help
started to miss fire and in checking i found that i could pull the # 3 spark plug wire and it does not make a diffecene on how it runs if u pull any of the other's there is a diffecene so i think thats means that the # 3 plug is not firing. check that out, it is firing so where to i go from here
Opeler Forever, Ben |
Try
1. Changing that spark plug 2. Check your spark plug wire with an ohm meter for high resistance.The wire may be broken internally. 3. Remove your distributor cap and inspect the terminal that corresponds to that cylinder, as well as the rotor itself. Sometimes just little sanding on the terminals will fix the problem. |
Code Goober
No, that's not a defect, that's a feature. |
did compression test
1 115 2 120 3 110 4 120 the number 2 cylinder is the one didnt seem to be firing which is number 3 in the in the firing order the motor has 638 miles thought it was more only 638 since the rebuild
Opeler Forever, Ben Last edited by ben; 09-10-2009 at 02:57 PM. |
UngerDog
firing order
The firing order is 1-3-4-2. The distributor rotor turns clockwise. Cylinder #1 is closest to the radiator. I would double check for a good spark at the dead cylinder. Are you still using points in the distributor, did you replace them and the condenser? Make sure to adjust the point gap and check the timing. Or better yet, now might be a good time to upgrade to electronic ignition.
Jerry |
#11 (permalink) | |
Based on your initial statements, I'm suspicious of problems involving the engine internals. You mentioned a misfire developed. Sounds like a failed ignition wire, damage to a spark plug, glowing debris in the cylinder, etc. Did you make any changes or repairs to your car immediately before the misfire began? Did you purchase cheap fuel from a station you've never used before? Your comments of what you did regarding new wires/plugs/cap/rotor are not clear. Could you please take the time and be exact in what has been replaced with new parts? Use periods at the end of each sentence. Otherwise it’s too easy to misinterpret your meaning. |
Is it missing all the time or just sometimes? Backfiring through carb or exhaust?
Could be a cracked distributor cap between two plug towers. I would just try another cap because sometimes those cracks are hard to see. Reset your points on the point lobe to that cylinder. If it is worn some it can cause a miss on that cylinder if it is the lowest lobe of the four. Just things I have ran into in the past. George. |
? Did you make any changes or repairs, to your car immediately before the misfire began? yes
i replace the transmission(put gear throw housing) ? new wires? no ? new plugs? yes but only one (hoping that was it) ? new cap ? no (cap look's good have tyred other cap) ? new rotor ? no (same with the rotor) took out the pertronix, because thought it was the cause.(was once before) went back together with new points (hoping that would fix the issue) ? sounds like a failed ignition wire ? no wire is fine. (msd wire's) ? damage to a spark plug? no but replace it any way. ? debris in the cylinder ? no cylinder is clean. had the valve lash done six mouth ago, also replaced rocker arm nut's at that time. ? does your head have hardened valve seats? yes yes it missing all the time i hope this help's,answer the ? thank you
Doug
1000 mile diagnosis
Run it in the dark and see of you are bleeding off the spark some how.
I would replace the rotor and wires, or at least try the wires on a different cylinder. Wires can appear fine but lose power by bleeding off the spark to ground Good luck.
Doug |
Real Name: gerold
Ben, You might look at the ground wire on your dist plate insede the dist. I had one that had the solder come loose and gave a terrible ground to my points. I took the dist out, cleaned, and resoldered it back, and it ran like a champ. gerold
#21 (permalink) |
replace ground wire on the dist
check in the dark extra spark checked no bleed off ![]() replaced all wire's and all spark plugs and coil,cap,rotor. still same. replaced all the lifter's, and valve's adjusted.again read some where that could have been the issue still the same time to take the engine a part and find out what went wrong any other idea's ![]()
#24 (permalink) |
Here are the problems resulting in the two times I was really stumped. Perhaps one of these is your problem. The engine turned. I had spark. I had fuel. But it wouldn't run.
1. Bad fuel. I'd fueled my GT at a Shell gas station and the fuel had been watered down. It was so bad I couldn't even run a lawn mower on it. So I drained the tank, refueled, and it ran great. I'm not sure how to test for bad fuel, other than to run it through another engine that I know will run. 2. Recently, I pulled the distributor in order to gain enough room to remove my over-sized alternator. Turns out my timing was approx 60 degrees off when I reinstalled the distributor. I was under the false impression that slot at the end of the distributor shaft only allowed the timing to be spot on, or 90 degrees out. I turned the engine by hand until it was top dead center and my intake valve (1st cylinder) had just closed. Then turned the slot with a long screwdriver so it would allow me to slip the distributor into proper alignment. |
