| General Discussions General Discussion and Chat. |
GT 3.4 V6 on Ebay
eBay Motors: Opel (item 190247292502 end time Sep-02-08 15:23:39 PDT)
Looks very clean in and out, with a 1994 Camaro engine swap. |
How about that, an almost Willit? clone.
Nice car either way. I wonder what the reserve is set to? |
Current
1970 GT; Red with Red Interior (Restoration Project) 1969 GT; Street/Strip Project (For Sale-Best Offer?) Previous 1969 GT; White with Black Interior, Automatic 1969 GT; Black Parts Car 1969 GT; White Parts Car 1970 GT; Silver with Red Interior 1971 GT; Orange with Black Interior, Turbo 1972 GT; Red Parts Car 1972 GT; Blue with Black Interior 1973 GT; Pearl Blue with Black interior. Full body kit. |
3.4 GT on ebay
My question is how did he shoehorn it in the engine compartment without the major chop, cut & rebuild and the hood modification that you made doing the swap. Maybe we just need to see more pictures of the engine compartment and the interior.
#8 (permalink) | |
Very Little cutting
From what I see, there was minor boxing of the lower driver's side foot well. They are even re-using the original hod locks so that side was not modified too much.
Depending on how the engine is set in place is how much you need to cut. I have been approached by many to install a V-6 on Stealth and show the step by step process but I want to keep this vehicle stock. I will say this, if after driving the car it turns out the engine is not to my liking, then I will install either an Ecotec or a 3.4L on the vehicle. I do have several engines available and also a Tremec 6-speed which I would really be happy with. |
JB
Restore, Customize and Conquer!!! |
#10 (permalink) | |
JB, just out of curiosity, do you think a replacement engine could handle a 6-speed with two overdrive gears? Even with the torque I have in Willit? I need to down shift at freeway speeds to accelerate rapidly. I'm thinking a dual overdrive unit would lug down the engine a bit. On the other hand, I'm seriously thinking about a T-56 in the monza, hooked up to the roller cam, 4-bolt main 350 sitting in the garage in pieces. We're guesstimating about 390 HP from it. |
#11 (permalink) | |
You can get a Tremec 6-sp mated to a Ford V-6 which is about 220HP. But in any event, I would probably live between 3rd and 4th gear most of the time. Tremec does provide you with a greater ratio curve between the gears so it is like having a set of halve ratio gears and an overdrive. Anyway, it is just something I am mindly toying with. |
JB
JB, Thanx for the info. I'll check it out. Now that we've kinda sorta hi-jacked this thread, I'm gonna build an FI engine in the monza, which means all the fun and games I had with Willit? doing the same. I still have to keep all the smog stuff on it, CA CARB rules, which means I'll have to keep the $107 water pump so I can bolt in the smog pump, instead of the standard $30 water pump. And probably go with another Sanden AC pump to replace the piston R-12 one that's there. Back in 75, this was just a monza with a Corvette engine in it, so I figured to just upgrade it to newer specs.
I'm gonna guess the reserve is close to 5 figures, but JB "blancojp" could probably give a berter guesstimate, he's done a bunch of engine swaps.
