Real Name: Jon
Unanswered: Wont Roll Over..
Jon
Try tapping lightly on the starter and see if that works. If not pull the starter and check it. It sounds like the Bendix isn't kicking the starter gear in. Hth, Jarrell
Im in favor BANGING not tapping but it sounds like the starter. Check all leads and make sure the battery isn't half dead the easiest way would be to try and jump it if it starts with a jump its the battery not the starter.
http://www.cardomain.com/memberpage/470044 |
Real Name: Jon
Brand new battery
. Tore the starter out and took it, along with a few extra's, into NAPA to get them all tested. Not one is working . Anyone got any idea's or a working starter?
Starters
Look in the yellow pages and find a shop that rebuilds starters and give them a call maybe between all the parts you have they can rebuild you a starter or two. Usually they have the equipment to turn or rewind the armature and can rebuild the solenoid. A lot of Bosch parts interchange and they should be able to fix you up with a good starter or two.
#8 (permalink) | |
Jarrell
#9 (permalink) | |
long time Opeler
Starters are easy to rebuild. Most of the time it's just carbon buildup. A good tear apart and cleaning, Maybe brushes if they look worn. Opel starters are very long lived. I've "rebuilt" many by just cleaning them and the contacts.
The Great Opel Search
dont know if this was mentioned before but have you tried to jump the soleniod or anything of that nature?
1998 Sunfire "The Great Opel Search Continues" © of Skyler Shelton "The dictionary is the only place where success comes before work" Mark Twain "Tobmstones Dont Talk Back" Smoke Tires, Not Drugs... http://sportcar.net |
Real Name: Jon
Well I got a working starter on the car, went and turned the key, and...NOTHING! Same thing as before. On this starter, like every 8-10 times I try and turn the key, I can hear the starter spinning.. but does not ingage. I am really confused on what is going on! The engine rolled over once the first time I tried it, and then it quit... so I figured the starter! Any other idea's??? Please?? Any suggestions would be awesome!
Real Name: Jon
Check and cleaned all the grounds on the motor. The one from the block to the "body" as well as the cable from the starter to the battey, and from the battery to the body. All seemed alright, but cleaned them good anyway. Like I've said before, the battery is brand new, and from the sounds of it, the starter is getting plenty of power..just the "sound" of the click, it seems to be working plenty hard. I would have liked to have this car running tonight since I have tried everything I could think of.. but I have not gotten anywhere. It just seems really strange that the engine did roll over at first. My last resort is that tonight I sprayed some WD-40 into where the spark plugs go just to hopefully free up the pistons if there is some stickage. Also.. once again, any input would be awesome. I am really lost on this one..
check and make sure u have power at all 4 of the nuts on the fuse box...i had problem with my one opel there that only the one side had power and not the other side...just had to make a jumper to go across to give it power...
Adam |
Jon, you have a good working solenoid from what you said, so the next thing is the electrical contacts inside the solenoid. To check them out, the starter has to be removed, sorry to say. At the top and bottom of the cap on the solenoid, where the battery cable and starter motor connect, inside the cap are a pair of contacts, a very large washer hits those contacts, allowing battery voltage to go to the motor to spin it. You can possibly, rotate the contacts and possibly turn the washer over on the shaft so you have new contact surfaces to allow battery power to the motor. Some solenoids have a spring clip holding the washer on the shaft, allowing you to turn it over. If nothing else, sand it clean of the electrical erosion and the contacts also, and hope for the best. HTH.
Real Name: Jon
I will try the thing with the fuse block first.. its a little easier
Anyways.. so what you all are saying is that chances are because of "corroded contacts" or a bad connection, basically the starter isnt giving enough juice to turn over the old motor? I hope thats all it is.. my worst fear is that from sitting for so long, having the motor roll over that one time, even with fresh fluid's, a piston seized.. Do my symptons sound anything like that could have happened?
#20 (permalink) |
jon if you have worrys about the engine take the spark plugs out and turn the engine over by hand with a spanner or socket on the front pully (ign off)
if it turns over easy then you should be ok for worrys about pistons do it for a while or pull the fuel pump and dizzy after marking the positions with tipex of the rotor and use a drill and a long round bar with the end shaped like the drive on the dizzy to spin the oil pump so you get oil pressure in the system (turn the ign on to pos 2 and have some one watch the gauge for the light going out and the needle moving ) this will give the system some lubrication and make the starters life easyer if the engine has stood and the oil has drained back out of the system
#21 (permalink) |
Real Name: Jon
Well I missed a day of working just because I havn't been feeling well.. and went back to try some of the things mentioned today. I tried to turn the engine over with a wrench and ran into a problem.. which way does it turn? LOL. I am guessing to the "right" as if you were tightening. Well I tryed it, and was limited on space, but from what I could tell it did not move at all. I even had the spark plugs out. Does this mean basically the engine is seized, or is it just THAT hard to turn? If the engine IS stuck, I may be having a couple opels to sell to earn back some money since I NEED a vehicle to drive SOON.
#22 (permalink) |
yes it turns clockwise and with no plugs it should spin easy even the alt belt should turn it when you turn the alt
#24 (permalink) |
Shoot some oil down the cylinders to ensure it is lubed enough to turn. If you have a manual tranny you can rock the car back and forth with it in gear to see if that will free up the pistons. All you are interested in now is determining if the engine will rotate.
Good luck. One step at a time. Mike |
#25 (permalink) |
Real Name: Jim
![]() Provided Answers: 7
Your engine is probably not seized, forget that stuff for now. Is that starter motor really turning or just the solenoid clicking? Hook a jumper cable directly from the positive on the battery to where the same cable bolts to the starter. Sounds too easy, but I've seen just as many battery positive cables fail as starters from corrosion inside the connectors.
If that doesn't work and you have an automatic, there is a switch in the shift console that prevents the ignition switch from closing when the car is not in park. You can just short the switch with a screwdriver to test.
'74 Manta ("Sig") '75 Sportwagon (project) '72 GT (whenever I get to it) Sold or wrecked: '72 Manta Rallye '73 Manta '74 Luxus Last edited by timemachine; 05-13-2006 at 03:38 AM. |
