Real Name: Neil
Unanswered: Fuel Tank Cleaning
I have ordered the following parts from OGTS, filler neck hose, tank vapor tubing lines, gasket for fuel tank sending unit, clear fuel filter(for under tank). Am I missing any parts to replace? And what are the recommendations on what to use as a cleaning agent? I found this link for sealing product http://www.por15.com/product.asp?productid=357 what size do I need to order? Thanks Neil Last edited by grslightng02; 06-02-2008 at 11:04 PM. Reason: Forgot to add a question |
Site Admin
Did your fuel line fitting come off ok? OGTS sells replacements.
I just did this to my GT tank two weeks ago. I used the POR-15 motorcycle kit. One small (1/2 pint) can was more than enough for a GT tank. |
'72 Opel GT (Sara)
Matt
Real Name: Neil
Thanks for the info Matt you have awesome pics of your step by step tank restoration! Although I'm still not sure what this "tank fitting" that was referred to is.
Yes, he is referring to the line off the bottom of the tank. I believe in order to get the tank out easily you should remove the two brackets on the wheel wells. The studs on them stick through the wells into the wheel area and are usually covered with undercoating. You have to remove the undercoat and remove the nuts and then the angle brackets come right off.
Real Name: Neil
Heat Wave Leak
I have pulled my tank, cleaned it, removed sock filter, painted it, reinstalled it and put a new hose to filler neck and reinstalled the venting lines, new fuel lines and two fuel filters.
In the past week our area has been plagued by day after day of temperatures beyond 100 degrees fahrenheit~! Just last night I went out to check my mail and as I walked out I could hear something, like water from a hose! I realized quickly the sound was coming from under my GT and I rushed over to find the new fuel line had become detached and was leaking gas from the tank! Needless to say I fixed it quickly. My problem is I'm in need of a part QUICKLY to fix this. When I removed the tank to clean and paint it, the "L" shaped metal tube that comes out of the bottom of the tank would not come loose no matter what I did. Unfortunately I had to just saw the piece off to remove the tank. Apparently when I reattached the new fuel line, the clamp that I tightened to the remaining metal tubing did not have enough tube to hold onto anymore and was pushed free under the heat. Does anyone have one of these spare "L" shaped metal tubes that I'm speaking of that I can buy from them? Thank You, Neil |
OGTS has the whole line and fitting, give them a call and you could have it overnight. They're that close to you.
I had my gas tank boiled out and sand blasted for a mear 50 bucks at a local radiator shop. All my hoses seemed to be replaced before i bought the car so i just clamped them on and havent had a problems since.
Thanks Neil[/QUOTE] Use the black rubber fuel line (5/16'') that you can buy at the auto parts and small fuel line clamps.I've used the clear before and it didn't hold up.This is something that you only want to do one time.Also there is a fitting that has a big and small hole that is only supposed to go one way. |
Real Name: Neil
Thanks for the advice. So far the only problem I'm having is that when I pulled the fuel tank, the metal tubing on the bottom of the tank wouldn't loosen. The metal tube has an L shape to it, and without removing the metal tube, the tank wouldn't come out of the car. I had to resort to cutting the tube to get the tank out.
I thought I left enough of the tubing there to attach my new fuel line and clamp. It's too short and didn't hold up. I called OGTS and Dennis said the part is in the new supplemental catalog but they are on back order from Germany. Does anyone have one of these "L" shaped tubes from the bottom of the fuel tank that I could buy from them? Thank You, Neil |
Neil, read post #9
Several years ago, I refitted my tank with OGTS's clear tubing. I think it is Tygon tubing. On inspection a couple of years later, I found liquid gas in the tube. The tube had swelled and was quite soft. I replaced it with rubber fuel line hose from the local parts shop.
Terry |
#16 (permalink) | |
Neil, I would suggest you use a penetrant like PB Blaster and get the line and fitting out of your tank, if possible. You can check your local "Yellow Pages" and find a tubing shop, and they can bend a suitable sized line with a compression sleeve and use your old fitting to seal the line to the tank.
#20 (permalink) |
Real Name: Neil
Ebay
Thanks for the heads up Gary. I bid on that item and was finally outbid by 50 cents! UGHHHHH
Anyway if anyone else out there has the metal tubing that comes out of the bottom of the fuel tank that you can sell me please email me. People have suggested fashioning your own and I thought of that. The problem is the tube has a metal lip on the end of it where it slips into the bolt. I don't think I would be able to replicate this in order to get the correct seal. Thanks, Neil grslightng05@aol.com |
#21 (permalink) |
Neil, that's a standard, copper/brass compression barrel that slides over the tube. Once you tighten down the fitting it compresses onto the tube and seals the fitting. I would suggest you check out a "Parker Store" in your area, they have all kinds of fittings and lines. Just take the fittings out of the tank with what's left of the line and show them what you got. They could probably use your original fittings and use a steel line to make a new compression fitting out of it.
#22 (permalink) |
Ron is correct, the only trick is to find a fitting that connects to the gas tank fitting. I posted on this topic a while ago (OK, FIVE years ago!) and this was the thread (read post #2):
http://www.opelgt.com/forums/fuel-ta...html#post37346 I also posted a photo of the adaptor: http://www.opelgt.com/forums/fuel-ta...onnection.html The key is this: "...Just make sure that you have a new fitting (the tank connection is a female connection, 12mm by 1.5) and some way to connect to a new piece of tubing. I found an oil pressure gauge adaptor at an automotive store, that was 12mm/1.5 by 1/8 inch NPT, that I then connected a standard copper tube to with a 1/8 inch compression fitting. And no more steel tubing to corrode." HTH
