#51 (permalink) |
The best clutch alignment tool on the market!
Here is the clutch/flywheel install. I installed a new rear main seal here, lubed new pinion bearing. Before I installed the freshly machined flywheel I ran a tap in all holes prior to assembly. I also paint the timing mark on the back side with a white strip to easily locate it for future timing reference. Makes it easy to see down where it is dark after installed in the car. I installed the flywheel and used the best clutch alignment tool on the market (an old front tranny shaft-I've found no better) Then I torqued all bolts to the correct specs. NOTE, the service manual is incorrect on the torque for the clutch plate bolts. After I finished I reinstalled clutch arm in the housing and the tranny is ready to install...pictures tomorrow or Monday on that. Also the new clutch disc is marked which way it points so you will know.
#52 (permalink) |
Engine assembly
Here are pictures of the engine tranny assembly on the stand about ready to install, I still have to install a couple brackets. I installed the starter, distributor, lifters and fuel pump, I did prime the engine with a special made shaft in the shape of a distributor shaft and then spun it with a drill until I could see oil come out of each lifter.
Keith |
#54 (permalink) |
Meet "Patches"
Okay, body is back with several surprises. There were a lot of previous patches used and covered up. We have our work cut out for us on this one, but I can't wait to start repairing the metal. This goes to show that one might have been in paint for years, but the sandblaster tells all and this is one of those instances.
Keith |
#56 (permalink) |
'72 Opel GT (Sara)
First in-person visit…
My wife and I made the drive from Atlanta, GA to Cookeville, TN Saturday morning for our first visit to see progress on the Opel GT restoration. Here is our “trip report" as a series of short posts with pictures (following in-person visits is the only time I will post to the PROJECT thread).
We arrived after about 4 ½ hours on the road (some of that time spent with the top down on the Solstice ). Keith was out front of Mid-Southern Restoration (MSR) waiting for us and we were joined by Harold (hrcollinsjr) and Art (one of the shop owners and the person that will be doing the paint job, among others things).Keith had everything laid out just as it would be if installed on the car: Front end, then engine and transmission, and then the rear end. We went over all of the steps taken to get to this point and reviewed several other parts that are finished but still loose (e.g., the master cylinder). We also looked over parts that still need some work and decisions made on how to proceed (e.g., the steering column and Weber carb). Everything looked amazing with many restored parts looking like they just came off the stock shelf. Continued... |
'72 Opel GT (Fireglow Orange)
Third Owner, Purchased in 1986 Current Status: Fully Restored Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, XM Radio / CD, ADDCO Front / Rear Anti-Sway-Bars Other Cars: '06 Pontiac Solstice (Envious Green) '99 Oldsmobile Intrigue GLS (Black Onyx) |
#57 (permalink) |
'72 Opel GT (Sara)
First in-person visit (continued)...
Next, we went to the back of the shop to see the sand blasted and primed body shell which is still on the rotisserie. We spent a lot of time here talking over what was found lurking under the paint and bondo as well as the good and bad aspects of the body’s current state. I think the general consensus was that the sections of the body that aren’t rusted are actually pretty straight and relatively dent free. Art discussed some things we can do with the underbody to make it sound and protected (and still look good) but that will also enable us to save a little on the budget. This will free up some money to spend on the visible parts of the car without compromising the car’s overall safety and reliability. You’ll see more on that as Keith get’s into the metalwork. We also looked over the hood and doors at this point all of which looked good. Harold was also a wealth of info on the car as we looked things over.
#58 (permalink) |
'72 Opel GT (Sara)
Next, we went to the loft area in the shop where all of the OGTS parts are stored waiting for installation on the car (e.g., carpeting, headliner, trim, rubber window seals, etc.) Also, all of the powder coated parts not yet ready for install were shelved here wrapped in paper and taped up for protection. Everything was clearly labeled and organized which a neat-freak like me really appreciates!
Next, we went over the in-car entertainment components I brought with me (in my nice new Opel duffel bag) for later installation. I purchased all of these components from Best Buy’s car audio shop. Not to jump ahead of ourselves here, but the car will have an in-dash AM/FM radio with CD player, MP3 / iPod input jack, and XM Satellite Radio receiver. A 580 watt amp will also be installed in the car initially driving two 6" x 9" speakers. The amp will provide the flexibility to later add a sub-woofer and additional speakers if desired. Music is important to me (I never drive without it) and so a good sound system upgrade was mandatory. Finally, it was time for a little driving fun. I went for a spin in Keith’s blue Opel GT which was awesome - Keith pushed the car hard . We also got to ride in a 1955 Jaguar and a Camaro that were parked out front when we arrived. We ended the day by having dinner with Keith and his wife which was great and Keith even gave us some “parting gifts” (Opel GT model and three CDs full of the hi-res pictures he has taken thus far).Our next in-person visit is scheduled for June. Until then, I would like to thank Keith and Art for a wonderful review of the project (and Harold for joining us) and I'll turn the thread back over to Keith... |
#59 (permalink) |
Metal work begun
I began work on the front of the GT today, the belly pan had been replaced before, and was easy to remove. I widdled away at the front to remove the lower headlight buckets. Looks like the metal on the outer frame rails to the outmost front will be replaced and then I will continue out from there. Wasn't too bad to clean all this out. Any one have any NOS inner front panels they want to sell or inner fender pieces let me know by posting on the comments thread. We could use some but if not I will hand make this stuff or rebuild the old pieces for the most part. Here are the pics
#61 (permalink) |
Metal reconstruction begun
Here are pics of the front frame rails -outer panels removed due to rust, then sandblasted inside and primed with a weld through primer from 3M. The I spotted in some new panels and roughed in the drivers side. I still have more welding to do to dyno this part in, thats why the seam is rough-plus a panel welds over this seam and then seam sealer will be applied.
Keith |
#62 (permalink) |
Front marker light areas
Before the lower headlight buckets can be welded in the outer lips of the front end has to be reworked, because it all gets welded to the bucket. So I am trying to get everything taken care of (rust wise) before I weld it back in. When I do this, I actually get several small pieces to remake the lip and some of the body part as well. I find if I do several small pieces, yes it takes longer, but the factory lines remain unchanged. If I tried this with one piece, it actually would take longer and cause more frustration. Also I from time to time refit the original marker light just to make sure I am not actually getting off track or my metal is warping. The last picture shows the other side and you can see what I had to do on this passenger side. I am trying to do only one side at a time as well
Keith |
#63 (permalink) |
Front sheet metal work
Been a little while since posts, so here they are. I really began working on the passenger side, so that is mainly what you will see in these pics. Since there is not any metal available for these cars, I have been "rebuilding the existing metal the best I can. A lot of this will never be seen, so not much detail is being used to cherry these parts out, but they will be all metal and solid. I began work on the lower headlight bucket panel. I added metal around the entire edge, then mated up to where it would be on the car and then drew a line to cut off the cirular area of the part. I leave some of the original edge so I know where to go to when lining back up. On the underside of this part I coated it with an epoxy that is basically a patching compound made by ManTek. This is an industrial product and won't be available at an auto parts store. I coated it up to the spot weld areas. This is sandable and I have smoothed it up since the pictures
#64 (permalink) |
More metal
These pictures are of the inner bucket pieces being replaced. Kind of hard to see what is going on here, but basically the buttweld seam for the inner fender panel was remade, and rust was cut out and replaced with new metal. Looks like the inner fender goes in before the lower bucket does to get everything lined up correctly. I will sandblast in here before I weld the panels in permanently, I will also reprime to protect these areas that paint cannot get into as well.
Keith |
#65 (permalink) |
More of front passenger side
Here are some more of the headlight bucket and then the inner fender panel from a donor car. I still had to do some rust repair to it as well, but you can see the before and after. I used what rubber pieces I could find to make the seals, but these are not available either so you have to be creative here
Keith |
