Winter Projects for your Opel
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Like Tree36Likes
Thread: Winter Projects for your Opel
    2000 Post Club My location poor gt (R.I.P)'s Avatar
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    Well since winter has decided to come early, thought it was about time for this thread. The old girl was a bit rebellious this summer, but did get me to all the shows I wanted. I have a few things to take care of, (1) blown head gasket, (2) broken timing cover, (3) leaking oil pan, (4) new OGTS starter, etc. etc ....currently the engine block and pistons only, are attached to the trans, too cold for the garage today,& OSU played, so I dug out another timing cover 12 bolt, stripped off the blk. paint, and polished it. I prefer the natural look, nice polished alum., with high temp clear coat, the water pump is next . I hope to reinstall the oil pan & timing cover this week. PITA cleaning up the engine compartment, but she needs it, a little oily WHAT ARE YOUR WINTER PROJECTS ???
    Opeler My location Djaz's Avatar
    Jul 2009
    Sahuarita Arizona
    70
    DAWN JOHNSON
    That looks great, I pity you living in the snow belt. I use to live in Indiana, Ugh ! winter for me means I can finally drive my car and not roast here in Az. I do need to put bushings in the front but will have to find some place to do it. That is one job I can't do. That was the last thing on my list to get done.
    Can Opeler Knorm65's Avatar
    May 2014
    Wichita Falls and Munday, Texas.
    1,739
    Kyler Norman
    4
    Nice timing cover!
    My plans are a new engine and clutch. I need to trim all of my electrical wires and find a little gremlin that makes my car stall or idle slower when headlights are on. If I get some money for Christmas I'll buy poly bushings and a rear sway bar. I also will try to get my AC and heater working.
    If I get all of that done then I'll pull out the dash and put the hazard light switch panel where it's supposed to go and make a mount on the rear package tray to mount a battery powered Music and instrument quality Roland PA system (loud and no wiring required!) so I'll be able to blast music and even plug in my jazz or acoustic guitar and play some tunes!
    After that, during the spring, I think I'll take a nice break and enjoy what I have. Maybe go to a track with dad and do some spirited cruising with the Opel and the Cobra
    Then take the GT up to school and maybe pick up a girl or two as long as Gordo stays away haha!
    "Mira," 1970 Opel GT ARA AC, European 2.0L and Weber DGAS
    "Kara," 1972 Opel GT Targa "Fancy Rat Rod"
    Aug 2006
    Goderich, Ontario Canada
    2,707
    P.J.
    Every Fall I line-up the list of winter projects, some small, some major. And the winter comes and it is too cold to work in the garage or the garage is too small for some large project or I find some other excuse to wait until the weather get warmer.
    The Spring comes and I wind-up scrambling to finish everything on time for Carlisle.
    But yes, here is the list of my projects:
    - Quaife LSD
    - Redesign propshaft support (eliminate donut and install sealed bearing inside the torque tube).
    - Black headliner (I hate the existing beige one)
    - Install air conditioner
    Only 6 months till Carlisle...
    Gary, GoinManta, opelgtguy and 3 others like this.
  7. #5
    Opeler jayhawkjesse33's Avatar
    Jul 2006
    Avon, Indiana
    540
    Eric
    I'm currently in engine rebuild/build-up mode. Just got the pistons in the mail today. Should have the motor completed in a couple of weeks, depending on the holiday.
    While the motor is out, I'd like to:
    Install a new electric fuel pump to properly fuel the DCOEs
    Give the engine bay a good cleaning and do some paint touch up in there.
    Replace a few seals in the transmission.
    May take the dash out and reroute some hoses in order to keep the heater with DSDs.
    While the dash is out, I may have it redone in the same vinyl used throughout my custom interior...that project is a big maybe, but it would be awesome!
    Cold weather and a GT without an engine in it are a dangerous combo...
    Eric
  8. #6
    Swansea, MA
    9,022
    Gary
    4
    My Winter plan is to keep plugging away with the 3.0, 24v install in my wagon.
    At some point I need to finish the fuel injector tester/cleaner that I started to build so I can test the 24v and Senator's injectors.
    RallyBob and saxybiker like this.
    www.alt-opel.us
    @opelgary
  9. #7
    3000 Post Club My location m610's Avatar
    May 2010
    Davis, CA USA
    3,029
    Mike Meier
    We'll be racing in March and possibly in January, so the Tinyvette will get it's usual maintenance and repairs.
    An indoor project I've been wanting to do is get an Arduino and set it up so that it can monitor the gauges and if any are out of bounds trigger a big warning light, basically a second shift light.
  10. #8
    Member Twintrouble's Avatar
    Jun 2010
    Seattle Wa
    251
    Duncan
    Put in the sprint last week and was going to put the carb back on today . But the kids left the garage door open all night and some one stole all my tools Sh**T. Good thing they left all my parts and beer. Spent the day gathering new tools merry x-mass to me. Will spend the next few months replacing all the wires and tubing in the engine department.
  11. #9
    Nov 2007
    Cöllingswööd, NJ
    9,820
    Gördö
    6
    Make a whole dashboard from scratch.
    Install wiring and switches for all sorts of crazy stuff.
    Finish installing windows.
    Finish interior upholstery.
    Regasket used 2.4.
    Run brake lines, fuel, and every other hose you can think of.
    I think I might need TWO Winters.........
    Viny Charb likes this.
  12. #10
    Mar 2011
    cincinnati ohio
    2,502
    Brad
    Regasket used 2.4.
    No Way Gordo, You get 1, We want to see it at Carlisle,
  13. #11
    Dec 2009
    Germany/Bremen
    2,757
    Norbert
    Thats good know when my work is in progress
    Also i would not have a black hole as engine bay.You can see nothing of details
    Its a detail eater,the black hole like the real ones
    Norbert
  14. #12
    Aug 2006
    2,707
    P.J.
    Norbert
    My plan is to install modern AC compressor on the RH side bellow carburetors, so it will not be much visible any way. No black hole, please!!!
    And now everybody knows that you are working on a model of my car...
  15. #13
    Member My location heliman's Avatar
    Jul 2009
    Battlefield, Missouri
    487
    Plan to pull the T-5 and hopefully replace it with a close ratio 6 speed from a BRZ. Making the engine to trans adapter will be a challenge, but that can be done. However since I don't make body mods when I swap something, the determining factor will be if I can figure out how to build a shifter that will come out in the stock location.
    71 GT, Ford 2.0 Zetec, Jenvey throttle bodies, Omex engine management. Subaru 6 speed transmission , Ford 7.5 4.10 posi narrowed torque arm rear end. Coilover front end. Electric power steering. Honda Accord 4 wheel discs. In dash Vintage Air, Dakota Digital gauges. Power windows. Keyless entry. Cruise.
  16. #14
    Member My location guyopel's Avatar
    Feb 2003
    Duluth,Ga.
    1,237
    John
    Engine work ....
    John
    DrinkMan likes this.
    Guyopel
    ---Thomas Edison
  17. #15
    Apr 2003
    Portland, Oregon
    6,665
    Quote Originally Posted by m610 View Post
    That's not a hard project at all.
    My Winter projects are:
    Assemble the 2.2, Just need to get the block powder coated before I assemble it.
    Have the 1.9+ block bored and short block assembled.
    Get valve springs for the modified 15. head and install it on the 1.9+
    And get a working model of my Arduino controller for Pozest. I built the code for it last Winter and the last week I've been designing the schematic for the "relay" board(s). It will have around 1000 connections I'll need to solder so it might take me a while to get it finished. ~L~
    poor gt (R.I.P) likes this.
  18. #16
    No....its not a Buick.... My location yellaopelgt's Avatar
    Feb 2005
    On Wind Lake WI.
    1,516
    Joe
    I've got about 2k worth of performance parts that have been sitting here for the last 2 years that will "hopefully" be going onto the GT this winter. First things first though.....I finally got around to locating some stove pipe that will need to get installed in the garage for my wood burner. NO WAY am I sitting in there with no heat!!! Then I'll need to get another cord of wood delivered,split it,well the story goes on and on.... not enough hours in a day.
    Frozen Tundra GT likes this.
  19. #17
    Opeler My location runs5k's Avatar
    Jul 2005
    Ste. Agnes, Quebec
    202
    Gerry Carrigan
    I've restored a 1970 Opel Gt and soon learned that finding rear wheel bearings were like finding hen's teeth. So I've been on the lookout for a 1971 to 1973 donor car. This summer I got lucky. I located a 1972 Gt in a bush near Massena, NY with no engine for just $100. It was really rotten but had only 55,000 miles on it. The only problem was that it had not been on the road since the late 80's and there was no title and I would not be able to export it to Quebec. I waited for fall so the mosquitoes would die off and dismantled the car and took home what was salvageable. I thought I was getting a good windshield but after cleaning it up I discovered a windshield wiper scratch on the passenger side. The diff was in really good shape and turned very smoothly. I'll change the pinion seal and clean and paint it before making the swap. My heater blower motor stopped so I guess I'll remove my dash and word has it that Santa is bringing me a new heater control plate from OGTS. My control plate is broken and so was the one from my donor car. I don't have a heated garage so all this work will have to wait until April....way to cold up here during the winter.
  20. #18
    Jul 2005
    Milner, GA.
    11,298
    Dan
    12
    My winter project sounds kid of simple..
    Change the radiator cap.
    Hopefully I'll be able to get it done. :-)
    JudokaJohn and The Scifi Guy like this.
  21. #19
    Apr 2003
    Portland, Oregon
    6,665
    The bulk of your time will be in generating a graph for it.
  22. #20
    Sick with Opelitus My location broszzy's Avatar
    Aug 2007
    Janesville wisconsin
    1,293
    Quote Originally Posted by yellaopelgt View Post
    We will have to Christen that wood burner!!
    That looks like it was made for it. Come to think of it, it was made for it!
    "All the worlds indeed a stage, we are merely players, performers, & portrayers, each anothers audience, outside the gilded cage"
    Geddy Lee/Neil Peart
    1. Show us the results of your winter Opel projects
      By GeorgeOpel in forum General Discussions
      Last Post: 03-08-2014, 09:19 AM
    2. What kind of Winter GT projects are you gonna do?
      By 1972ACGT in forum General Discussions
      Last Post: 12-25-2013, 11:44 AM
    3. Winter 2011 (Winter 2010)
      By Gary in forum General Discussions
      Last Post: 03-24-2011, 11:00 AM
    4. What have you done on your Opel last winter?
      By P.J. Romano in forum General Discussions
      Last Post: 03-29-2010, 10:10 AM
    5. What did you do to your Opel over the Winter?
      By jlthunder in forum General Discussions
      Last Post: 04-20-2009, 11:40 AM
