Audi TT vs. GT
Results 1 to 6 of 6
Thread: Audi TT vs. GT
    Opeler My location jvandyke's Avatar
    May 2006
    Hudsonville, Michigan, USA
    1,767
    Audi TT vs. GT
    Guy I work with is a sports car geek. Has a slightly hopped up TT, up to about 265HP. He offered to let me joy ride it last year. I turned him down at the time but tonight he offered again, I was off.
    I'm not a very experienced performance car guy by any stretch but holy crapoli did that puppy fly!!!
    It was fun, but despite performance at a level not even dreamed of when my GT was new, I had an awesome ride home from work in my GT.
    There's something about the spartan "pure" experience (not that I'd know really) of a classic like my GT.
    Of course some dude trundling around in a MG TD or something surely says the same in regards to my GT!
    To each his own.
    I like the smell of my car (little gassy ) the noise, the valve train, creaks and groans, straining on the wheel at parking speed, rough ride, handling that takes some forethought Some fast foot work keeping the engine idling at the light, clutch, brake/gas/brake/gas....you know the dance.
    The view of my little bubble headlights flipping over and coming to life, the curve of that knife edge fender viewed from the driver's seat (BTW that has to be one of the top 10 most perfect sights in car history, no?), the little analog gauges gently bouncing.
    GT wins.
    '72 Opel GT (Sara) My location newman27's Avatar
    Jul 2006
    Atlanta, GA
    2,115
    Matt
    A friend of mine has a TT also - it is a fun ride. I like all the same things about the GT - what a great car! Although, I've never actually flipped the headlights on one because the cable on mine was frozen up the day I bought it and I couldn't ever get one pulled from another car to work properly. I ended up buying a reproduction cable from OGTS. The first thing I'm going to do once mine is on the road again is flip those headlights . BTW, my GT was really hard to steer at parking speeds too until I got an alignment done. Night and day difference. Have you had an alignment done since you bought your car? It might help.
    Nice post...
    Matt
    '72 Opel GT (Fireglow Orange) "Sara"
    Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, Custom CAI, Sprint Manifold,
    Enhanced Suspension (Anti-Sway Bars / Koni Reds / Sport Springs), "Big" Brake Package with 22mm Booster / MC, 15x8" Wheels and Toyo RA-1 Tires, XM Radio
    Restoration Thread
    Comments Thread
    Other Cars:
    '09 Pontiac G8 GT (Panther Black) "Jet"
    '06 Pontiac Solstice (Envious Green) "Mina"
    '99 Oldsmobile Intrigue GLS (Black Onyx) "Raven"
    Moderator My location jordan's Avatar
    Mar 2003
    corning ny 14830
    1,962
    The only aspect of alignment that would matter with slows speed maneuvering would be the camber, toe in/toe out won't matter too much unless it is way off and caster won't matter really either. The biggest improvement you can do to make steering easier at slow speeds is to fit some very narrow tires and clean and relubricate the steering rack.
    1970 Opel GT 1.9
    1980 Moto Guzzi V50
    2000 Saab 9-3 2.0 turbo
    2000 KTM 200 exc STOLEN
    Jan 2003
    Chapel Hill, TN
    7,790
    Harold Collins
    Quote Originally Posted by jordan View Post
    I can see toe in/out not making much difference. Caster I would think could make a big difference. When I explain caster to someone I use examples such as the casters on a shopping cart (extreme negative caster) they follow really well, neutral is like the front forks on a trail bike almost straight up and down, easy steering and changes directions easily also (neutral is straight up and down). Chopper style bike (extreme positive caster) only wants to go straight. The GT's are set up with slightly positive caster so they will track straight.
    Camber basically is whether the top of the tires lean in or out.
  7. #5
    Moderator My location soybean's Avatar
    Nov 2002
    Reidsville N.C.
    1,856
    Well, we're moving out of the original disscision but I'll add my .02 worth. My
    camber was extremely messed up on the passenger side, front end alignment on a Bear machine fixed that. Wore out a front set of tires real quick. Check the front end alignment and save yourself some money.
    Back on topic now. We, son and I, recently purchased a used 06 350 Z. Don't rag me
    now , but after installing a few small mods, cold air intake, plenum spacer, that sucker will run. 130 in 3rd gear, with 3 more to go. Top end is supposed to be 150. I'm too old to see that again, well maybe not that old, but not on a public road. As far as looks it's ok, the car is basically plastic, too. So in conclusion, I'd still rather have my Gt and my 88 Saab Spg. Both easy to work on, and in a lot of ways, I feel safer with them, steel rather than plastic. Speed on both is acceptable to me and besides, they both are Classics. I love my Gt. Ok off the soapbox and back to the original topic.
    Jarrell
  8. #6
    May 2006
    1,767
    My low speed issues are certainly due to wide front wheels, I'm not even sure what they are, 7" or so I'll look sometime. The handeling at speed is fine, quick and "nimble".
    1. Replies: 16
      Last Post: 06-16-2007, 11:07 PM
    2. Opel Get together at Flashback
      By Thom71GT in forum Georgia Opelers
      Last Post: 11-15-2005, 01:49 PM
    3. Looking to buy an Opel Gt
      By Rojo in forum General Discussions
      Last Post: 11-27-2004, 05:22 AM
    4. Tacoma's 2003 Gathering of Opels
      By MawandPawOpel in forum Opel Events Forums
      Last Post: 08-20-2003, 04:38 AM
    5. Speedway GT
      By jeff denton in forum Racers Forum
      Last Post: 11-16-2002, 07:24 PM
