Clean oil won't drain
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Like Tree31Likes
Thread: Clean oil won't drain
    Opeler Zachary's Avatar
    Dec 2016
    St. Charles, MO
    7
    Hey guys, first post here so I'm sorry if it is in the wrong place. I am trying to change the fule pump on an Opel I acquired and there is something in the drain hole stopping oil from flowing. The oil is in good shape and this should be the drain as maybe a tablespoon of oil came our when I removed the cap. There was a spring behind plug as shown and the other picture is the object in the drain. It moves when I poke at it but it seams to be held in place and not magnetic. It's a 71 GT with the original 1.9. Thanks in advance for any advice. Also yes, I plain to clean the cat hair off before reinstalling the plug.
    Nov 2007
    Cöllingswööd, NJ
    9,820
    Gördö
    6
    The oil drain is on the bottom of the oil pan. I know that I should know what that thing is you're showing, but I don't. I think that is the pumpy springy thingy that makes the mechanical fuel pump do it's thing. I'm probably wrong.
    Resident Curmudgeon My location Opelmel's Avatar
    Jul 2005
    Neshkoro, WI
    1,259
    Mel
    It looks to me that you've removed the pressure relief valve from the oil pump cover. At the end of the spring there should be a pressure relief piston. Examples of both can be seen on this order page from Opel Gt Source:
    Oiling System - 1.9L Engine - Opel GT - Store | Opel GT Source
    The piston inside the pump cover is forced back when the oil pressure gets beyond a certain point, thereby maintaining a safe and adequate pressure.
    The oil drain plug, as noted, is on the bottom of the oil pan.
    Ooooner likes this.
    1000 Post Club My location jlthunder's Avatar
    May 2003
    Salfordville, PA
    3,982
    I agree with Opelmel. I hope you didn't lose prime on your oil pump by removing that pressure relief valve. There is an easy way to check.
    Put it back together. Disconnect the coil wire on your distributor (the one in the middle of the distributor cap). Crank your engine until you see oil pressure on your oil gauge. Once you get pressure, you can reconnect the coil wire.
    If you lost prime, you won't get oil pressure. No oil on a running engine is a bad thing!!
    The drain plug is on the bottom (steel pan) or the side (aluminum pan).
    1973 GT, Parted out, R.I.P.
    1968 Kadett, Owner since 2006, Sold, 28 June 2008
  7. #5
    Opeler Yellow73GT's Avatar
    Apr 2003
    N.Dak.
    951
    Chuck
    5
    Quote Originally Posted by jlthunder View Post
    As pointed out, that is NOT the oil drain plug. With this tidbit of knowledge, I am going to make the assumption your either very young and know very little about motor vehicles, or your older and not mechanically inclined, sooooooooo, I would strongly suggest you ask someone who is more knowledgeable about engines and car repairs/service before tackling anything further and most certainly verify if you have lost prime or not, if you have you are going to need someone with mechanical knowledge and skill to help you restore prime, otherwise your going to be needing help from someone to replace your engine. It's fun to learn, but not when you know little and have no one to stop you from making a critical mistake Good luck getting it straightened out.
    "Be Water, My Friend" Bruce Lee, December 9, 1971
  8. #6
    Jul 2005
    Milner, GA.
    11,298
    Dan
    12
    I see this as another tongue-in-cheek thread.
  9. #7
    Dec 2016
    St. Charles, MO
    7
    Thanks. Im 21 and know a bit but want to know more so I bought this opel for $400 to work on when I'm not in school because I could afford to mess it up and I love the little car. I assumed that was the drain since it was a low point in a similar spot as my focus. I do not believe there was a pressure relief piston on the end of the spring so I'll probably have to buy one. The car had a distributerless ignition system (link bellow) installed when a previous owner put in all new wiring. I have never seen it start, only a video of it running with someone squirting gas into the carb so I'm not sure if the gages can be trusted. I should be able to just remove the cables to keep it from sparking though since I'm not too familiar with the system. Can anyone tell me if this is any good? I know a distributor can be a hastle sometimes for timing but I don't know if this is junk or not. https://m.summitracing.com/parts/cfi...cKYaAi_j8P8HAQ
    The Scifi Guy, ggl and MikeNotigan like this.
  10. #8
    Nov 2007
    Cöllingswööd, NJ
    9,820
    Gördö
    6
    You seem like a nice young fella who's eager to learn and you've managed to take your first punch from us with grace and style.
    I therefore bestow upon you the.........
    You need to take it slow at this point so that you don't blow unnecessary money as you work out your car's glitches. I suggest starting out showing and telling us more about this car so that we can better walk you through the basic steps to get you evaluated and running. A good start would be to take some pics of your engine compartment so that we can get a grasp of the modifications done to your car.
    You've got a somewhat long journey as we walk you through the steps and school you up on cars, so be patient and we'll get you through it.
    Zachary likes this.
  11. #9
    ggl
    ggl is offline
    2000 Post Club ggl's Avatar
    Dec 2008
    Norway
    2,610
    Goy Larsen
    Quote Originally Posted by Zachary View Post
    Which is a perfectly reasonable and logical assumption even though it's entirely wrong
    The fastest way to learn stuff is by doing and you've just learned something new, my motto when working on cars is "how difficult can that really be", sounds as if you've got the perfect attitude to become a full blown Opeler. Good luck with the car, I'll certainly be looking forward to further updates on your progress. Just remember that there's no shame in asking questions before doing something you're not sure about and the only stupid questions are those you've asked before but didn't care enough about to remember the answer.
    If your oil pump has lost it's "prime" there are a couple of ways to restore it but one of the easiest ways is to undo those 6 little bolts on the oil pump and pack the gears with grease before putting the cover back on.
    What is a "prime" in this case. Well a completely dry gear pump, the oil pump consists of two gears inside a housing, have a great difficulty sucking a thick liquid like oil because when dry the gears have no seal against the housing and isn't able to create the vacuum (suction) needed to get the oil flowing. You need som kind of fluid in there to get things started
    Btw, you learn from making mistakes than doing them the right way. If you had guessed right all you would have learned was how to change the oil on your Opel, with your mistake you've learned not only that but also where the oil pressure relieve is, how an oil pump actually works and why it's important to "prime" it
    The Scifi Guy and Knorm65 like this.
    "I hate RallyBob"
  12. #10
    No....its not a Buick.... My location yellaopelgt's Avatar
    Feb 2005
    On Wind Lake WI.
    1,516
    Joe
    A factory service manual is in need here. They are easy enough to get off e-bay or someplace similar. Even though the p.o. made some mods it will still get you in the right direction. I believe there may be one on this site for download. Good luck!
    The Scifi Guy and Timbo like this.
  13. #11
    Jan 2009
    Illinois
    1,595
    William
    I see that you are in St. Charles. There are some people in St. Louis who have been into Opels for some time, and there are some on the east side of the river as well. Good luck. Bill
    The Scifi Guy likes this.
  14. #12
    Mar 2011
    Bordentown, New Jersey
    1,486
    Mike/Michael
    Information at hand is your friend! Welcome to the site and to the world of Opels. Please take a read on your headlight wiring system before you have plans on taking the car for a long run. You will have to inspect and repair the headlight wiring harness from the head lamps back to the engine compartment. 40 years of rotating headlights and high current have helped to crack the wire's insulation and in very short order, a dead short between wires in that loom can burn the car to the ground.
    Opel GT Source has a wealth of information with many of the parts you buy; tech tips they call them. For now, to get better acquainted with the GT, here is the Brooklands Workshop repair manual they sell. It can better help you in doing maintenance and repair, with this book in hand: Link: Opel GT Owner's Workshop Manual - Books and Literature - Opel GT - Store | Opel GT Source Buy this book, buy an old factory service manual on flea bay and in conjunction with this site, you'll be on your way.
    Good luck!
  15. #13
    Mike's Opel Shop Site Supporter My location opellane's Avatar
    Apr 2004
    Goshen,New York
    908
    Hi Zachary, Welcome to the club, You picked a Great Car to restore, There are a lot of good people here that are willing to help a newbie Opeler / Mechanic. These Opels are pretty simple to work on and have a very unique style.
    I guess by now you've found the drain plug..It's usually always in every engine on the bottom of the Oil Pan ( oil Sump) for easy draining.. The oil filter should be tighten one more turn after hand tight.
    If you only lost a couple table spoon of oil from the oil pump psi spring Cap .. you should be fine..
    re-install that plug/Cap with the spring and copper washer and Drain & refill oil ( oil Change) note: drain plug washer installed / crank it a few times with no gas and see if you get the oil psi needle to move.. then you'll be ok again.
    I would read up on info.here lots to learn on Car maintenance if you want to keep your Opel GT running properly
    Take pictures with your posts ..there easy to upload and have fun with your GT
    MIKE
    1973 MGB, Red, Weber 38DG
  16. #14
    May 2003
    Salfordville, PA
    3,982
    From the original picture in your first post, you can see the relief piston in the middle. It looks a little dirty. You can get a new one from OGTS, but make sure you remove the old one first.
    If you don't know how to disable the ignition to the spark plugs, just remove each spark plug wire. Make sure you label which one goes on each spark plug. 1, 2, 3, 4. 1 being the one towards the front of the car. You can name them Moe, Larry, Curley, and Shemp if you want, just make sure you match them up.
    Crank the engine and make sure you get oil pressure before firing it up.
  17. #15
    Oct 2002
    Mahopac, NY
    4,092
    The compufire ignition is fine (and actually good) although I "think" it messes with the firing order. There is a thread here somewhere on the conversion process. Before you put that relief valve spring back in make sure you carefully clean the 4 sealing surfaces involved, which are the bottom of the hex shaped plug, both sides of the copper washer, and the face of the oil pump cover. Don't use anything that will put heavy scratches in the surfaces or you will create a leak. For the parts that you can hold in your hand fine steel wool will work nicely but be sure to clean off any steel wool fibers, you don't want to introduce steel wool into the oil system. Some brake or carb cleaner on a rag on the end of screwdriver can be used on the cover but again, be careful not to scratch the surface if the screw driver pokes through the rag! I doubt you have lost enough oil out of the pump to require re-priming but better safe than sorry so do as others have suggested and check before starting. Instead of pulling the wires off the plugs you can pull them out of the Compufire and then you won't have the possibility of sparks flying around out the end of the wires if they get too close to a ground point. This avoids the hazard of fire. Just keep track of which one goes where as stated before.
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
  18. #16
    Super Moderator My location Ooooner's Avatar
    Concord, North Carolina, United States
    2,782
    Roy Bell
    4
    Hey, never received the seal! 😳
    opelgtguy and The Scifi Guy like this.
    Roy Bell
    1969 Opel GT (Switzerland)
    1973 Opel GT
    1972 Opel 1900 Wagon
    Carolina Opel Club
  19. #17
    Nov 2007
    Cöllingswööd, NJ
    9,820
    Gördö
    6
    Quote Originally Posted by Ooooner View Post
    Okay, here ya go:
    Is that pronounced Uuner? Uner? Owner? Uh-oh-ner? OoOoOoner? What the heck is an Ooooner anyway?
  20. #18
    2,782
    Roy Bell
    4
    Okay, here ya go:
    I appreciate the seal. It will be admired until the day I die! You need to get patches made up so people can sew them on the coats!
    Ok... Ooooner is sort of dumb but it's a nickname in my family. I'm a "Junior" and my little brother, when we were small, just called me Ooooner because he couldn't say Junior. So the damn nickname stuck on me like glue. You're not going to take the seal back, are you?
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  21. #19
    Dec 2016
    St. Charles, MO
    7
    I appreciate the support! In response to all the posts, I have had things I'm working on so I haven't been out to the car since the original post, but I hope to this afternoon. I plan to post in the intro thread I think I have seen but have been away at school without enough good pictures. Im on spring break now so I took some more and will be getting to that. Im not sure why I haven't bought that book already, I've read many people talk about it on here. The car is pretty rough so it won't be on the road for a while, but I was hoping to get it started and test the clutch this week. it feels bad buy the transmission at least goes into gears fine. I will get more pics posted soon (hopefully tonight). I have been silently reading on here the last 3 or 4 months but I'm new to forums so I've been figuring that out. I was planning to clean the plug with gas to get the gunk out of everything and then rinse it off just in case. My dad always uses gas with grease so I assume thats fine as long as I'm not mixing gas into the oil? I will be sure to check for prime before starting and to record it. So the relief piston is that raised portion in the hole their? Also I will look into the ignition thread here because the order of the wires is 1243 right now which I thought was wrong but maybe not for that system.
  22. #20
    Oct 2002
    Mahopac, NY
    4,092
    www.markandson.net
    www.gpny.com
    1. Oil drain plug crush washer
      By roundl in forum Group 6 - Engine
      Last Post: 09-13-2008, 10:01 AM
    2. CIH Head Oil Oil Drain Dam Tube for Improved Cam Life
      By jeff denton in forum Opel Tips & Tricks
      Last Post: 05-08-2005, 02:09 PM
    3. CIH Head Oil Oil Drain Dam Tube for Improved Cam Life
      By jeff denton in forum 6A - Engine Mechanical
    4. clean out
      By nobody in forum General Discussions
      Last Post: 06-22-2004, 04:49 PM
