Go Back   The Classic Opel Forums > The Lounge > General Discussions
Old 09-18-2009   #26 (permalink)
UngerDog
ungermm's Avatar
Originally Posted by ben View Post
did compression test
1 115
2 120
3 110
4 120
I don't know why you would pull the head. Your compression isn't bad.
the number 2 cylinder is the one didnt seem to be firing
which is number 3 in the in the firing order
This statement, if correct, means your wires aren't in order. The #2 cyl. is fourth in the fire order. The firing order is 1-3-4-2. Check to make sure your spark plug wires are in this order!
ungermm is offline
Old 09-25-2009   #27 (permalink)
ben
ben's Avatar
ben
ok so i pull the engine a part
can't see any damage little scoring
one bearing cap was i little tight
nothing major
so
Opeler Forever,
Ben
ben is offline
Old 09-25-2009   #28 (permalink)
ghcoe's Avatar
Real Name: George
Did you check the cam lobes. I bought a Manta once and it was running on three cylinders. They thought it had serious internal engine problems. Was just bad cam lobes on one cylinder. George.
ghcoe is offline
Old 09-26-2009   #29 (permalink)
ben
ben's Avatar
ben
took the head to the machinest
asked to have it all checked
Opeler Forever,
Ben
ben is offline
Old 10-09-2009   #30 (permalink)
ben
ben's Avatar
ben
well i guess iam in for a complete rebuild
the machinest i took my egine to said the last guy f##k me
thats why i had all the issues
head wasn't rebuild right wrong ehxast seat no case harded valves
didn't clean the block right turned the crank wrong. so called them they said without paper work could't do any thing for me.and if i had paper proable not because it rebuild in 06. but think because it should have lasted longer then 638 miles. so i won't be recommening them for ever again
Opeler Forever,
Ben
ben is offline
