Old 04-18-2008   #1 (permalink)
Sick with Opelitus
broszzy's Avatar
broszzy is on a distinguished road
Unanswered: Vent hose
On a 73 GT theres a 1/4" vent (I think) hose that runs from the fuel tank and comes up the drivers side engine compartment and stops there, "PO thing" does any one know where this is suppose to go? also where dose the hose from the small hole in the valve cover need to go?
Thanks again Pat
broszzy is offline
Old 04-18-2008   #2 (permalink)
Mid-West Opeler
sawdust's Avatar
Logbook Entries: 2
Real Name: Hans
Originally Posted by broszzy View Post
where dose the hose from the small hole in the valve cover need to go? Thanks again Pat
search valve cover hoses
Projekt 2009 - Der OPEL GT
Other Cars:
2006 Solstice (Aggressive)
2010 Fusion Hybrid (White)
LINK to my picture Albums
sawdust is offline
Old 04-19-2008   #3 (permalink)
baronbors's Avatar
baronbors
Thanks again Pat
The vent line from the gas tank goes to the vacuum canister in front of the radiator.
baronbors is offline
Old 04-19-2008   #4 (permalink)
Opelupogus's Avatar
Opelupogus is on a distinguished road
There's a pdf with a diagram from Charles Goin that might help:
http://clubs.hemmings.com/clubsites/...h/TankVent.pdf
If it's not leaking oil - it's out of oil!
1969 Opel GT ... visit my restoration project ...
2008 SRT4
Opelupogus is offline
Old 04-19-2008   #5 (permalink)
'73's ...
On 1973 GTs there was a special fuel return line that went back from a bleed on the fuel filter - supposedly a vapour lock prevention method. This required a special fuel filter with one inlet and two outlets - so it is quite possible the "P O" could not find the correct filter, used a conventional IN/OUT one, and just left that line dangling there ... IMHO
Old 04-19-2008   #6 (permalink)
Exclamation GT fuel vapor line . . .
. . . yep, and of the GTs, only the '73s had it!
Old 04-19-2008   #7 (permalink)
Opelupogus's Avatar
That's interesting that the 73's had it. Opelbits (Tony) and I have discussed this various times as a preventative for vapor lock. The one by the carb is presumably the outlet, where was the inlet.
Does it return to the tank or back to an inline filter before the fuel pump?
Does anyone know if this actually helps reduce vapor lock?
I installed an electric fuel pump last year and have been contemplating whether or not to run a return line to recirculate the fuel. In theory it seems like a good idea.
2008 SRT4
Old 04-20-2008   #8 (permalink)
Sick with Opelitus
broszzy's Avatar
I got this car with no motor and a box of parts and there is a fuel filter with two in and one out or two outs and one in lol but its plug ed Ill have to order a new one and hook it up right. I know I read something about the 73 being different but could not find it again, it's a good thing there's so many guys here to help!
Thanks again Pat
broszzy is offline
