There's a tire computer you can use at www.tirerack.com that will help you figure out the tires you'll need to maintain a close to accurate speedo reading. When I took out the floor carpet on Willit? the was a layer of about 1" of foam under the carpet and some tar like insulation covering the whole pan. Now that I'm looking to start the interior, I'm gonna lay down an insulation blanket of water heater stuff, than the layer of foam, than the carpet. Never had a foot heating problem here in sunny SoCal though. HTH.
