Fan HP Usage
Results 1 to 16 of 16
Like Tree14Likes
  • 2 Post By kwilford
  • 1 Post By gt alex
  • 7 Post By Adolf LepoRello
  • 4 Post By Autoholic
Thread: Fan HP Usage
    Opeler Yellow73GT's Avatar
    Apr 2003
    N.Dak.
    951
    Chuck
    5
    Fan HP Usage
    I don't know if any of you guys have been following these guys, but I thought the information was interesting enough that I should share.
    https://www.youtube.com/watch?v=ZXdLgaFXZzs
    "Be Water, My Friend" Bruce Lee, December 9, 1971
    Opelnut opelnut_1's Avatar
    Apr 2003
    Colorado
    785
    Very interesting
    My Question is which provides better cooling cause in the Gt's case that should be more of a concern..
    My Collection:
    69 Opel GT (Mystery Car)
    70 Opel Gt (First car)
    72 Opel Gt (Mostly Stock)
    87 Volvo 240 (Daily Driver)
    07 Volvo S60 (Daily Driver soon)
    07 CBR 1000rr (SPEED FIX Machine)
    65 F250 (for parts haulin)
    65 Fastback Stang (Sleeping Till Gt is back on the Road)
    Jan 2016
    Albuquerque, NM
    538
    Joseph Bauer
    I've watched some of their other tests, they usually are interesting.
    As for which fan option is better for cooling, well the fan that robs the most power will be the best fan for cooling. The reason why is simple, the more air the fan pulls through the radiator, the more power it will consume to do so. But an effective cooling system is far more than just the fan. The radiator, type of coolant, thermostat, airflow and shroud / no shroud all play a part. It's better to focus on the needs of the whole system than to just go for the most extreme fan you can find.
    ~Joe
    "Autoholism is an incurable addiction medicated daily with car porn." ~Me
    "the sickest of the sick — a car guy who is collecting parts for the restoration of a car he doesn’t even own yet." ~Anonymous
    Apr 2003
    N.Dak.
    951
    Chuck
    5
    Quote Originally Posted by opelnut_1 View Post
    When I was looking for any prior discussions on cooling system stuff to see if fans had been discussed in this manor, instead I spent to much time reading other interesting things that distracted me, and after way too long decided to just post it.
    But to that point, as Autoholic has said, it's the entire cooling system as a whole, not any one part. I for one got to thinking about an electric fan after seeing this, simply because it would draw less hp from an already overtaxed little engine (relatively speaking). I ran some numbers on a hp/1/4mile calculator and 10 horsepower on a 2200 pound car means something
    Your ET / MPH computed from your vehicle weight of 2200 pounds and HP of 100 is 16.32 seconds and MPH of 82.81 MPH.
    (imagine factory stock)
    (now imagine modified with electric fan for the next 2 lines)
    Your ET / MPH computed from your vehicle weight of 2200 pounds and HP of 105 is 16.06 seconds and MPH of 84.16 MPH.
    Your ET / MPH computed from your vehicle weight of 2200 pounds and HP of 110 is 15.81 seconds and MPH of 85.48 MPH.
    I wouldn't think the little factory stock fan on the 1.9 would rob more than 10 horse, but who knows? And if it is stealing 10 horse thats a full half second in the quarter mile, only other way to gain that in a 1/4, without actual engine modification $$ is to shave off 500 lbs. (Rule of thumb 100 lbs =.1sec) I like cheap horsepower, so the idea of switching to an electric fan and maybe aluminum radiator for cooling efficiency wouldn't be such a bad idea after all. Hmmmm.
  7. #5
    Nov 2012
    Australia
    132
    Alex
    power loss from cooling
    Hi, The obvious advantage of electric fans is they only need run when needed.
    When street racing in my teens (40 years ago) I found disconnecting my alternator made a noticeable difference, every thing run off the battery for the duration of the race. You could do similar and disable the fan with a micro switch/relay on full throttle. The other thing we found affecting cooling was the air flow to the radiator was blocked partly by putting an electric fan in front of the radiator unless a short circuit was placed across it when not in use to stop it free wheeling in the air flow.
  8. #6
    Jan 2016
    Albuquerque, NM
    538
    Joseph Bauer
    There is no need to create a switch to disable a cooling fan in a GT. With a water pump driven fan, you could use a clutch actuated fan. It is only used when needed, so it shouldn't consume as much power. If you want to go with an electric fan, there is no reason to mount it in front of the radiator. Just ditch the water pump driven fan. Mounting a fan in front of the radiator is the worst thing you can do, you're impeding the flow of air from the front of the vehicle. Heat exchangers that move through the air work the best by pulling oncoming air through the radiator with a fan.
    ~Joe
  9. #7
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    We did "it" several different ways.
    One was to warm up the engine and gear oils to around 140F
    At the finish line well over 270
  10. #8
    Calgary, Alberta, Canada
    4,984
    5
    Quote Originally Posted by Autoholic View Post
    ... there is no reason to mount it in front of the radiator. Just ditch the water pump driven fan.
    Except there isn't usually enough room on a stock Opel GT between the water pump and the radiator for an electric fan. Do you have an Opel yet Joe?
    P.J. Romano and slracer like this.
    Working on the bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT, and may have another GT to build next...
  11. #9
    Nov 2012
    Australia
    132
    Alex
    cooling for less power loss
    If you have to put the electric fan in front of the radiator it won't block air flow if you stop it free spinning with the air flow. It is the spinning that blocks the air to stop a 12v dc fan from spinning you use a relay so when it's off the relay puts a short across the relay. It stops it because if you spin a dc motor it acts as a generator and the short put a big load on it, it can't push.
    Turning off the alternator at full throttle would remove electrical load what ever it is fan or what ever.
    Some water pumps don't pump properly at high rpm. reducing crank pulley size 10 percent will reduce power loss on all accessories. Some cars this works well and others need the pulley they have.
    alex
    davegt27 likes this.
  12. #10
    Jan 2016
    Albuquerque, NM
    538
    Joseph Bauer
    No, I have seen a few GT's that have done it, which is why I mentioned it. There is a GT in Orlando I'm rather interested in, and I'll be in Orlando in later July...
    ~Joe
  13. #11
    Jul 2003
    San Diego, CA
    2,280
    Interesting test and discussion, especially if one owns a small block Chevrolet (SBC).
  14. #12
    Opel Intern Swiftus's Avatar
    Aug 2008
    Corvallis, Oregon
    1,209
    Jay Swift
    Quote Originally Posted by Yellow73GT View Post
    Like a current vid where you can catch a glimpse of a drag GT
    You mean the Gray and Red GT on Roadkill? Yeah, rolled through the shot @ 28:50.
  15. #13
    Member Adolf LepoRello's Avatar
    Jun 2015
    Steiermark
    166
    As a general rule, I have stopped coming here (this crappy site) ...
    You should have continued to live by your own self-inflicted rule.
    kwilford, Ooooner, Lindsay and 4 others like this.
    "LIKE" my post or my cat will bite your nose off!
  16. #14
    Nov 2007
    Cöllingswööd, NJ
    9,826
    Gördö
    6
    Mods: Feel free to merge any useful posts from my other erroneously started thread on this subject into this one.
  17. #15
    Jan 2016
    Albuquerque, NM
    538
    Joseph Bauer
    As a general rule............... forearmed.
    You need to hook yourself up to a battery mate, and get a positive charge going. Your shirt should read negative earth.
    ~Joe
  18. #16
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Quote Originally Posted by gt alex View Post
    If you have to put the electric fan in front of the radiator ...
    alex
    Alex, I've seen a gain of 3-5 HP while on a dyno.
    1. Fuel Usage Rate
      By m610 in forum 6C - Fuel System
      Last Post: 12-12-2015, 12:20 PM
    2. Entertainment Center Power Usage
      By The Scifi Guy in forum General Discussions
      Last Post: 10-29-2015, 11:43 AM
    3. Replacement Steel Fan? (OEM Plastic Fan Hit Radiator!)
      By greensmurf20 in forum 6B - Cooling System
      Last Post: 10-01-2005, 03:29 PM
    4. Tag usage
      By tekenaar in forum Site Feedback, Comments, & Requests
      Last Post: 07-08-2004, 12:00 PM
    5. fan
      By Rob in forum 6B - Cooling System
      Last Post: 03-10-2004, 10:08 PM
