| General Discussions General Discussion and Chat. |
#26 (permalink) |
Not So Newb Anymore
I am going to post up some pics of the one that is bad and the drivers side that is good. I noticed around the hole that the driven gear is in there are hairline fractures in the metal. I was thinking that might be the problem but there really is no way to fix that. Still working on a plan to fix it.
#28 (permalink) |
Not So Newb Anymore
Well I took the intiative and started the only course of action I thought might work. I started welding the teeth building them up and then grinding them smooth to get them to mesh up correctly. I don't know how long this will hold up but the welding is strong and shouldn't wear down very fast. Here's a picture of the work. I still have to clean it all up and lube it before I make the final reassembly.
#31 (permalink) |
Not So Newb Anymore
Well i got it all back together. It works flawlessly. I guess I got lucky. Now on to other things.
Does anyone know what the bolt pattern on the wheels are? I needed to get some tires but I have a hard time finding decent 13 inch tires. So I am thinking of going with 14 inch wheels and tires. |
#33 (permalink) | |
After making between ten and twenty posts, you should have figured out how to use the search function. With 56 posts to date, now you need to be told. Along the way, someone should have mentioned that there is a reason that this site is organized into headings, similar to the Factory Service Manual, so that questions and related answers are more easily found using the search function. A general rule is to keep threads on-topic, and to post them to the appropriate Forum. Most importantly, search for an answer BEFORE you start a new thread, and if you can't find the specific answer in a related thread, ADD a post to the thread rather than starting a new thread. General Discussion threads will get lost over time, while threads kept on-topic and posted in the correct Forum will endure and be useful time after time. The following link, while humorous, provides a terrific insight into the best way to using this site: Hi newbie, you want to post on a forum? this is what you need to know! There is an entire Forum related to wheel choices at 3D - Wheels and Tires - Opel Forums For your further insight, there is a thread related to the headlight mechanisms at http://www.opelgt.com/forums/2c-gt-h...echanisms.html and many related threads in that Forum. Most if not all of your questions in this thread have answers in other threads Thank you in advance for your assistance |
working on my '71 GT and '75 SportWagon |
#35 (permalink) | |
Again, this is just awesome! Keith my man, you have zero tact. None. Here we have a new fan of Opels who posts intelligent questions (and pictures, both for the problem and how he solved it which are worth a few hundred words at least). I understand that someone has to manually move to post to the correct forum when it is wrongly categorized butI think a private note to the guy to hint about the correct forum when posting would have sufficed. Thanks for taking the fun out. And BTW, the "newbie" video about posting in a forum is mildly amusing (at best) for those of us who have been doing this for a while but to an actual new person it's pretty damn condescending. Sheesh its great to be aggrivated in the morning. |
#37 (permalink) |
Not So Newb Anymore
I had seen the video a long time ago. I am a member of quite a few forums. I don't really want to start a war with anyone on here it's a very valuable site with tons of info. That in itself can be rather frustrating. It's sometime tough to find exactly what you are looking for sometimes the info provided isn't there. I also felt that I did a good thing when I offered up my very simple solution to a problem that plagues many of these cars. Let's not get away from the topic though with this. I will admit I should have searched the wheel size before asking I was just on a roll. Thanks to all who provide such a great help.
#39 (permalink) | ||
I believe that we have agreed to disagree on this matter before. However, should you become a Moderator someday, your suggestion that individual private notes get sent out to every one of those 13,200 members might not seem like the most effective method of communication. With one or two posts, insight has been given to at least a few hundred members who have read this thread. To be clear, I am not trying to "take the fun out", but imagine this site with no organization, no guidance, and no Moderators. It would look like a few thousand other car boards that are not worth the trouble to even look for answers. And while the "Starterup Steve" link may seem a bit condescending, it is pretty much spot on for providing accurate guidance for posting etiquette. By the way, I find that my agravation level is much reduced by not logging in until after my second cup of coffee ![]() Thanks for your understanding of the intent of my post. Even if my tact was off a bit
#40 (permalink) |
Lack of tact certainly gets the point across better and I don't think the moderators have anything to apologize for. i like many others would like to thank the moderators for the excellent way this site is run.
Keep up the good work. |
Puppies are not just for Christmas, I could play with them all year round.
#41 (permalink) | |
Keith, The mods on this site do an excellent job for the most part. And I realize it is a thankless job and the pay isnt great. I just think that a note to Opelnewb would have done the job better. I know you can't send a pm to all 13K members but the reality is that not all of them need one and not all at the same time. And seriously Keith, I know you are not a bad guy but the devil is in the wording..... Anyway time to move on. -Nathan Last edited by kwilford; 11-07-2008 at 03:57 PM.. |
#42 (permalink) |
Not So Newb Anymore
I appreciate everything guys. I have posted to the proper catagories and hope to not only gain some useful info but share lots of helpful tips along the way. Check out my headlight dimmer post. I have decided to go another route and use some more "standard relays to fix the issue it may prove to be very useful for anyone wanting to simplify and repair the issues so many of these cars have with the headlight system.
