Curve Crazy GT
HELP ME PLEASE!!! its soooo annoying
thanks chris Owned Cars: 1973 Opel GT 1980 Chevy Monte Carlo-Current 383 project drag car. 1972 Chevy Monte Carlo 2005 Dodge Ram 1500 |
Chris,
It sounds like it could be the starter switch. Have you tried to bypass the switch. Do you hear anything when you turn the switch? If so is it a click or does the fan come on in the heater?
Are WE having FUN YET!! Rick in Atlanta |
Real Name: Allan Wheeler
Only other thing i could add is check the negative cable where it's attached to the body. Mine was hanging on by just a few little wires!!
73 Gt (RIP), 4 speed, 2.0L, 290H cam, weber, S-10 clutch w/ matched flywheel, sprint to a 2" pipe, Aluminum finned oil pan. SOLD! 70 Kadett Wagon 14k, 1.9L, Auto, weber |
Pull the battery leads off of the battery, not just tighten. Clean both the posts and cables and reinstall.
HTH Jeff
Curve Crazy GT
Allright, ill check all taht but now it wont even start, it just clicks, i have ignition switch in teh colum any more its a push button on teh dash, but ill clean EVERYTHING electrica
but any more input would be great cause im out doing it right now!l
No....its not a Buick....
Either turn off all the lights in the garage or wait till dark and have a buddy turn it over for you while your looking under the hood. You should be able to see the spark where its shorting out. Been there, done that. It beats taking everything apart. But you should just clean everything up anyways, then your good to go when driving season comes round!
HTH Joe
have the batterie tested it sounds like it died or has just lost charge
CoolCrisp! You don't live that far from me, and it was snowing like crazy here! What, do you live in an oasis?
![]() I have been waiting for a decent day to take mine for a ride....
Steve "ever notice you are never done tinkering with the GT?" Never mind, I am WAAAY beyond tinkering now...[/SIGPIC] |
Don't forget to check all the connections at the starter too.
Bypass ( Jump ) the ign. switch, go to the connector at the starter and go between the battery cable connector at the starter (Jump )to the solenoid connector ( car out of gear and brakes on & coil disconnected for safety )If the starter turns on then you will work from the solenoid connector & wiring back to your starter switch inside the car ( you said you had a push button ? ) HTH
Firstly, I'd give your battery terminals a GOOD cleaning. Secondly, I'd either give the battery leads a GOOD cleaning or replace them. Thirdly, clean ANY and all grounds. Still doesn't work? Then, bypass your starter by jumping across the solenoid terminals (like guyopel suggested). If that STILL doesn't work, you may have a problem with your ignition cylinder. I had the same problem with my old pickup, I tried every stinking thing possible and ended up having to yank the steering wheel and replacing the cylinder.
Now... You said that it intermittently works? I'd say the issue is with a loose wire, which is difficult to track down. Instead of cleaning your ground point, try clipping, stripping, and reattaching your wires. If you find a break in a wire that's causing a short, DO NOT USE A BUTT CONNECTOR!!!! Yes I know, they're cheap, easy, and pretty reliable. But repair it the right way: Solder and Shrink Tubing. Not only will it look more professional but it will also be more reliable in the long run. |
#17 (permalink) | |
BTW welkom PigletsOpel to the "sickest" site on earth [Opelitus or Opelitis, virus caused by Opel cars, very catching sicknes, doesn't hurt but you can get rid of it ] Have fun catching the bug by reading and posting here
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 06-12-2006 at 04:55 PM. |
