You are correct the far right is a clock
Below you have your switches for the running lights, dash lights, windshield wipers, heater and rear window defroster
and below that are the emergency flasher lights.
(taken from memory - Ms. Opel is covered up and asleep for the winter)
Mine shoots completely over the roof so it washes the rear window - that's a feature!
. Can you tell I have a lot of time on my hands?
I've seen what happens on an agric. sprayer when someone tries to clean out a spray nozzle. Instead of it spraying in a flat fan shape it changes to a straight stream and when I left the pit area for a burger only to return and ask WHY the expensive specially ordered accelerator pump nozzle was dumping most of the fuel on one side in a synchronous opening two barrel carb. I will admit these were softer brass jets and the GT spray nozzles are a harder material, I think.
