Ascona Fuel Sender Micro-Surgery - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
Thread: Ascona Fuel Sender Micro-Surgery
  1. #41
    Aug 2002
    SW Missouri
    2,266
    I just soldered on an old carburetor float to replace my bad brass float.
    TMK
  3. #42
    UFOpel Investigator Site Supporter My location Aardvaark (R.I.P.)'s Avatar
    Aug 2007
    Des Moines, Iowa
    3,475
    Mark
    Quote Originally Posted by tomking View Post
    I just soldered on an old carburator float to replace my bad brass float.
    I'm wondering how the various sender floats are attached on Opels from the factory. I know how the '75 cork float is attached. Never got into my '73 Manta's. Dr. Manta shows a new sender asm. for carb engines. But it's cork like the '75's.
    -Mark
    '75 Manta
    Having invested my life savings into
    this Opel Manta. I expect big returns.😅
    Link to my album of Opel catalogs
    and magazine articles:
  4. #43
    Plano, TX 75074
    5,299
    Otto
    ExclamationM.A.K. floats
    Quote Originally Posted by Aardvaark View Post
    If memory serves, believe they're attached like the '75 models . . .
  6. #44
    Moderator Site Supporter neuropel's Avatar
    May 2002
    Pottstown, PA
    2,410
    Todd Kirby
    I removed the sender from my Manta's tank today and my problem is definitely the cork float. It's completely saturated, and pretty much fell apart in my fingers when I tried removing it from the float arm. A quick check of the sender showed that everything is working fine. It reads full scale, so if I can replace the float I should be all set.
    I've called EVERY autoparts store around to see if I can find that 1/8" gasket Otto mentioned, and NO ONE carries it (it's far cheaper to call ahead than drive these days). I can only get the 1/16" stuff, so I guess I'll make two and seal them together.
    Todd
    Paddle faster...I hear banjo music!
    ________________
    1972 GT 2.4L
    1974 Manta GT/E 2.0 LHU
    1973 Manta Rallye 2.5L
    1967 Kadett L Rallye 1.1L
  7. #45
    Spofford, NH
    12,475
    Bob Legere
    Quote Originally Posted by neuropel View Post
    Todd
    Todd, I have some gasket material (McMaster-Carr to the rescue!). I just made a sender gasket last week for a '75 fuel tank. It's .090" thick I believe, and it is cork with rubber so it's good for fuel.
  8. #46
    May 2002
    Pottstown, PA
    2,410
    Todd Kirby
    Well, just back home after spending the late afternoon/evening trying to get a cork and the right gasket material. Struck out at every turn! No luck finding the cork for a float (shop that has it closes early on Sat and Sun, but I'm 90% sure I can get it tomorrow). Also still no luck finding the 1/8" gasket, so I picked up a sheet of 1/16" cork rubber and hopefully that'll work. The only problem with McMaster Carr for me is that I need this stuff yesterday. I'm not at home through the week, so I have Saturdays and Sunday mornings. To be honest, this is just a short term fix anyway as the tank will be coming out when I switch over to EFI.
    On another note, I did some quick calculations based on the last time I filled up the tank, minus what I drained out today, and determined the car is getting REALLY crappy fuel mileage (It's been difficult to tell without a fuel gauge). It's running ok, but the dreadful mileage (along with the gas fumes that hit me in the face every time I walk into my garage after I park it) tells me I must be running way too rich. Hopefully I'll have time to change plugs and at least lean it out a bit prior to Carlisle.
    Todd
    ________________
    1972 GT 2.4L
  9. #47
    Aug 2007
    Des Moines, Iowa
    3,475
    Mark
    NAPA carries the FelPro cork/rubber 1/8 gasket sheets in 18x36" but
    it's about $25 so I passed on it and went with stacking two 1/16" thick
    ones. Like I posted earlier, I'd advise not putting the 5 small screw holes
    in the gasket(s) ahead of time, but just allowing the self tapping sheet metal screws Opel used to make the holes in the gaskets at assembly so the threads seal properly as they are not blind thread holes in the tank. Mine has not leaked in four days with a full tank.
    NAPAONLINE®
    See PN/FPG3007.
    Also, the original cork float has sat on the work bench for four days
    now, and now only weighs about 1/10th what it did when removed after
    the gas has evaporated out of it. After 30plus years it was pretty much
    a sponge. I didn't coat my new cork with anything, but if it doesn't
    hold, might coat the next one with Permatex No.1 which hardens.
    -Mark
    '75 Manta
  10. #48
    Opeler My location dcm013's Avatar
    Aug 2002
    Troy, MI
    643
    Don McLean
    Mark, can you tell me the approx. dimensions of the cork? I'd like to have one on hand before I drop the tank.
    Thanks,
    Don
  11. #49
    May 2002
    Pottstown, PA
    2,410
    Todd Kirby
    I just replaced mine today with a cork that was 1.75" tapering to 1.5". It's a little bigger than stock, but it's working great so far. First time I've seen a full tank register in my car! In an earlier post in this thread Mark mentioned that he used a cork 1 7/16" tapering to 1 3/16". I really don't think it's all that critical as long as you get one close in size that will float in the fuel to give the arm full movement.
    A quick and easy fix for a common problem!
    Todd K.
    ________________
    1972 GT 2.4L
  12. #50
    Aug 2007
    Des Moines, Iowa
    3,475
    Mark
    Todd K.
    That's my take too. Just get a cork that is close. Most hardware stores and home improvement "big box" stores sell them in various sizes in the fasteners
    section along with springs, o-rings, bushings, c-clips and other small items.
    They sell solid rubber stoppers for bottles too, but I don't know how well they
    would float or hold up in gas. Btw. bottle stopper corks are sold by an industry sizing . That original cork Opel used is 1-3/8" dia x 1-1/2" long. If the cork you buy is long, it can be trimmed and the small center hole added.
    -Mark
    '75 Manta
  13. #51
    Opeler My location Gary Sullivan's Avatar
    Staten Island, NY
    228
    Testing voltage stabilizer?
    I know you guys were talking about testing instrument gauge voltage stabilizers a while back on this thread. I am not finding any answer as to how to do that. Any simple test for those? Thanks
    NYAsconaGuy
  14. #52
    OPEL PARTS GREECE alpharm's Avatar
    Apr 2005
    GREECE
    207
    Quote Originally Posted by Gary Sullivan View Post
    Push the gas pedal and you will see your fuel tank gas ''filling up''
    E-mail: alpharm@otenet.gr
    Online: (MSN users-Windows Live Messenger): Opelparts@hotmail.com
    Skype: Opelparts
  15. #53
    Opeler FReis's Avatar
    Nov 2016
    Porto, Portugal
    90
    Fernando
    Hi,
    My Ascona's sensor is not completely dead, but it's very inaccurate.
    I was thinking of removing it and try some tips that I saw in this thread, but if it is irrecoverable there will be chance to find a new one?
    When removing it is supposed to replace the gasket, is it necessary to use an additional sealant or just the gasket will be enough?
    Thanks in advance
    Fernando
  16. #54
    Swansea, MA
    9,023
    Gary
    4
    Quote Originally Posted by FReis View Post
    Hi,
    Thanks in advance
    Fernando
    I made a gasket from cork sheet material and used sealer. No leaks.
    Old mechanics trick: Place the sheet over the tanks opening and using the ball end of a ball pean hammer, tap around the opening and into the mounting holes. Then trim the outside.
    www.alt-opel.us
    @opelgary
    1. 3.4 V-6/T-5 Engine/Tranny Swap Phase VI
      By namba209 (R.I.P.) in forum Performance Articles
      Last Post: 11-21-2008, 11:29 AM
    2. Fuel Sender Unit Easy Fix
      By Conaero in forum 1E - Other Electrical/Gauges/Instrument Panel
      Last Post: 05-08-2006, 04:43 AM
    3. 3.4 V-6/T-5 Engine/Tranny swap Phase I
      Last Post: 11-20-2005, 03:42 PM
    4. Fuel Gauge Sender Problem in '69 Kadett
      By tekenaar in forum 1E - Other Electrical/Gauges/Instrument Panel
      Last Post: 12-31-2004, 12:29 PM
    5. Sending Unit Filter - Ascona Fuel Tank
      By svopel in forum Fuel Tank, Lines, Filters and Venting
      Last Post: 11-01-2003, 06:16 PM
