Unanswered: red wire question
interior work
Uber Genius
I remember it as "white on the right" meaning the wire with the white strip goes on the right side as you are looking at the back of the gauge. The wiring diagram I have, though, says red/white is +B.
#3 (permalink) | |
Ok thank you... my original opel manual has a horrible wiring diagram! so here's a tricky one... there is a thick black wire going to the back of the cigarette lighter... appears to be a power because it has a rubber cover and the other wire is ground. That wire splits, and the split power wire is obviously supposed to go to something... I have a free terminal on the backside of the fan switch and the bulb to the flasher switch. Which one does it go to? thank you!
p.s. I HATE WIRING
interior work
