
Like a tongue to a cold flagpole
Old 08-08-2009   #11 (permalink)
teppy is on a distinguished road
Try drilling a hole on an angle from the cap center where it is in the filler neck. Then insert a nail into same hole allowing you to remove the cap. If it still doesn't work, try this one: Removing a fuel tank cap.
teppy is offline
Old 08-08-2009   #12 (permalink)
opelspyder's Avatar
Does not apply
Teppy,
your above post would not apply to a GT gas cap. If you drill it, you destroyed it. I don't like putting nails into anything other than wood. Your link is concerning new gas caps. The GT has a large chrome locking gas cap.
And they can be a pain sometimes when they are in the locked position getting off. Please though, do not use a drill!!!!! You may be able to snake out the filler neck on certain year models. Some have a guard that prevents this
Keith
opelspyder is offline
Old 08-08-2009   #13 (permalink)
Real Name: Karl Senula
opelgtboy70
For the San Diegoans, take the neck off and put it in the freezer
Karl
opelgtboy70 is offline
