Unanswered: Wiring Questions
Anyway, I expected a bunch of bullet connectors and an old-style fuse box mounted on the fender or somesuch. Was I expecting the right thing? I just ask so that in the future I'll know I'm not looking at an Opel wiring setup. -R |
Oh Boy, the dreaded PO strikes again. Then again it might be a good thing, if, he left you a schematic of how/why he wired up the relays and new fuse box. I can tell you Opel GT Source can repair ignition switches for the GT. Pricey perhaps, but there are none to be had elsewhere. Could be the PO put in the relays to keep all the power from going through the ignition switch as it normally does. I don't know if it will help, but J J Wheatley of DESTEC has an outstanding 14 X 22 inch, plastic laminated, full color coded schematic of the GT. It may assist in tracing out the wiring you have now. At least it will show where the wires are supposed to go and may give you some idea of how the new wires are run. One thing sure, you'll need a schematic and a V. O. M. to trace out the wiring you have now, along with an understanding of how the relays are wired in. Lotsa luck with your project.
