Old 05-21-2009   #1 (permalink)
jak133's Avatar
jak133 is on a distinguished road
Answered: Bad ground or is it normal?
Hey all, was putting taillights back on after paint and while checking them with key turned to on position (engine not running) pressed brake pedal and radio cut out but lights work. With engine running radio does not cut out, whats going on here?
jak133 is offline
Most Helpful Answer - Posted by markandson
One other possibility. If you have a new radio it may have low voltage protection circuitry. Without the car running you may cause a low voltage condition when the brake lights come on, just a thought.
Old 05-21-2009   #2 (permalink)
sure sounds like a bad ground
Old 05-21-2009   #3 (permalink)
jak133's Avatar
Thanks Baz, electrics are not my specialty. Where do I start ignition, brake system, or lights?
jak133 is offline
Old 05-21-2009   #4 (permalink)
Old 05-21-2009   #5 (permalink)
jak133's Avatar
Never thought about that, it is new radio and everything seems to work fine.
jak133 is offline
Old 05-21-2009   #6 (permalink)
Uber Genius
First opel 1981's Avatar
To test this theory you can hook up a battery charger (or jumper cables) to your battery and try again.
First opel 1981 is offline
